Member postings for Nick Tolhurst
Here is a list of all the postings Nick Tolhurst has made in our forums. Click on a thread name to jump to the thread.
Thread: Centec 2B power feed gears and gearbox internals.
12/04/2020 19:49:48
Just realised also that as well as the diameter of the worm I need to know the number of teeth on the wheel it meshes with as well...sorry !
12/04/2020 19:37:24
Actually having just done a quick calculation on the dimension given on that caliper it turns out the gears are 20DP.
Thats the same as the gears on a Myford gear train. Went out to my workshop to test that out on the one remaining gear I have on the Centec and yes, it's true, it meshes nicely with gears from my Myford ML10 lathe.
Should be able to make some more ratios then maybe ? Worth knowing anyway !
Edited By Nick Tolhurst on 12/04/2020 19:38:16
12/04/2020 18:16:16
Thanks Geoff for the help I've sent you a message and will be posting up photos of what I have shortly.
Thanks also to Gary, terrific photo's, many thanks for them. Do you have a side on photo of those gears to give me a clue of the length of the dog clutch pins ?
Also what;s the overall diameter of that worm wheel ?
Cheers ! Nick.
11/04/2020 18:54:50
Does anyone have a Centec Mill with a power traverse on the table ?
I have a Centec 2B with some parts of the power feed gearbox intact.
However I only have the gear that fits on the leadscrew and the fork that engages with a gear that slides along a shaft to disengage the feed.
I can see from some pictures on the web and from the parts list some of the gears and the number of teeth can be counted. However I need details of the gear that the fork engages with and the worm and wheel that connects to the motor.. I need to know diameters and the number of teeth. Also there appears to be a number of parts that engage wtth the slotted gear on the fork to act as a dog clutch. The details of these parts are not clear.
Also I dont have the plate that encloses the end of the cast box althogh I can probably guess that.
Any details of a suitable motor would be great too as I dont have that either !
I know the originalwas a Brook Gryphon 1/8 horsepower. any ideas for a replacement ?
Any help appreciated.
Cheers Nick.
Thread: CENTEC DIVIDING HEAD
30/03/2020 09:32:58
Fantastic !
Very grateful.
Pity I missed that on Ebay !
Do you have a Centec mill yourself ?
25/03/2020 19:50:40
Hello,
Does anyone have an original Centec dividing head ?
If so, any chance of some nice "square on" photos of it from ech side, front . top and bottom.?
I'd like to make an accurate copy to go with my Centec 2B Mill.
Thanks.
