Member postings for RONALD JACKSON
Here is a list of all the postings RONALD JACKSON has made in our forums. Click on a thread name to jump to the thread.
Thread: coolant pump
01/09/2019 05:32:37
Thank you for your reply
25/08/2019 15:10:11
Have set the Chester coolant system for my Chester db10 at lathe level,the coolant is topped up, pump working, but no coolant. Does the pump need priming ,if so how?
Thread: screw cutting on a chester db10 lathe
25/08/2019 14:55:01
Thanks for your replies and have sorted the gears out
21/08/2019 20:46:44
confused by the instructions in the lathe hand book for setting up the gears on the db10 lathe
