Member postings for Leslie Deasy
Here is a list of all the postings Leslie Deasy has made in our forums. Click on a thread name to jump to the thread.
Thread: Hoover Motor Lubrication
11/07/2021 23:06:46
Hi have you any pictures of your kennedy hacksaw please.
Would also like to see the hoover motor striped
Thread: Kennedy Power Hacksaw Gaiter
07/06/2021 22:18:27
Sorry to hijack on the OPs post but I'm just wondering would anyone have a copy of the owners manual for the Kennedy power hack saw?
Thread: Unimat sl with high tailstock
03/06/2021 01:00:53
Posted by Andy Carlson on 31/05/2021 18:16:50:
Mine is OK... never measured it but have not noticed an issue anyway.
Do you get the same height difference with the tailstock barrel fully retracted as with it fully extended? - just wondering if the tailstock is sitting level or not.
Are we talking the ols Unimat DB/SL here or the more modern (red) thing similar to the 'Unimat PC'
Hi its the Hammered green model. No droop noticeable on the barrel
31/05/2021 17:32:14
New unimat sl owner
Just wondering if any one else with a unimat has come across there tailstock been 0.5 higher than the spindle center??
Thread: Setting up a Tri-Leva Myford ML7
25/07/2020 21:41:00
I really need a copy of the tri lever handbook of anybody cab help
Thread: Ml7 tri-leva handbook
25/07/2020 16:40:15
Hi can anyone one help me please with a tri leve hand book and setting it up please ?
I have my tri leva running pretty nice but I had to slightly increase the friction on the axle that the levers pivot on the keep enough friction on the lever while down in the engaged position! Is this the correct procedure for fint tuning the tri lever set up ??
25/07/2020 16:14:20
Posted by Cornish Jack on 18/11/2013 11:49:09:
I have sent you the scans of the Tri-Leva relevant extracts from the ML7 manual. Have you received them?
I ask because I did a 'copy and paste' of your email address and have a nasty feeling that I may have included the final full stop - in which case the message will be wandering around in e-space!!blush
Rgds
Bill
Hi could I trouble you for a scan please of the tri lever handbook
Edited By JasonB on 25/07/2020 19:17:20
walker midge
JD Metals
rapid Direct
