Member postings for Dan Shilling
Here is a list of all the postings Dan Shilling has made in our forums. Click on a thread name to jump to the thread.
Thread: Bantam metric leads crew & half nut
30/05/2021 20:54:50
Posted by Brian Wood on 30/05/2021 20:35:07:
Hello Dan,
I am surprised that no-one else has mentioned it before now , but surely there are change wheel arrangements that will give you metric threading using an imperial leadscrew. Are there no guidance set ups in a plate fastened to the change wheel cover or elsewhere on the lathe? It would save you a lot of money and the approximations are usually remarkably close.
With the 127t change wheel -that I don't have - you can get approximately the metric back just like you can on an imperial machine but some threads such as modular won't work not that anybody tends to make these.
It's just if I could get a metric leadscrew it would complete the machine and I could set the machine straight from the plate without fussy calculations and approximations all the time.
Thread: Professional rebuild ! (???)
30/05/2021 20:46:49
that's terrible bad luck they should pay you the full £1250.
If you find somebody that can fix that then perhaps you could give me their details because mine needs a metric leadscrew and half nut See my post.
If you decide to break it.... well more than it is, then I need a metric leadscrew and half nut.
30/05/2021 20:30:36
Posted by not done it yet on 30/05/2021 19:17:49:
Do you already have a lead screw? If so, one possibility is to replace the threaded portion with a metric trapezoidal screw thread.. Half nuts might likely depend on the machine design.
Kingston engineering would quote you for a replacement lead screw with nuts, I expect. I have seen several mentions of Kingston, on this and other fora in the past. All reports have been favourable, but I’ve never needed to avail myself of their services....
I'll look into the kingston option though I have not fully given up finding a good second hand metric leadscew and half nut - seems rare as hens teeth!
30/05/2021 20:27:52
Posted by Dave Wootton on 30/05/2021 13:15:04:
There is a firm called Nobilla that breaks Colchester lathes, but their prices are not bargain basement!
yes they only have new and that's where the £ 375 and the nut £100 then vat on top! comes from. Would be fine if the machine was hardly used but as it's 45 years old a good second would be more suitable.
I'll look into the kingston option - I do have an imperail leadscrew and half nut
30/05/2021 11:17:31
Posted by Dan Shilling on 27/05/2021 12:28:52:
So I was wondering on the off chance if anybody had a spare metric leadscrew and half nut for a Bantam or was breaking one?
Any suggestions would be welcome.
27/05/2021 12:28:52
I've bought a Colchester Bantam, it's metric but I need a metric leadscrew & half nut to complete the machine.
I can get from a Colchester lathe Specialists a new leadscrew for £375+vat but though the machine's good it would not justify that price especially as I have already paid near on £400 for it.
Imperial is findable but metric seems impossible to find a good leadscrew & half nut.
Simon
BOLDON
rapid Direct
walker midge
JD Metals
