Here is a list of all the postings Roger Benson has made in our forums. Click on a thread name to jump to the thread.
Thread: M-DRO on SX2.7 |
21/01/2021 18:46:51 |
Snap. The 10V has been on the backburner for a while.
Roger |
21/01/2021 07:33:01 |
Edited By Roger Benson on 21/01/2021 07:34:01 |
20/12/2020 18:09:09 |
Sorry for the pics on the side. Anyone know how to rotate?
Edited By JasonB on 21/12/2020 10:19:43 |
20/12/2020 17:18:58 |
I used one of the supplied plates to support the reader head. This was then mounted on a piece of angle that fits to the existing swarf guard mounting holes. I will mount the Y axis this week. I have some pics but dont know how to add them at the moment. once I find out how I will post them. |
16/12/2020 18:43:20 |
Posted by Oxymoron on 16/12/2020 17:23:42:
Roger, Paul, I have added a 4 axis DRO to my SX2.7. Photos in my Album titled DRO. May not be the best way to accomplish the installation but it works for me. I've bought some Aluminium to tidy it up but not got around to it yet. Hope the pictures help. Dave Thanks Dave |
16/12/2020 18:42:56 |
Posted by PaulF on 16/12/2020 17:11:08:
Hi Roger. Im in exactly the same position at the moment, I should have the X axis completed tomorrow. For the Y axis I think I’m going to have a fixed scale bolted to the base casting and make a custom bracket to allow the head to bolt into the holes already there on the table. Paul Hi Paul I have the magnetic version as well. I have not built up much metal stock yet so have sent off for some aluminium to play with. I would prefer a fixed head myself.
Roger |
16/12/2020 15:11:54 |
I am in the process of installing an M-DRO setup onto my SIEG SX2.7 mill. I have managed to get the X axis on but am struggling a bit with the Y axis installation. Does anyone have any pics of their Y axis installation on an SX2.7 Have a fixed reader head or a fixed scale? Thanks Edited By Roger Benson on 16/12/2020 15:33:40 |
Thread: Rotary Table Quest |
23/11/2020 11:26:36 |
Thank you all. I will just have to wait until they are in stock somewhere. Vertex or Soba. DRO next? |
Thread: Stuart 10V Build Log - Complete Beginner... |
22/11/2020 14:39:45 |
Thank you Jason. Strange how it is missed on both documents.
22/11/2020 13:18:52 |
Posted by JasonB on 28/06/2020 10:07:33:
Personally I never machine flywheels on an arbor and it is just asking for chatter and a poor finish. If possible hold by the inside of the rim in either 3 or 4 jaw chuck. Stuarts are usually fairly true once cleaned up with files so 3 jaw will do. This way you can machine the face, 1 side, hub face and then finally bore all at one setting ( I don't ream) then just flip it over to do the other side of rim and hub which don't need any concentricity. Drill drains first, 1/16" or 1.5mm hole will do, threaded hole about 1/16 to 3/32 short of cylinder Edited By JasonB on 28/06/2020 10:08:58 What is the thread size for the drain holes? I cannot find any reference to them on the drawing or in the booklet.
21/11/2020 10:08:09 |
Hi I am looking for a Soba 6" rotary table and a chuck adapter plate. Everywhere seem to be out of stock. Does anyone have a secret source or can offer advise on a suitable alternate that is in stock? Cheers |
Thread: Slot saw speed |
01/10/2020 08:24:45 |
Posted by JasonB on 30/09/2020 18:13:04:
What is the wall thickness of your tube and how are you cutting it ? slices off or along it's length It is a tapered hole 2mm to 4mm over a 20mm length. |
30/09/2020 18:04:07 |
Thanks all. Need to order some more blades. Is 40T too course or OK for mild steel? |
30/09/2020 16:05:46 |
I have just bought a slot saw blade and arbor from ARC and am quite surprised to find that the key way in the blade is to small for the arbor key. When I queried this it appears that this is common. You have to either open out the key way in the blade or machine down the key in the arbor. Surely in this day and age if you sell paired products they should fit. Anyway onto the question. What is a good starting speed when using a slotting saw. I have managed to dull mine after only 2 light (.2mm) cuts. I have a 50x0.7x13x40T HSS blade cutting into 25mm mild steel tube. I do not think that 0.2mm is too deep or am I to be corrected? Thanks |
Thread: Understanding Digital Subscriptions |
16/05/2020 20:06:36 |
Yes thanks Jason I am now in the archive where I want to be. Just finding where your milling series starts. Thanks for your help and patience. |
16/05/2020 19:37:29 |
Posted by Neil Wyatt on 16/05/2020 15:03:20:
The 'bad referrer' error usually means that when the page 'refers' the browser to a flash player it is unable to find one. This is usually for one of two reasons:
If you get it for more recent issues it can suggest a p[roblem accessing HTML5 - updating your browser to a more recent version will probably solve this. Neil
Thanks Neil Please see my reply to Jason below.
Roger
16/05/2020 19:36:41 |
Posted by JasonB on 15/05/2020 20:30:30:
You need your subscription number not order number if i remember rightly, should be a 10 digit one. Edited By JasonB on 15/05/2020 20:33:59 Thanks Jason I finally found the subscription details in an email buried in the junk folder. I used that but it now says that the subscription is not active. If they want a subscription number then they should change the page and not ask for an ORDER number. |
15/05/2020 20:50:13 |
About 2pm. |
15/05/2020 20:41:59 |
I got the subscription on ketans advice to read your milling articles. |
15/05/2020 20:40:27 |
I don't have a subscription number. Neither email from my payment details a subscription number only an order number. I agree that there should be one somewhere. |
