Member postings for Ian McVickers
Here is a list of all the postings Ian McVickers has made in our forums. Click on a thread name to jump to the thread.
Thread: What *should* a Warco Super Major Milling Machine be able to accomplish?
19/05/2020 20:05:53
I think your asking a lot of the machine if you want to push it more than 1mm DOC in steel. I had the GH universal and ended up stripping down the headstock and quill and fitting decent bearings to make it quieter. It used to rattle like hell before I did the refurb. Had to use bearing fit on some of the bearings because the recesses were oversize which really doesnt help. Refilled with H32 oil and it definitely improved things. Mine was sat on vibration feet and didnt jump about but was noisy.
Thread: Carbide Insert Designations & Suppliers
09/05/2020 22:56:43
Check out Shop-apt. Always had good service from them.
Thread: Taper Pins
09/05/2020 20:37:47
Someone else may correct me if Im wrong but I think they are started off with a taper drill then reamered if required.
Thread: Should have stayed on the sofa today
09/05/2020 20:33:35
Nice one Phil, have you been watching This Old Tony? Jeff if you can sell it for £1125 Ill give you 50%.
New one made today.
Kiwi Bloke, its amazing what you can come up with when you put your mind to it.
Thread: Stepper Motor Flexible Coupling.
08/05/2020 20:09:31
Hengstler or flexible beam couplings are pretty common so should be easy to find. RS components have then but they are a bit pricey. Zapp Automation might have them.
08/05/2020 20:03:49
Unfortunately my mill doesnt run in reverse. Standard single phase drive.
08/05/2020 19:33:16
Well a while ago I ordered some lathe tool holders from ebay and they arrived and fitted without ant issues so decided to order some more from the same person but they never arrived. Ordered some from someone else and they all got taken to work to be re-machined because none of them were the same dimensions and only one of them fitted the tool post.
Anyway decided from now on to make my own. Machined the lump of steel to the dimension required and cut the slot near to size ready for the dovetails. Dont have a dovetail cutter so decied to make one. Everything was going really well, or so I thought, right up to when I was going to fit it in the mill for a test cut then realised my mistake.
Hopefully I`ll cut the next one the right way.
Thread: Essential and non-essential workers lockdown rules
09/04/2020 15:24:34
Ive been giver a letter from my employer and also told to show my pass as well if I get stopped. But, the company guidance also says that this may not be enough so I have asked what do I do if I get stopped and told to go home? Still waiting on an answer.
Obviously I will be going home if told to but what do you do on the next day you have to go to work? Take the risk of getting stopped again by the same person? I dont think it would go down well.
Hopefully the police will take the view that the covering letter is enough to justify me going to work.
Thread: New design of mains plug?
30/03/2020 17:18:36
That type of plug has been around for a while now. Cant understand why they havent been banned yet. Have a look on fatallyflawed.org.uk They are shown on the first page.
Thread: Manual for Elliott / Victoria / Gate Omnimill 00
28/03/2020 17:33:12
Bill,
is you pm me your email address I can send you the ops manual and the spares manual.
Ian
Thread: What are you doing to stay safe
27/03/2020 19:12:37
I still need to go to work 2 mornings a week and work from home for the rest of Monday to Thursday. Might venture out to the workshop over the weekend.
27/03/2020 19:06:30
Peter,
please check your pm`s.
Thread: Whats App...'Hoax' warning
25/03/2020 10:23:21
Did this thing not appear about 5 or 6 years ago? Pretty sure it was a hoax back then.
25/03/2020 09:24:00
Peter, drop me a pm with your email address and I will send you some info.
Thread: Encryption software
17/02/2020 09:48:33
If you have a samsung phone you can use the secure folder app.
Thread: Welder Inrush Current
12/01/2020 19:59:47
Try a D20. This will supply a higher inrush current.
Thread: Colchester Bantam Lathe
11/01/2020 17:18:11
Emgee the foot bar with an estop is still fitted to the machine so can be hit from anywhere in front of the machine.
11/01/2020 16:18:26
Some photos will help to see whats going on. So the lathe start stop is still operated by the sliding lever on the front of the lathe which operates the built in contactor? Looks like the Clarke inverter does not have any interface for controls at all and just outputs straight power allowing for a contactor to be placed between the inverter and the motor. If this is the case then you could replace the cover and foot pedal switches and an estop switch in the supply line to the contactor but its a bit rough and ready and wouldn't be my preferred option. If your going to keep the lathe it might be worth while changing the motor to a 3 phase 230v and getting a single to three phase vfd to run it. Then you could refit the switches and add any other controls you like in circuit.m-dro panel 1.jpg
This is what I did to mine as the original wiring was crap. I now have all controls in one place.
Thread: What Did You Do Today 2020
10/01/2020 20:44:40
Henry, yes the ballasts were removed. The lamps just needed the supply connected to one end so it made fitting a bit easier as well. Starter not required either.
Thread: Sent lathe back
10/01/2020 18:16:44
Not good that you've had to send it back but at least Warco customer service has sorted out a refund for you. Cant you fit in something a bit bigger like a Colchester Bantam size?
Ausee.com.au
