Here is a list of all the postings Brian Morehen has made in our forums. Click on a thread name to jump to the thread.
Thread: 26 tpi thread |
01/04/2022 20:33:50 |
Almost Certain British standard brass as they are all 26 threads if i remeber right
Regards Bee.M |
Thread: stuff that came with my lathe ... |
23/03/2022 16:41:00 |
I think you must keep everything , Why because the first thing you get rid off you will need it next . Time has told me that because everytime i sell someting I always requre same within a few days . Best Regards Bee>M |
Thread: Need to cut long thin strips of steel (& plastic) - e.g. with an angle grinder? |
18/01/2022 20:15:06 |
Have you looked at a Multi Tool ,I have cut most of the material you have mention using a straigh edge as a guide saw mine in Lidli some time ago and bought , with the right blades well worth the cost has saveded me loads of time . Regards Bee,M |
Thread: Adcock Shipley Bridgeport motor |
16/01/2022 21:21:22 |
If your motor runs o/K at the moment it seems that this is a single phase motor . Your incomeing cable is a metal covered flexible cable and the outer is used for a earth connection but the green wire has also been used for this so it appears that this is wired for single phase use .How many wires are in this incomeing cable? Regards Bee M |
Thread: reversing a single phase motor |
16/01/2022 21:05:11 |
Missed your 5 letter Pleased it is now running o/k Bee .M |
16/01/2022 19:13:00 |
Is this a single phase machine with 3 leads Live Neutral & Earth , Or is this a three phase machine with 3 Live and a earth lead 4 Cables if a neutral is there for a light then ypu may have 5 Leads . Regard Bee.M |
16/01/2022 18:56:52 |
Swapping Your Brown and Blue led roun has only reversed the incomeing polarity on motor. You earthe is blocking the view of motor leads . To reverse the motor you need toreverse the start windings This looks like the Blue and Yellow leads that need to be changed round . The earth lead is restricking view; Bee.M |
Thread: Do you "still" enjoy driving? |
30/12/2021 15:20:46 |
I spent 45 yrs years driving sometimes 1000 plus miles a week as a service engineer repairing Commercial Laundry & Dry Cleaners . Now prefer to drive only to where I want to go. Many pass me and I then finish up behind them at the next set of traffic lights. I am left puzzled at the rush ???
Regards Bee >M |
Thread: Hi from sunny Norfolk (uk) |
29/12/2021 16:23:48 |
Forncett St Mary Steam Museam On my list to visit looks like some Great Engines to View Cheers Bee.M |
Thread: A Merry Christmas to All |
25/12/2021 08:39:31 |
Seasons Greetings to all and all the best for New Year
Bee M |
Thread: Wire |
16/12/2021 13:59:56 |
Looks like Bowden Cable that use to be used for a Brake and Clutch cable in a Sheath on Motor Bikes or anything that requires a control cable , Remember using this to replace brocken cable because it was easier to rethread this in the outer case than to replace the complete cable and sheath complete. Regards Bee>M |
Thread: Metrotropolitan Vicker Single phase motor |
06/12/2021 16:28:08 |
2 slip rings is a puzzle. 3 Slip rings together with 6 Brushes for a large 50hp 3phase star delta motor with a Allen West oil filled starter control that you move the starting handle from start to run yes . 2Slip rings have found this once where there there was a 2 Phase supply on a RAF base. More Details will hopefully provide a answer Bee.M |
Thread: Over 70 Driving Licence Renewal |
30/11/2021 18:40:25 |
I just sent all my paperwork together with a copy of my eye sight test haveing had reaccuring cataracts in both eyes since since my previous renewall 3 years ago . No problem everthing completed new licence arrived within 10 days.
Bee.M |
Thread: Compressor |
24/11/2021 14:16:41 |
Yes most small compressors are noisy and are direct drive , Also a compressor over 50ltr air storage capacity may well require a yearly insurance test certifecate like a Steam Boiler because they are classed as pressure vessels. Good Luck in your search
Bee.M |
Thread: Wonky threads using die |
22/11/2021 18:03:02 |
Die holders seem to have mostly metric sizes BA and small Whit & Bsf that i Have are 15/16 which from memory will only go to 1/4 Whit 5/16 Whit and similar go to a 1. 5/16 Die holder which i think stops at 1/2 whit. I also have some BA Dies that go from 10BA to 4BA that are 9/16 Dia . To get a perfect fit you may have to make small ring to fit your Die to then hold your Die , A poor fit may break your die? I maybe slightly wrong about these sizes as i am reliying on my memory Good luck and time you will win. |
Thread: Motor Gland |
21/11/2021 19:07:49 |
At a guess 3/4 Conduit now Metric which will not match , If a American Motor no match . Continental ,I have found no match, Good Luck Bee.m |
Thread: How to read a micrometer |
21/11/2021 12:59:17 |
Hi Colin use some twist drils if imperial as mike looks a quick check will give you the right answers looks like a good buy Good Luck Bee.B |
Thread: 80th birthday |
20/11/2021 21:01:37 |
Enjoy the day when it arrives I have less than a year to go . I just wish that all the thinks that I have done I could still do on a bench , This way I would be able to repair . Wishfull thinking. Regards Bee.M |
20/11/2021 20:44:31 |
If you have a piece of steel turn this down to the size of your bar about 2" Long then bore a hole that will be a good fit on your 3/16 bar . When you have done this bore a hole in the end the same size as your Die this will then give you a Guide to to keep the whole unit straight .or if you have a larger size die holder thie can be done in the revirse with the held in your die holder and the die in the die holder after you have extented the 3 screws Hope this helps and that it can be understanded I have made this and used many times
Good luck Bee M |
Thread: BA Allen Keys |
19/11/2021 20:12:15 |
have used BA allen screws for years down to 8 BA . AF allen keys have always been correct ,I believe these also been in use be fore Metric appeared
regards Bee,m |
