Member postings for Michael Callaghan
Here is a list of all the postings Michael Callaghan has made in our forums. Click on a thread name to jump to the thread.
Thread: Looking for help valuing two lathes
19/06/2022 21:42:59
Just take lots of good pictures and stick it all on eBay. The dealers that offer to buy your complete workshop and brush it afterwards will rob you blind. I have sold a few lathes and two milling machines on eBay for good prices as I updated my machines. There are lots of buyers out there, even in these dark days.
Thread: motor insurance rant
15/06/2022 14:24:44
I lived in France for a number of years. They had two types of insurance. Within France and outside France. At the time my English insurance was £300 pa fully com. The French insurance with AXA was £80 and that was fully com full European cover. At the time motoring was a whole lot cheaper then in the U.K.
Thread: Flash player
14/06/2022 16:09:24
Why can’t I open the older magazines. Flash player is no longer supported and his an out dated product. So why can’t the owners of the magazines sort this problem out. It’s been like this for over a year now to my knowledge.
Thread: Drawing needed for 5 inch gauge three cylinder royal scot
14/06/2022 14:27:38
Hi chaps, I need a drawing of the front Centre panel that goes just in front of the smoke book door to the top of the front buffer. This is for a three cylinder royal Scot so needs the housing for the piston rod. If you have details of this part can you please let me know. Thanks.
Thread: Material for wheels
08/04/2022 18:43:28
Thanks chaps, I will take a look
08/04/2022 16:04:35
Hi, it had to happen. Due to an house move I have lost the rear trailing wheels for my 5 inch Stirling single. I have looked into the cost of cast iron and it’s ridiculous what people are asking these days. What other materials can I use that don’t cost a small fortune. Thanks.
Thread: Steel boilers
05/04/2022 21:03:47
Interesting, however I find it odd, that there is nothing about material thickness in the federation book on boiler tests. The boiler I think was from a traction engine in which steel boilers are very common. If traction engine people can get their boilers tested without cameras and so on, and I have witnessed a few traction engine tests on steel boilers, I don’t understand why it’s not the same for locomotive boilers. Odd hobby at times I think.
05/04/2022 19:16:45
Hi chaps. I have a question. Last week I saw club boiler testers refuse to test a steel boiler. Said boiler was out of the frames and unwrapped. In the boiler code book, it states that steel boilers can be tested and how to go about it. So why did these boiler testers refuse to test a boiler. In my mind it looked like they just made up some new rules, in refusing to test the boiler. If some clubs do test and others don’t, what is the point in having a testing code or standard. What our your views on this. Mine is if the boiler stood the test then that’s a past, end of. I read in an American magazine that a chap had made a boiler out of a used oxygen cylinder for his big boy locomotive. So our boiler testers getting above themselves here in the U.K. I am all for safety. But if something passes, it is ok. And I think boiler testers should all test steel or copper boilers or none at all.
Thread: At my wits end trying to remove pulley
11/03/2022 11:10:01
Job done. Cutting the shaft and knocking it out from below did the job. Thanks for all your input.
11/03/2022 09:23:51
Hi chaps. The motor on my meddling pillar drill died. I now need to remove the aluminium pulley from the motor. There is a locking tap on the motor shaft and no matter what I try it will not come out. I have tried heating the pulley and tapping from below, nothing. I tried bathing in wd40 for a day, nothing. Due to. The tab being low down in the Center of the pulley I can,t get a good hit on it and pulling on it does nothing. So chaps, is their a way of getting this dam pulley off the shaft I am thinking that the only way open to me is to cut the shaft off the motor and knock it out from the bottom.
Thread: Rear section of boiler wrap holding in place
09/03/2022 13:03:56
Hi chaps.I am having fun and games with the rear section of boiler wrap for a 5 inch gauge Stirling single I am building. Apart from one boiler band in the front part of the section the only way I can see the wrap holding in place is by clamping the rear edge under the cab front edge. Is this the correct method or is there a better way. There is not much space between the boiler and the frames and main wheels on a Stirling so just want to be sure that the wrap is correctly held in place. Thanks
Thread: Stirling regulator stuck
16/02/2022 20:14:28
Thanks, will give it a go.
16/02/2022 19:59:00
Hi, can anyone help here. The regulator is completely stuck on my Stirling. Unlike other locomotives I can’t see much by looking inside the boiler from the dome. So is there a way of freeing the regulator without taking it all apart. Thanks
Thread: Stirling single build notes
16/02/2022 19:51:33
It is a 4-2-2 .
16/02/2022 15:02:09
Hi, does anyone know if any build notes got published for the Stirling single. I saw what looks like build notes for the Stirling in an old ad on station road steam in one of the pictures for a project Stirling. If anyone knows of any notes available can they please let me know. Thanks
Thread: 3D printer forums?
08/02/2022 17:21:03
Take a look on Facebook. There are a number of forums depending on the machine you have.
Thread: Right to Repair
08/02/2022 17:19:34
Bmw wanted £4000 for a new headlight for my 5 series. Ok it’s the fancy led job which is very good when it’s working and by far the best headlights I have ever had on a car. But £4000. Thank god I was able to get a used one. Mind you that cost £450. Manufacturers just rob you senseless these days.
Thread: I am getting shorter - how about you.
08/02/2022 17:14:41
I have lost an inch in the past 5 years. Was always 5ft 10. But now 5ft 9. It’s an age think
Thread: Setting left and right side
25/01/2022 16:40:43
Thanks chaps,
25/01/2022 13:55:42
Hi chaps. I am a bit at a loss. The plans I have only show one side of the locomotive. And I am now at the point of setting up the wheels. I understand that there is a leading side and a following side. The loco is a b1. So my question is. In what position do you have the connection rods in relation to each other on each side.let’s call the right side of the locomotive the right hand side as you are looking at it from the front.so in what position should the connection rods be on the right hand side and should the crosshead be at the front, ( nearest the cylinder) middle or rear of its motion. And which position should the left hand rods and crosshead be in also. Thanks. Michael
Dreweatts
Rapid RC
