Member postings for john constable
Here is a list of all the postings john constable has made in our forums. Click on a thread name to jump to the thread.
Thread: helical lathe prototype - choice of components
11/09/2018 12:23:10
thanks, Andy.
11/09/2018 12:08:31
No you're not. I havent finished the hardware yet so software comes next.
I think I've decided that I dont need sophisticated tool control of the type needed to carve a design in 3D. I just need basic algorithmic control to move the the tool in and along the work and out again at a certain speed while rotating it slowly.
I think linux cnc is going to be excessive for that. I need something I can write and check my gcode in and if possible a simulator and I need to transfer my gcode to the arduino via usb.
still open to suggestions though.
20/07/2018 19:51:50
thanks martin. Those 5 axis breakout boards you mention - are they usb or parallel?
20/07/2018 17:17:43
wow. I do have an old laptop but I dont think it has a parallel port. I'll have to check.
Would this setup run to 3 steppers?
20/07/2018 17:04:57
did you use a tailstock martin?
20/07/2018 16:48:06
20180719_203006_resized copy.jpgThat's excellent Martin. It'll be exactly what I'm looking for. Although I might use a ball-end cutter for some effects, a point cutting roundover bit will give me a rope twist.
I've gradually been taking delivery of components and its its been my first chance to lay things out. My rotational axis is a rotating table and 4 jaw chuck. I can't remember how many turns per table rotation but its quite a lot so I hope the required torque wont be that much as a direct 1 to 1 ratio. Mind you. the reason I'm making a prototype first is so I can make these kind of mistakes and learn from them.
16/07/2018 14:50:25
I found cncsimulator and its a fantastic free program with lots of tutorials and support. Last night I used it to write my first bit of g-code - yaaaaaaaaaaaaayyyyyyy! I actually cut a thread into the end of a rod on a metal lathe.
The problem is (and I think this might be an issue with all simulators) that my machine design is non-standard so it doesn't simulate properly. CNCsimulator does allow you to create a custom machine but it's a seriously advanced function and I think well beyond me.
15/07/2018 18:35:08
Posted by john constable on 14/07/2018 20:33:59:
Posted by Martin Connelly on 14/07/2018 18:41:02:
The problem of low torque stepper motors is if they get a small kick when a tool cuts a shaving or bit of swarf they can miss steps. Once out of position they keep on merrily moving things around in the wrong position until there is human intervention or the program stops having produced something that is not quite right. You don't get these types of force with 3D printers, there is no high speed tool spinning around.The other thing is you may be underestimating the amount of force needed to push a work piece and tool together for the cutting action to take place. These motors when used with 3D printers are often driving fine threaded studding which gives some mechanical advantage. Is this what you were thinking of using instead of ball screws? They are not used to push a cutting tool into a work piece either. The Gcode for what you want is trivial don't sweat over it but do get suitable equipment for what you propose otherwise you could be wasting money.
Gcode for a barley twist
G01 X0 Y0 Z0 A0 F50 (Move to starting position. Tool over the centre of the work piece at one end and just touching the work piece. Use A=180 for a second start 180° around from the first and add 180 to the A value below ie 360+180=540)
G01 Z-1 F25 (Move the tool down 1mm into the work piece)
G01 X250 A360 F50 (Move the tool 250mm along the work piece whilst rotating the work piece 360°. Change 250mm and 360° to suit your requirements.
G01 Z2 (Lift the tool away from the work piece)
G0 X0 A0 (Rapid move back to X=0
G01 Z-2 F25 (Lower the tool 1mm more than before to do a second cut)
Repeat with decreasing Z until you have got to the depth you want.
Martin C
Thanks, for all that Martin. It's been very useful. It's also my first look at real g-code!
can you recommend a good resource for learning g-code? G-code for dummies?
14/07/2018 20:52:29
Posted by Neil Wyatt on 14/07/2018 20:40:40:
You can disable the temperature settings. Many printers don't have heated beds, and these rigs are often used to make dual head printer/router machines.
