Here is a list of all the postings Dell has made in our forums. Click on a thread name to jump to the thread.
Thread: Another watchmakers lathe |
18/01/2021 18:10:06 |
Hi all hope everyone staying safe and well i have it all cleaned and painted in 2K ready for rebuilding, but I am unsure what oil to use, with my IME the consensus was to use H32 transmission oil, has anyone any suggestions? Dell |
17/01/2021 15:23:47 |
the lathe is a Derbyshire Magnus 10mm , I found the stamp when I stripped it to get rid of the crap paint job and repaint it . If anyone has any 10mm Derbyshire Magnus collets surplus to requirements they wish to sell please PM me as there are a few missing. many thanks Dell
15/01/2021 08:49:34 |
Hi david I don’t want it ti fit my IME lathe as I am going to sell that I was just wondering if anyone knew what it was. Dell |
14/01/2021 13:06:23 |
14/01/2021 13:05:41 |
Hi Bob there we’re three different collets that came with the lathe and I have tried them for running true and they all run true as far as I can see with my dial gauge ( well very close 0.0025”  thanks Dell |
14/01/2021 09:08:16 |
Hi Nigel thanks for reply I will have a look on site you suggested I have ordered a quick change tool holder set as I can’t be doing with setting tool every tool change, plus I need to find out what fitting for leaver operated tailstock for Jacob chuck. Dell |
13/01/2021 18:46:41 |
i have been looking for a cross slide for my IME watchmakers lathe but it seems they are as rare as rocking horse poo, so I have purchased another watchmakers lathe including cross slide and other parts, some I know what they are for and some I don’t. so If the knowledgeable people on here could help it would be much appreciated, firstly I can’t find a makers name on it although most of the collets measure very close to Derbyshire and the very top of the bed measures 1 and 15/32” or 36.5mm. second the two black and brass poles have two pulley wheels on top of one of them I haven’t a clue what they are for . also land last but not least various other handles and things plus a round knurled ring with two grub screws. many thanks Dell Edited By SillyOldDuffer on 13/01/2021 22:01:13 |
Thread: Just purchased this |
10/11/2020 19:47:20 |
Hi all hope everyone staying safe |
Thread: 5BA Threads |
27/09/2020 08:10:15 |
I have just received some 5BA cheese head steel screws for a french clock, from EKP Supplies £3.50 for 25 they have steel and brass different heads and lengths. Dell |
Thread: Macrome tools |
26/09/2020 18:26:22 |
Thanks for replies the set will only be for cleaning threads in mainly brass clock parts and the occasional replacement screw making , I know the risk in buying second hand but unless you pay big money nowadays or new they are mostly rubbish so I thought for sixty pounds it was worth the risk, It is a full original set in wood box, I also looked at another set but it had bits missing and it didn’t look in as good condition but it was LaL, only time will tell, but I have been in vintage/ classic vehicle restoration for 50 years but had never heard of Macrome before. Dell |
26/09/2020 13:10:05 |
I did a google search but not much came up obviously I asked the wrong question |
26/09/2020 10:53:28 |
Hi all has anyone got any information on Macrome tools, all I can find out is that they were in business around the second ww in possibly Wolverhampton and or Alcester and there is a road in Wolverhampton with same name not sure if road named after company or vice versa, the reason for asking is I have just purchased a BA tap & die set and I am wondering about the quality although vintage tools mostly seem to be good quality and a lot of this sort of thing used to be made for the armed forces thanks Dell |
Thread: What size shaft |
24/06/2020 19:57:13 |
Thanks for that Emgee but I forgot to also ask how long it is so I get the correct one and is it grub screw.? Thanks Dell |
24/06/2020 16:45:33 |
Hi all |
Thread: What lathe tools |
26/04/2020 08:55:48 |
Hi all hope everyone staying safe and well although I am a key worker I am only working two day’s a week so as I have plenty of time I have just started to make some clock parts and screws with my Cowells 90 ME but I am finding that I am not getting a very good finish with brass although I get a better finish on mild steel, I am using HHS tooling and I was wondering if anyone had any suggestions as to what could be wrong, I have tried different speeds, would carbide be any better. any help would be appreciated Dell |
Thread: Rear parting |
02/02/2020 14:18:11 |
Thanks JasonB being new to using a lathe especially one this small it is and will be a steep learning curve, I knew I would have to cut a bit then extend the bit cut then extend again , also I have been looking to see if I could find a different sort of tool so if you have a picture or link that would be great . i haven’t started yet as I want to make everything clear in my thick head before I get going. Many thanks Dell |
02/02/2020 12:41:52 |
The overhang was just to set the height to centre and yes I can use a 1/4” HSS parting tool but some of the things I intend to make are 45mm diameter in brass so an HSS parting tool is not going to cut it ( pun intended ), if I make a wedge to set the tool on a rake would that not work ?. Dell |
02/02/2020 09:04:18 |
01/02/2020 15:26:42 |
Thanks for reply’s I cannot run it backwards as the chuck on a Cowells 90ME is threaded so it would unscrew, and I have sent a email to Cowells. |
01/02/2020 12:03:57 |
Hi all just received rear parting tool from Cowells and upon installing parting tool even with as much packing as I can fit in, the cutting edge ( but on the bottom as it’s upside down) it is still 1.5 to 2 mm lower than the dead centre in tail stock, any suggestions? |
