Here is a list of all the postings Dave S has made in our forums. Click on a thread name to jump to the thread.
Thread: T-slot cutter |
19/05/2022 20:41:00 |
Yes to photos. I can’t picture what you made. Sounds useful Dave |
Thread: making a Square |
12/05/2022 19:37:22 |
Surely the point is to make things?
Dave |
11/05/2022 21:35:48 |
Im building a CNC mill, and I think Ill need a chunkier square when I eventually get to the aligning stage. I came across a webpage sometime ago (can't find it now of course) that showed how to make one from a chunk of cast iron. Not having a lump of iron the right sort of shape I poke about and found some thick walled steel box section. Hurrah, that'll do to try the process at least, and might even work for the intended job To start the long edges are made parallel. Fortunately I have a reasonable surface grinder, so I slapped the box onto the mag chuck and started making sparks: The weld seam was something like 0,004 lower that the edges. Not too bad. I planned to rough grind and then finish, so once both sides had cleaned up I checked it on the surface plate. Basically zero movement on a 0.0001" DTI. I was well chuffed Now the long edges parallel It was time to rough in the ends. I hacksawed them roughly square, whacked it in a known OK grinding vice and made some more sparks: Then with parallel ends that should be close to square it was back to the surface plate to measure up: DTI on a surface gage rocked left and right for the high reading. Turned out to be leaning by about 0.007". For the first round of squaring up it was back to the grinder with some feeler gages: 0.003" under one side and clean up one end, then flip and make parallel (without the feelers). At this point I left it to sit for a couple of days, partially to let it move if it was going to, and partially cos I have other things to do... It did move, and the long sides were slightly out, something like 4 tenths IIRC. So I did a light set of finish passes on them. This is the start of one ( the beautiful dark corner): Ended up back to basically as good as I can measure Then another round of measure the squareness. I couldn't easily get the round part of the surface gage to touch and have the DTI at the height I wanted due to the way the angles worked out. Fortunately the surface gage has a V in the front, so one bearing later I have a round bumper again and I could measure over pretty much the full height.: This time I needed an offset with precision in the tenths region, so I made a pair of gage block stacks with the required offset ( IIRC it was 0.2 on one side and 0.2014 on the other). The square was supported on these on the grinder, mag'd and clamped so I didn't get any ideas about flying away and then a fresh dress and a light grind and I cleaned up the ends. The finished square has come out OK: Its roughly 90 degrees Dave
Edited By Dave S on 11/05/2022 21:36:28 |
Thread: J & S surface grinder - refurbishment |
11/05/2022 17:06:45 |
I would probably TIG or braze up the holes - but I have a TIG set and like to use it JB weld might also be an option Dave |
Thread: Jones and Shipman 540 plain bearing head seals |
06/05/2022 08:16:03 |
Yes indeed. I was hoping to get the seals before having to strip the machine. Still if no one knows then I guess that’s how it’ll go. |
05/05/2022 08:49:42 |
All I have is a photo of the parts manual, which has a very general description: Of course the part numbers are no use unless you can get them from the apparently defunct J&S. Given the cost of the wheel head oil Id rather not run a total loss system... Dave
04/05/2022 19:53:32 |
My elderly 540 has decided to start leaking from its wheel head. It’s the plain bearing, uses super thin oil model. Andmar suggested a seal place, but the info in the parts manual is apparently not sufficient. Dave |
Thread: METAL DUST & VFDs |
02/05/2022 11:26:21 |
I would put it in a box with filtered forced air cooling. doesn’t need to be fancy filters, just something to stop the brass - a panel filter for a car engine might be what I’d use as I have them available. Even a pair of tights from swmbo over a tube would work. Dave |
Thread: making spindle bearings |
02/05/2022 11:18:41 |
What are you making a spindle for? Dave |
Thread: Ping - and a screw is lost |
01/05/2022 09:48:57 |
I would not worry about comments like don’t use the “cheap Chinese” movements. Much like machine tools there is a significant section of society that believes cheap Chinese = terrible quality junk. In my experience a working watch movement cannot be junk of that sort, although the finish might not be first class Swiss. Tool’s however are a different matter. They are an extension of your hands, but with less integration. I also do surface mount prototyping and rework with the same tweezers : That’s on a standard 0.1” piece of veroboard and I had to hand place and solder those connections… Dave |
Thread: Question Re Camlock Chuck Fixings |
28/04/2022 17:09:10 |
A small amount of poking later : **LINK** John was running D1-5 not 6, but the principal is the same Dave |
28/04/2022 17:04:21 |
IIRC the late Sir John Stevenson of this parish used to run D1-6 with only 3 pins in it. The pins pull the taper together. 3 is most likely sufficient for most uses. Somewhere on the internet (might be the home shop machinist bbs site) there is a long discussion about this and how 3 pins are plenty enough based on the strength of them. Dave |
Thread: Blobs on 3D print.. |
25/04/2022 19:12:58 |
Good news and an interesting thing to file away for next time I have a blobby print Dave |
Thread: Machine movers |
23/04/2022 16:52:21 |
I’ve used DD haulage in the past to move my tools: Dave |
23/04/2022 11:30:37 |
Looks like your retract setting is too low, so the filament oozes as the head is moving from one move to another. Usually a setting in the slicer I think
Thread: ER16 Collets from Ebay |
23/04/2022 09:38:22 |
And varies with collet clamping diameter as well as collet size. Useful link to regofix doc: **LINK** Dave |
20/04/2022 09:56:45 |
I’ve only skimmed the video, but it looks about right: Dave |
19/04/2022 18:29:49 |
The rubbery mesh draw liner stuff is quite good. Stuff falls into the holes and doesn’t bounce back out. If you are “pinging” out of tweezers I suggest you dress them and also practice manipulating small nuts and bolts - 12BA are cheap enough in a small packet to practice stacking, moving and rotating, with the bonus that they are none critical if they ping off. Have a poke about at the watchmaking forum on WatchUSeek for more tips and stuff. Dave |
Thread: Need a pen to draw the "finest possible" lines? |
19/04/2022 13:57:43 |
I suspect the increasing use of fibre tips is related to the cost of manufacture. One thing with Isographs and other tube nib pens is that you must hold the pen consistently, and preferably at right angles to the page for the line to be correct. Fibre tips flex, but “tube” pens don’t
Thread: Sigh, practicing a skill I would rather not need |
18/04/2022 14:43:14 |
Managed to complete the second part without any mishaps The D bit technique is one I got from James Harvey’s Machine Shop Trade Secrets. It’s a good book of short tips and tricks. I misremembered it slightly - he uses a ball nose, which presumably is a better geometry. He also likes to make the cutters hexagonal rather than round for some reason. The important bit tho I’m sure is having a rigid setup and pecking a thou at a time: Mods - if there is any sort of copyright issue then feel free to remove the pictures- I think it’s ok for educational sharing. I’ve used this truck a couple of times on taps, but also to rescue a watch case where I snapped a tiny carbide drill in 316 stainless. In that case the cutter was bigger and I sleeved the hole, but the D bit did the job, with the tiny drill shattering as the pecking happened. Dave Edited By Dave S on 18/04/2022 14:44:00 |
