Member postings for Gwilym Box
Here is a list of all the postings Gwilym Box has made in our forums. Click on a thread name to jump to the thread.
Thread: Elliott Jig Borer spare parts
20/06/2019 13:26:55
Steve,
Thanks for all the effort in documenting the handle. I'll study in detail this weekend.
My machine is in pieces and slowly coming back. Just bought a 10 ton press so I can change a bearing, so that will be a task for the weekend.
I'll mock up a part in wood to get a feel on how I'll be able to machine this.
Cheers
Gwilym
18/06/2019 00:57:20
Hi Steve,
That's the handle assembly. I have some measurements taken from photos but it you can take them from the actual casting it would be great.
If you could provide some dimensions for the adjuster rod as well as mine is missing as well.
Thanks
Gwilym
17/06/2019 00:33:10
Hi Steve, thanks for the offer. A picture would be very helpful especially to compare to the Lathes.com photos.
My assumption was that the main feed assembly was cast iron and the actual handle was satin chrome steel with a black plastic ball.
I've used the photos to determine approximate sizes and shapes and will make a wooden template. Once I'm happy with the shape and functionality I have a chuck of cast iron to machine.
Cheers
Gwilym
27/02/2019 21:08:47
Thanks, fabrication was going to be my fallback position. I was aiming for all original parts but having been through a lot of photos, a small block of cast iron and some rod should allow me to produce something very close to the original.
I've stripped the rest of the machine for painting and have dismantled and cleaned head and gear box. Time to put it back together again.
27/02/2019 08:57:04
I'm currently restoring an Elliott Jig Borer MK1 which is missing the automatic feed lever and stop mechanism. Would anyone know of one being broken down or a source of spares?
Thread: Jig Borer in the home workshop
11/12/2018 04:09:05
I've just acquired an Elliott MK1 Jig borer and I need to identify the correct motor frame and foot mount. Would anyone have the correct specification?. The MK2 has a D80 frame but the mounting plate is different to the MK1.
The photo of the Hoover 3 phase is useful but I can't see the model details clearly. Looking at both the NEMA and IEC specs I can't find an exact match to the mounting plate. I'm wondering if the motor mount was something specific to the UK.
