Here is a list of all the postings Peter Howell 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Fosse way Exhibition Centre |
18/02/2021 20:51:23 |
I think it is or was TEE
Thread: Multi-part assembly drawing |
18/02/2021 09:06:43 |
Posted by Nigel Graham 2 on 17/02/2021 14:22:54:
(I use TurboCAD, and it doesn't offer magnifying - it might fit a 5" g. loco cylinder and its dimensions legibly at 1 : 2 on A4, but I don't think it would allow showing the drain-cocks at a readable 10 : 1 on the next sheet.) ' Nigel Surely in TurboCAD when you insert a view into your 'Paper' Space you can change the scale. So all you need do is create a separate view of the detail, insert it into Paper than increase its scale as much as you need. I've just checked this. I am running an old 2016 version Turbo that I've never transferred to my new Laptop so I had to fire up the old computer and checked last night. |
17/02/2021 15:50:36 |
The discussion my query provoked has be most interesting. Personally I get a great deal of satisfaction from producing a good drawing, and you can do it sitting down in the warm ! I have enjoyed Technical Drawing (as it was called) at secondary school. I still have a book given to me as a school prize for that subject. Then in the early 1980's I introduced a very early CAD system into the small engineering company I was working for. A program called RoboCAD running on an early IBM PC. I was still involved in producing drawings for them up until I retired in 2000. But only in 2D. After that I bought my own copy of TurboCAD and continued producing drawings for my own use - but to a reasonable standard. Now I thought it about time to stretch the grey matter and try to get to grips with 3D. FreeCAD is free so nothing to loose if I give up. I have been told I should have signed up as a hobbyist for Fusion360. But I'd already started producing some stuff with FreeCAD. |
17/02/2021 11:32:50 |
The latest version of FreeCAD - 0.19, (Not yet a stable release so may have bugs) has Assemblies. But even with the stable 0.18 it is easy enough to move and align parts. I think I'll stick to separate drawings for components but import into an assembly to check for fit. FreeCAD easily produces an orthographic (either 1st or 3rd angle) drawing on what ever paper size you want. It will also produce G-Code, though I've not tried this yet. I used to use TurboCad and Vectric Cut2D.
Thanks - It's always interesting to get others ideas. A lot of knowledgeable people out there !!
17/02/2021 09:02:37 |
Posted by HOWARDT on 17/02/2021 08:38:27:
The traditional way in many places was to draw on one sheet. It was easier to handle one Elephant size sheet, later A0 size. When CAD started I continued with one sheet as we still used a large format printer. Eventually it just became easier for everybody to use a single part per drawing, historical large sheets just got cut up. Using single part allows use of smaller printer, in a lot of case a cheap laser A4 lase is good enough. Yes. In 2D draughting I've always give each part its own drawing. But now in 3D I'm wondering if it's better to have everything assembled as it goes, then separate them out later to produce a production drawing. It would mean that the total drawing, consisting of all the component part, will get very big (computer big, not physically big)
17/02/2021 08:27:33 |
My first foray into 3D modeling, using FreeCAD. My question is with an assembly consisting of many parts, such as a steam loco, is it best to draw each part separately and import them into a separate assembly drawing or draw everything on the one drawing toggling the visibility of each part as it is drawn and placing it in its correct position as you go ? |
Thread: Transporting Loco |
03/01/2021 13:36:11 |
Thanks for the advice. Thinking about the problem I will cut a piece of plywood to be a fairly good fit on the boot floor so that it can't move sideways or fore and aft. Then screw some angle iron to make rails for the loco to sit on and some sort of bars like Clive mentions over the buffer beams clamped down to the ply. I'll give this a try first and see how it feels then modify as necessary. I agree with 'not done it yet' it does need to be restrained. I may drive carefully but there are some idiots about.