Thanks, Neil. So would that reduce the current requirement for a nema 23 low enough for one of these boards to cope?
14/07/2018 20:33:59
Martin C
14/07/2018 20:32:39
OK, I've listened to all the advice regarding 17s vs 23s. I still think my machine's motors will need very little torque - I can't see a router spindle binding when taking a shallow cut in wood for instance. However I came here for the benefit of your advice so I'd be mad to ignore it. I might also be underestimating the torque needed for my xy table which is quite cheap and, my MKII will probably need 23s and I can move them across.
So, can any suggest a driver/controller board kit that will cope with 23s? And can I mix 17s (where I know there is a low torque requirement) or does that get complicated for a novice?
14/07/2018 14:35:38
Posted by XD 351 on 14/07/2018 11:20:16:
Wouldn't it be easier to run a proper cnc controller like mach3 ? It would be seamless with something like fusion 360 cad/ cam which you can get for nothing on startup .
You can buy cheap 4 axis engraver / router units that just need to be connected to a pc running mach3 that may do what you want
I would build the electronics to be able to handle much more powerful motors - even if you don't need them now you may in the future . Nema 17 motors and the ramps controllers/ drivers are pretty gutless at around 2 amps max .
Thanks, XD. I won't be engraving or 3D carving as such. I'm just guiding the tool along a slowly rotating spindle of wood so full cnc control software will be overkill unless i have no choice. That's also why I think 17s will be OK but this is just a lightweight prototype to prove the principle and help me understand how it all works. The MkII can use 23s if necessary.
14/07/2018 14:26:35
Posted by SillyOldDuffer on 14/07/2018 10:09:50:
Posted by john constable on 13/07/2018 22:17:15:
So GRBL is a piece of software - like an OS - that runs on the arduino board and controls the controller board by interpreting gcode that is sent to it by usb from a pc which is running one of many user-written GUIs?
Do the GUIs generate code from instructions you give it or do they convert from a CAD image?
"So GRBL is a piece of software - like an OS - that runs on the arduino board and controls the controller board" - exactly right. It translates G-code commands into the motor steps needed to move a tool or print head to an X,Y,Z coordinate.
grbl will respond to commands typed into a character terminal, this is the best way to test your configuration to prove the motors respond correctly to simple commands. For production work that simplicity gets tedious, hence the GUIs. They do the same job but - once properly set up - are slicker, more helpful and whatever else the designer has thought of.
What the GUI's do varies a bit, but there look to be three levels of sophistication:
  • An improved version of a character terminal, tailored to support 3D, with easier connection.
  • A 'sender', allowing lists of g-code commands to be sent from files, providing access to folders, with buttons allowing grbl to be reset, jog, or otherwise positioned.
  • A 'sender with previewer', these can display the tool-path on screen, allowing the operator to see obvious mistakes before sending them to the machine.
A picture's worth a thousand words, this example is grblgui. (I've not used any of them and can't comment on installation, ease of use, or bugs.)
As far as I can see none of the free GUIs convert from CAD, you either type the code in by hand, or load it from a file. The file is usually created by something else; either a conversion program, or by the drawing package itself. Jason's post shows how Fusion360 does it.
A superficial read suggests OpenSCAD can't produce g-code directly, rather users export the model as a DXF file and run that through a DXF to G-code converter. At this stage it's worth mentioning a potential booby trap! The g-code files needed to print a 3d object are additive, that is the object is built inside-out by depositing layers until the shape is finished. The g-code instructions needed to mill the same 3d object are subtractive, that is the tool removes material from a solid block until the shape is finished, outside in. grbl doesn't care, but it's possible that software written specifically for 3D printing might not support milling and vice-versa. Your lathe is subtractive and the g-code you send to grbl needs to be that way round. It may be necessary to try a few alternatives to find what suits you best.
That's all good news - thanks, Dave. So I still need CAM or CADCAM software. I'll persevere with fusion 360. However, as I only really want to turn rather than carve, I can probably do without the CAD stage. I just really wanted to see what my twists would look like and I've been able to do that in OpenSCAD.
