Member postings for Stuart Smith 5
Here is a list of all the postings Stuart Smith 5 has made in our forums. Click on a thread name to jump to the thread.
Thread: Muncaster's Simple Entablature Engine
13/11/2019 10:22:29
I ordered a flywheel casting from Lee on eBay on Sunday and it arrived today. Looks good. Flywheel
Thread: Surface Mount Switch
16/10/2019 11:28:14
I live near the CPC warehouse, so buy quite a few things from them .
They have a whole range of boxes and switches. Is this the sort of box you are looking for?:
the range of switches and boxes is at :
I have no connection with the company, just a customer.
Stuart
Thread: PC problem #2
23/09/2019 18:25:46
If your laptop has worked ok up to now and your wife's laptop works ok, it is not likely to be adjacent networks or equipment that is the problem.
The easiest solution is to use a USB wifi adapter. Modern ones are very small and seem to work ok. This avoids the risk of damaging the laptop when taking it apart to try to fix the problem.
Stuart
Usb dongle
Thread: Help choosing a Chinese lathe please
02/09/2019 22:47:22
The machine mart lathe looks expensive in comparison to other brands.
I bought a mini lathe about 18 months ago and spent a long time comparing specs etc.
In the end I bought a CJ18a lathe from Amadeal. It doesn't have the brushless motor of some of the Chester or Warco ones but has a 100mm chuck as standard. It was delivered very quickly. May be worth considering.
Stuart
Thread: ARC Euro Trading Great service
24/08/2019 10:41:07
It's not just ARC. I ordered two items last week , one from Warco and one from Amadeal. Both were ordered late on Wednesday evening and both were despatched on Thursday and arrived on Friday.
Thread: Which Stuart models can be done on a 7x14 lathe with no mill?
24/07/2019 14:43:40
Ben
For information, there is an Amadeal cj18 lathe for sale at the moment in the 'for sale' ads on this forum.
Thread: Need to drill a hole digital caliper
07/06/2019 15:10:03
I had the same problem. I used a tungsten carbide drill bit from this range: - **LINK**
I tried a masonry drill and it did sort of work but not as well as the tungsten carbide bit.
Stuart
Thread: Where is best to buy??
03/06/2019 13:47:40
Macc Models seem to have good prices for small section brass. 1/4 inch brass hex is 90p for 12 inch length, but postage is extra so for a one off piece would probably be more than you paid.
No assocition with the company, but I have bought from them. Quick delivery too.
Thread: Connecting a pair of motor controllers.
03/06/2019 08:50:58
Ron
Does the potentiometer have a switch? If it has 5 wires it could have 3 for the potentiometer and 2 for a switch.
Another Stuart
Thread: Should I have 3 phase supplied to my house?
30/05/2019 11:44:27
A similar question was asked on this thread:
https://www.model-engineer.co.uk/forums/postings.asp?th=138585
some of the comments were incorrect, but you may want to have a read. Some comments were from forum members who have had three phase installed.
You can get a quote for 3 phase by contacting your electricity distribution network operator (DNO). The cost will depend on the location of the nearest suitable 3 phase main cable and the supply capacity you want . If you don't know who your DNO is, you can find out at this website:
Regarding your own internal wiring, a commercial/industrial electrician will be able to quote for the necessary work.
Stuart
Edited By Stuart Smith 5 on 30/05/2019 11:50:23
Thread: Ballscrews?
29/05/2019 11:43:26
Would these be suitable?
Accu
Thread: Waterproof cabinet / box?
15/04/2019 13:57:38
This a drawing of a brick cubicle used for temporary electricity supplies.
Brick cubicle drawing
15/04/2019 13:54:48
I suppose it depends how much you want to spend.
Here are links to 2 suppliers of steel cabinets:
Ritherdon
Glasdon
Or you could make a brick cubicle with a concrete flag as a roof.
Thread: Pendent control box for a VFD
12/04/2019 22:04:06
You might find something suitable here:
they are usually cheaper than rs.
Thread: LED replacement bulbs
09/04/2019 20:39:27
Chris
It may be that your leds can be dimmed if you have dimmable leds and the correct type of dimmer. This is one I bought recently:
Dimmer
specifically advertised for leds.
Thread: miniature 3 pin sockets
27/03/2019 23:39:42
It sounds like Mini Din connectors would be a good choice if they are small enough for your application. Available from 3 pins upwards and with chassis or pcb mounting sockets. I buy connectors from CPC. They are local to me but do quick free delivery. **LINK**
Thread: Making nameplates
13/03/2019 21:57:35
The etched brass in my previous post is 28mm diameter.
13/03/2019 21:55:48
I etched this after using pressnpeel sheet with the design printed using a laser printer.
I heated the brass in the oven and then pressed it onto the sheet.
I used Sodium persulphate from CPC as the etchant. It is clear so is easier to see what's happening than ferric chloride. It works best at 50 deg c.
etched brass
13/03/2019 21:04:57
You could try Pressnpeel. It is a blue sheet that you print onto using a laser printer or photocopier. You then iron onto your brass sheet and when peeled back it leaves the black resist for etching.
I have used it for producing PCBs but recently made a couple of etched patterns onto brass for wood brands. I didn't manage to etch very deep, but deep enough I would think for a loco nameplate. I intend to use this technique to produce nameplates for my 16mm scale loco.
Thread: Metal Cutting Power Saw
11/03/2019 22:53:48
Ron
The Evolution Rage saw has a TCT toothed multipurpose blade not an abrasive one. I have a Fury saw which also has a TCT toothed blade. I have used it mainly for wood but have cut 1" square section steel with it. I have had it for about 4 years and it still cuts ok with the original blade, although I have cut steel a few times. I bought it after a demo in my local B&Q where they cut steel and aluminium.
Stuart