02/01/2021 15:57:32 |
My Polly loco is almost complete. I've now got to give some though about transporting it to the club site. I've made a scissor lift to get the height right for loading into the back of my car, then I'd thought of a board with angle iron rails to actually get it in. But what about securing the loco. A strap over the top might cause more damage than it would prevent. I'd wondered about a couple of bars through the wheels bolted down to the board. With the present situation there is no activity at the club track so I can't see what other members do. So what do other people do |
Thread: Christmas Cracker Jokes .. and similar |
24/12/2020 13:13:12 |
My most useless Christmas present from last Christmas:
A 2020 wall planner |
Thread: Alternative to 365/office etc. |
15/12/2020 11:49:30 |
I've used Libre Office since retiring (10 years ago). I'm just playing with FreeCAD, a 3D modelling program - open source so free. It will generate G-code so I'm hoping to use it with my CNC mill. It looks very promising but 3D modelling is totally different to 2D drawing. I didn't think much to Libre CAD - not compared to my paid for Windows TurboCAD When I had my own small business I used a very good open source finance program called GnuCash. Oh yes - I'm virtually gone over exclusively to using Linux Mint. I've kept the ability to boot into Windows should I need it - like to use TurboCAD. |
Thread: Drawing Projections |
10/12/2020 11:11:01 |
I agree with PaulM's comments. I must be a similar age to him and have no difficulty with either 1st or 3rd angle (providing you are told what the drawing is in) or metric / imperial. I sometimes use either. If I've measured something and it looks better (more rounded) in inches whereas it would be odd amount in metric I'll use inches. This particularly applies to DIY building jobs where accuracy in not so important so long as it fits. I also avoid cm, never seen the point of them - they only add to the confusion. My mantra for 3rd angle was "What you see - Where you see it". |
09/12/2020 13:16:08 |
08/12/2020 14:20:48 |
q) What do you call a country where everyone drives a red car? a) A red carnation |
Thread: Next issue late? |
04/12/2020 14:08:49 |
The postman has just brought ME 4653 - on time to the day. |
Thread: Compton Series 2000 starter |
03/12/2020 14:42:06 |
Thanks John, unfortunately I've just looked and the Crompton appears to be completely sealed. There are no contacts visible. I would have to dismantle the assembly to get to them. The same applies to the overload unit.
03/12/2020 11:58:58 |
My Myford Super 7 has a Compton Series 2000 starter. Occasionally it doesn't switch on. The contactor jumps but doesn't lock on. If I manually press in the contactor block in (with an insulated screwdriver) it works. Then the starter will work normally for several stop/starts. Is there something I can do or will I have to replace the whole unit?
01/12/2020 15:21:57 |
Posted by Gavin Whitelaw on 01/12/2020 13:42:44:
Well, 1st December and STILL no sign of 4652. The subscription dept has no spare copies so looks like I am going to miss this one. WHAT is the point of a subscription if when a copy goes missing they can't supply a replacement? Also no answer on their FB page to a message left, nor a repy from the Editor when I emailed......They really are NOT good at customer replations. I had that a while back when mine went astray. You would have thought the subscription department would have access to any extras. What about all the ones that will be returned from newsagents. Sales must be very low at the moment. And wasn't the editor having to appeal for recent back issues the other day and offering to buy them. |
Thread: Soldering Iron Tip |
27/11/2020 11:37:31 |
Thanks guys. I'll file it for now and order a new tip. Those old school gas heated irons were well used (and abused !) I remember they used to look like a miniuture axe. I guess modern kids wouldn't have any idea what they were. To think what we were allowed to do in the workshop I'm taking early '60s
27/11/2020 10:54:25 |
My electrical soldering iron tip has become quite worn and I had thought to file it flat, but 'Googling' the subject there are dire warning against doing this. The main one being that it will remove the tip's coating, but surely the tips of the old fashioned irons I used when I was at school that were heated in a gas oven were only chunks of copper, I'm sure they were filed as necessary. So is it OK to file the tip and re-tin it ? It is copper - not plated (well its not magnetic). Peter |
Thread: Centec2 knee adjustment |
26/11/2020 15:07:24 |
Hi. I'm fairly new to the forum so I missed the original posts. I have a Centec 2 that I aquired several years ago with the aim of restoring. The knee adustment on mine is by a pinon operating on a rack inside the knee, This is attached to a shaft that passes right through the head stock and terminates in a taper onto which a handle fits. This all looks original. It would be quite easy to fit a graduated hand wheel in place of the handle. But I do have the much sort after quill feed vertical head. |