That also means the inside-out issue won't affect me so all looking good so far.
13/07/2018 22:17:15
13/07/2018 19:24:26
It's just too elaborate for what I need. I just need to move the tool about a bit to guide it to cut turned rope twists. I'm just not going to be doing anything sophisticated enough to justify a complex cad image. I'd like to model it in 3d so I can understand the effect of speeds on pitch types and number of spirals on one spindle etc and just get an idea of what it'll look like.
I did these last night in OpenSCAD in less than hour including installation and learning the basics of the software.
13/07/2018 18:35:21
OK - interesting. My strategy to get a kit was that all the components are already selected to work together and as I'm still green that's one less bunch of things to go wrong. However, if I was more confident I would prefer to get them individually.
Sounds like one step and emulation are a safer way to go. I'll look for an emulator so I can start to learn g-code while i'm still building the lathe.
So, is there a way to send your complete G-code to the arduino from the pc without using the sd card?
13/07/2018 17:45:31
both would be good
13/07/2018 16:40:17
Posted by Martin Connelly on 13/07/2018 11:23:51:
It shouldn't be too hard to spoof a few signals to use it as is, my biggest worry would be the torque available from the motors. 3D printing doesn't put much load on a motor so small holding torques don't cause a problem. You may need to up the holding torque by either replacing some of the motors with something beefier or by fitting a planetary gearbox on some of the stepper motors. You will only find out if you need more torque when you have got it all set up and start to cut something. I would work on the basis that as the spindle will not need high rpm for your application there would be no problem putting a 10:1 ratio gearbox on the spindle motor from the off. It may be cheaper than a bigger stepper with its own power supply and driver unit. These motors are 40 N.cm which is the same as 0.4Nm. Since people converting mills and lathes to CNC will be looking at steppers or servos with holding torque up to something like 20Nm you can se where my concern is coming from.
Martin C
Thanks Martin. My machine is scratch built rather than converting something heavier and the capacity is small i.e. maximum 2" x 10" wooden spindle. Nothing needs to whizz around too fast either as the tool movement will be slow like thread cutting on a lathe rather than a gantry router.
So, hopefully nema 17s will be fine....
I'm still trying to understand the whole path of CAD through to driver boards fully.I reckon I can learn to write simple gcode which should be enough for my application and can be put on the SD card but it would be nice to control the tool directly from a window on my pc. Not quite sure how to do that.It would also be useful to emulate the effect of my code on my machine before I commit but I'm not sure how to do that yet either.
12/07/2018 23:36:42
Posted by SillyOldDuffer on 12/07/2018 22:34:58:
Looks like a good way to start John. It already understands G-code (grbl). It also solves the user interface design issues I was wittering about in the other thread because all that is done on a PC. The Arduino gets its instructions off an SD-Card, which keeps that side simple.
My only tiny worry would be unwanted side-effects because it's a 3D printer driver. For instance the firmware might make a fuss if the bed & extrusion heating stuff is left disconnected - the motors might wait forever until a non-existent printing part was up to temperature. Shouldn't be a showstopper - I think it's all open source and hackable.
Edited By SillyOldDuffer on 12/07/2018 22:35:40
is that going to be the same with most of these kits?
11/07/2018 23:45:43
So, after loads of helpful advice I've settled on the following for my project. Its a small tabletop light duty helical turning lathe. Any comments welcome.
https://www.amazon.co.uk/gp/product/B06Y4NYJWN/ref=ox_sc_act_title_3?smid=A16ALI0DJJWDXC&psc=1
https://www.amazon.co.uk/gp/product/B07BB979R4/ref=ox_sc_act_title_4?smid=A281VSOIV3TOD6&psc=1
https://www.amazon.co.uk/gp/product/B071JV158X/ref=ox_sc_act_title_1?smid=A54GFBX2KVQG6&psc=1
https://www.amazon.co.uk/gp/product/B072J97N8T/ref=ox_sc_act_title_3?smid=AR85BMET0MBNK&psc=1
Edited By john constable on 12/07/2018 00:16:44
