Here is a list of all the postings Jager has made in our forums. Click on a thread name to jump to the thread.
Thread: ME beam engine |
18/04/2022 11:47:47 |
Thanks for your kind words. Yes Jason it runs ok on air and apart from minor adjustments to be made during final assembly I am hoping that once the bearings and gears are all bedded-in it will be capable of running at a realistically sedate speed. David, I resisted the temptation to divert to other projects and instead determined to see this one through. Model engineering is something I came to late in life when other pursuits were becoming difficult. Fortunately I seem to have retained a vestage of skills learned many years ago and their current resurrerection is the cause of much personal pleasure. I would dearly like to build a triple expansion engine but fear time is against me so I shall curb my enthusiasm and stick with smaller things. RMA, I didn't find the Reeves castings too bad although the bedplate did need truing, some items were badly chilled and the entablature is dreadful as may be seen in the photo; I will remake this in mild steel. What I did find annoying was the obvious missmatching of the journal bosses on the beam. A conscientious supplier would have a new pattern made, as well as correcting the drawings in respect of the Watts parallel linkage interference and the valve gear errors caused by the change of steam chest. |
17/04/2022 22:40:18 |
17/04/2022 22:38:53 |
12 months down the line and the ME Beam Engine is ready for stripdown, painting and final attention to detail such as adjusting gibs and cotters to length, final stud lengths etc.. Perhaps the next project will be a suitable boiler to steam it. |
Thread: Vacuum Limiting Valve |
23/01/2022 11:52:27 |
Wouldn't it take the form of a boiler safety valve installed in reverse?
Thread: Milling on a Lathe with a Vertical Slide |
15/10/2021 18:13:31 |
Hi Bill, Pleased to see you are getting there. Don't forget you can also take the vice off and clamp your work directly to the slide. It's handy if you just need that little bit more room or your workpiece is an odd shape for holding in the vice. David. |
14/10/2021 18:19:00 |
Posted by William Harvey 1 on 14/10/2021 07:03:34:
Posted by Nicholas Wheeler 1 on 13/10/2021 22:45:56:
Posted by William Harvey 1 on 13/10/2021 19:13:03:
Posted by Nicholas Wheeler 1 on 13/10/2021 18:55:54:
So spend a few pence on allen head bolts, and file new T-nuts out of some stock. Of course, that’s what I’ll do, but why would Soba supply bolts that don’t fit? I am happy with measuring the Allen Bolts, but I have no idea how to measure and get the correct T nuts? Have you considered turning the vice through 90° and putting the bolts through the slots provided on the outside edges? I would measure the end of the T-slots. Probably with a rule, as the nuts don't need to be a machined sliding fit. Hacksaw and file job. TBH I think the nuts and bolts supplied are designed for the slots 🤣
Bill, do as Nicholas suggests,, turn the vice 90 deg, make/get T-nuts to fit the slide and bolt through the two counterbored holes in the vice with allen bolts. This arrangement will allow you a good range of vertical travel by selecting an appropriate slot on the slide. David |
Thread: HELP needed |
08/10/2021 10:15:31 |
Hi Steve, I just make up a solution of a litre of warm water and put around half a cup of citric acid crystals. This is not aggressive, nor dangerous, like sulphuric. Just keep an eye on your work, no sweat. |
23/09/2021 22:55:05 |
The SOBA vice in your link is the same as in Jasons pic. If you search Chronos for small milling vice for Myford you will get a choice of 4 pi x. On of them clearly shows the mounting holes in addition to the 4 edge notches. The only variant in Jasons pic is some nuts replacing the knurled end of the operating screw. |
23/09/2021 20:14:30 |
Yes, as shown in Jasons post above.
David. |
23/09/2021 10:57:47 |
Bill, That vice in the pic will fit. The two bolt heads you see hold the vice on via t-nuts in the v. Slide slots. You also have a choice of slots which improves versatility. David.
Thread: Workholding Problem |
11/09/2021 20:59:50 |
I may well be misunderstanding the problem. If it is the length of the large diameter shown in the chuck you need to reduce could you machine a ring, close fitting on the castellated section and superglue it on. Hold this in the chuck to machine large diameter and its length. When done just apply a litte heat to seperate. |
Thread: Pitch Circle |
21/06/2021 19:05:40 |
Hi Roy, When calling for holes on a pcd it is necessary to describe the hole and specify the pcd. e.g. 4- holes 6mm dia on 24mm pcd. I suspect something is missing from your drawing. David. |
21/06/2021 19:04:51 |
13/03/2021 10:10:08 |
Michael, I apologise for my tardy response but this is my fourth attempt - each time I hit the button for ADD POSTING everything deletes. I now have the castings and have begun work. Thus far I have machined the baseplate and the main column and all seem acceptable. If you search on line BUILDING THE ME BEAM ENGINE you should find a vid by 'engineeringmodeller'. He has some good vid, lots of pics of his build and somewhere amongst his stuff is a narrative detailing errors he found in the drawings. I hope this is of some help. David |
06/03/2021 16:55:20 |
Posted by JasonB on 06/03/2021 16:45:28:
No you would need a full digital subscription to ME rather than just paying the extra to include digital to your existing MEW print subs as you only get access to one mag's archive per digital subscrption. Thanks. |
06/03/2021 13:41:39 |
Thanks Jason, Am I correct in thinking that a digital subscription to ME is what you mean? Or upping my paper subscription to MEW as your 4th para.? David
06/03/2021 12:30:52 |
Gents, Many thanks for your advice. I have obtained a set of castings for the ME beam engine and realise a build guide would greatly assist me. Is there a means to obtain the series if articles which were published in MEW, Ibelieve in 2019? David. |
04/03/2021 09:41:37 |
Bill & Jason, Many thanks for your input. I am convinced to go with Reeves. Wish me luck! David |
03/03/2021 18:28:22 |
Good evening, I am given to consideration to attempt building an ME beam engine and see that there are a number of firms producing casting kits. I am aware of Stuart Models producing a set of castings for a similar model, but find their prices would bring a tear to a glass eye. I wonder if there are any members here who have recent experience of available kits and who are able to give constructive criticism of potential suppliers to help this rank amateur avoid making the wrong decision. |
Thread: Free inserts. |
12/12/2020 13:06:48 |
Yes please!
Dave |
