Member postings for ADRIAN THOMPSON 3
Here is a list of all the postings ADRIAN THOMPSON 3 has made in our forums. Click on a thread name to jump to the thread.
Thread: M E Beam engine
04/02/2022 16:43:21
img_5517.jpgHi I part through machining the cylinder and and having read David Haythornwaite excellent article on building the M E Beam engine where he suggested that instead of 6 studs in the cylinder cover it looks better if 12 studs are used. So that is what I have done. I made a dummy stud for where the steam chest bolts onto the cylinder otherwise it would have a gap in the ring of studs. The dummy stud is tapped only into the cover, see photo.
I have been busy with the beam and have machined the bearings and placed them in situ. I never realised how important alignment is when trying to align the cylinder and beam. I think this is going to be the worse job of the build. Let me know what you think. Adrianimg_5514.jpg
23/01/2022 19:41:19
Hi I am building the M E Beam engine and I have posted problems with the Reeves castings. When I phoned they admitted the entablature castings were all chilled and so I decided to fabricate the entablature from steel. I obtained a strip of 4mm mild steel and machined a groove down the centre. see photo. Next I realised that using heat to form it into a `U` shape would distort it, so I made a simple bending jig and that worked really well. I cut the shape to size and silver soldered the entablature together. see photo. I left the entablature in one piece rather than cut the end in two and mounted it on the column. I think it looks good and took less time and machining a casting. I was not very keen on the brown mahogany base so I covered the top in aluminium and will engine turn the aluminium to give it a more modern look. What do people think of this? Adrian
Thread: Machining Cast Iron?
05/01/2022 16:57:41
Hi I am attempting to m/c a reeves casting of the Entablature for the M E Beam engine. The casting is so hard that it has chilled when casting. I have`nt come across this before so I tried to flycut the outside edge with a carbide insert tool. I have machined Stuart castings without any problems but with Reeves casting, sparks were flying all over the place. No chance of machining it so I have sent it back to Reeves for a replacement. I have a question to ask, Can the chilled iron be annealed making it softer, or is it scrap? Thanks Adrian
Rapid RC
Dreweatts
