Here is a list of all the postings Mark Davies 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Doncaster 2022 Exhibition - is it on? |
19/04/2022 07:28:58 |
Hi, you mention a midlands show, what is the name of this show so i can search for info please. Ta. |
Thread: Hello from Lincoln |
20/03/2022 14:15:00 |
Hi Nick, I too am from lincoln, nice to see you on here. So much info available.
Thread: Converting brick outhouse to (very small) workshop... |
15/03/2022 06:19:26 |
Hi Andy, i have an outhouse in my back yard tiny bit smaller, and only just enough space width wise for an SC3 lathe, leaving about 6-7 inch to do change gear swapping. I also have a small bench drill in there. dont drop anything tiny cos bending down searching aint fun good luck
mark
Thread: Screw cutting problem |
14/03/2022 16:43:22 |
That finish is perfect. Well done for getting a decent pic of that. |
Thread: Stewart Harts Horizontal Engine build |
17/02/2022 19:37:01 |
Cheers jason. I really wanna get on with this but i have so little time at the mo, but getting there slowly. Rveryones help is very much appreciated. |
17/02/2022 19:19:59 |
Hi folks, im about to start to assemble my parts for this engine. I know that i have to put gland packing behind gland on the valve chest , but does any go behind the cylinder hex headed gland type fitting that the piston rod goes through. cheers in advance for any help. |
05/02/2022 10:45:52 |
Brilliant. Thankyou jason. |
05/02/2022 09:22:40 |
Brilliant. Thats what i thought as the dimensions were all in the same ball park. Thankyou. Jason. is there a way i can set it up so i get a notification on my phone if my post gets a reply?
cheers. Take care. |
05/02/2022 03:22:38 |
Thanks for the help about studs n nuts guys. does the height of the centre of the cylinder, the slide and the crank shaft have to be the same height exactly from the base. I assume they do, but drawing is vauge on this and was after a bit of valued knowledge please. thankyou. |
24/01/2022 21:58:16 |
Thanks very much for the replies gents. Studs n nuts it is. thanks again. Mark |
23/01/2022 09:06:11 |
Hi all, Im currently half way thro this project and was wondering what peoples thoughts were on the fixing i should use, eg studding with nuts or hex headed bolts. Think whatever i decide i will make them from brass. thanks. |
