Here is a list of all the postings Jon Lawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Modern boiler construction methods for the model engineer |
08/04/2022 17:11:38 |
I love this application of modern techniques to our hobby. Brings it into the current age whilst maintaining the spirit of ME. I think I'm a data nerd. When I was younger my cars all had as many gauges as there were things to measure... |
Thread: Material for wheels |
08/04/2022 16:26:24 |
Mild Steel? |
Thread: ER16 Collets from Ebay |
08/04/2022 16:07:59 |
Posted by SillyOldDuffer on 08/04/2022 14:57:46:
Trouble with ebay is it's a market-place, not a single seller..
..and I'm always astonished at how many people forget that. It's like writing off an entire town's shopping precinct because you got stiffed once at the Sunday market.
Thread: Pipe lagging |
05/04/2022 15:35:07 |
I was having a brain fart. I was thinking I'd used it incorrectly as a contraction (as in "Keith Appleton is"
04/04/2022 19:30:25 |
For some reason I can't edit my post to remove the rogue apostrophe.... |
04/04/2022 18:49:42 |
I followed Keith Appleton's advice of string initially held in place with cycanoacrylate, then painted with white (or off-white) enamel. Seems ok. |
Thread: Model Turbines |
04/04/2022 13:52:48 |
I really enjoy these posts, please keep them up. Thanks,
Jon |
Thread: Cutting Carbon Fibre |
03/04/2022 11:31:14 |
How on earth did he snap it! I wonder if the cleaner solution would be to get another piece of carbon fibre and replace the shaft complete? Rods are easily found, used in everything from Model RC Aircrft and and Fishing rods as metioned before. |
Thread: Myford Super 7 at SRS for only £395 |
03/04/2022 11:29:08 |
I personally think it would make for a great article. |
Thread: Rumely Oil Pull engine |
31/03/2022 22:25:25 |
I neglected to say, what a fantastic piece of engineering John.
You mentioned in an earlier post you were thinking about adding castor oil to the fuel, did you do that in the end? Edited By Jon Lawes on 31/03/2022 22:31:35 |
Thread: "Kiv" or Kiev? |
31/03/2022 22:24:34 |
Posted by Bazyle on 31/03/2022 22:16:10:
One of the ones that has annoyed me for a long time is pronouncing the children's book hero Don Quixote as Keeotay rather misses the educational connection with the word quixotic.
But wouldn't deliberately saying it wrong to fit our narrative be worse? Especially as the original is three or four hundred years old and predates any childrens variant of it by a few centuries. |
31/03/2022 20:52:13 |
E5 petrol (the older stuff) is 5% ethanol. E10 (the new stuff) is 10% ethanol. The ethanol isn't a new addition, the quantity has just increased. As a result you may be getting it twice as bad with the new stuff, but it isn't a new problem if the ethanol genuinely is the issue. |
31/03/2022 20:26:06 |
Posted by Tony Pratt 1 on 31/03/2022 15:14:17:
Posted by Calum Galleitch on 31/03/2022 14:17:21:
Posted by Tony Pratt 1 on 31/03/2022 13:39:52:
my views/opinions don't count. Tony, it is not that your views do not count, it is just that yours are not the *only* views that count. Moreover, taking the time to understand the world as other people see it is an enjoyable activity in its own right. I will have to disagree with that one Callum Tony
I'm with Callum. Your opinions do count, but yours have equal value to the other views, and some are struggling to adapt to that. |
Thread: how to make it stay in ? |
29/03/2022 20:56:56 |
Unsprung weight is the enemy, so keep it lightweight! |
Thread: Odd Car Boot Finds? |
29/03/2022 05:08:38 |
Most likely a red herring but I did find this: Visible on the small plate is PATT 5001. I wonder if it is a regulation, manufacturer or similar? EDIT I've since read it most likely means pattern, as in the design something is made too, especially with regards to MoD equipment. They are mentioned in passing here, specifically spark gap condensors, which could make sense.. https://worldradiohistory.com/hd2/IDX-AUSTRALIA/IDX/Amateur-Radio/70s/Amateur-Radio-AU-1970268.pdf Edited By Jon Lawes on 29/03/2022 05:13:48 Edited By Jon Lawes on 29/03/2022 05:16:04 |
28/03/2022 20:28:25 |
https://commons.wikimedia.org/wiki/File:Philips_Stirling_engine.JPG As I understand it the frame formed storage of some of the pressurised gases. Edited By Jon Lawes on 28/03/2022 20:28:45 |
28/03/2022 20:25:49 |
I think Philips donated the generators to schools; I'd love to get my hands on one one day. That is obviously a visual tool to demonstrate the operation. My grandfather made stirling engines intending to use them to power irrigation pumps in africa, but it never came to anything. |
Thread: Tapping straight |
28/03/2022 00:50:04 |
I did laugh at the Kase slice! It has a lovely finish for a workshop tool, I seldom have the patience. Edited By Jon Lawes on 28/03/2022 00:50:42 |
Thread: Using kerosene to clean ground surfaces |
24/03/2022 20:31:27 |
My nefarious purpose is for cleaning off Dykem Blue; after some advice on this forum I purchased Acetone via ebay recently (almost certainly over the going rate). It works very well indeed. Edited By Jon Lawes on 24/03/2022 20:31:47 |
24/03/2022 02:50:02 |
I suspect there will be no difference to the accuracy, but it will make your working environment smelly and is not something you want over your hands any length of time. I believe its a bit of an old school thing in the states to wipe your tools over with it, but there are far nicer, less smelly and less toxic things you could be using. If a film of kero is affecting accuracy then you are working to a much finer tolerance than I!
