Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: I think its sold
28/01/2022 14:47:05
Posted by br on 28/01/2022 14:40:49:
Frustrating .
Take the time to answer a FOR SALE advert only to be told -- I think its sold.
But if it is not, I will let you and other interested parties know.
Others ??
Been there done that TWICE. I wish members would remove the ad promptly once an item is sold.
regards
Thread: skip find box of slot drills
24/01/2022 11:36:55
Some may need a sharpen but no harm done giving them a try. Even if the tips are shot the flutes may be ok. I would say a good find. These are the kind of things I like to find as the HSS itself is still useful as lathe tooling when attacked with a bench grinder.
regards
Thread: Scheppach Bandsaw Portable
23/01/2022 10:21:38
Drill a 8.1mm hole through a length of 20mm or so square/round bar set that in the jaws and push your rod through as required. You could drill & tap through the guide for a clamp screw if you feel one is required.
regards
Thread: Wire wicks
23/01/2022 10:05:10
Posted by Paul Lousick on 23/01/2022 07:27:57:
I did a couple of other experiments to test some of the theories that were posted.
Lifting by capillary action and syphoning.
I suspect the syphon is broken because the two wire examples touch the container lip. It isn't broken in the multi-strand wicks because the outer threads are lifted over the edge. If so, the single wires might work if they were held by a firm base that hooked them clean over the lip.
Possibly the viscosity, weight and how well the oil sticks to the wire matter too. Could be a lighter oil on a different surface would be OK
My test does not use a tube on the inside of the oil pot and I don't believe it is a syphon action that lifts the oil. On some large engines the tube is 1/8"-1/4" diameter and 2"-3" high and open to air at the top. Somehow, the oil has to be raised by the wick on the outside of the tube
The test below has the wicks held at the base and hooked over the lip without touching the cup. The 1st is solid copper wire, the second plain steel with no coating on its surface and the 3rd is multi strand copper wire (from electrical cable).
Lighter (hydraulic) oil was used this time for the test and each wire coated with it to wet its surface.
Sfter 12 hours nothing happened.
In this test the first wick used a solid steel wire wrapped tightly with wool yarn..
We don't have worsted wool in Australia and I used a local lambs wool knitting yarn. ( Worsted is a high-quality type of wool yarn. It is named after the small English village of Worstead, in the county of Norfolk)
The second wick is one strand of the copper electrical wire, bent in half to make a small loop and twisted together. The wool passed thru the loop and roughly wound around the twisted copper wire. (this is how I make wicks for our full size traction engines)
Both of these transfered a similar amount of oil.
I believe the wire wicks work better when the free end is not touching the base and the oil allowed to drop off the end. This allows for a better pull by the wicked oil. Also the wick needs to be wetted at the start of the cycle so the run off starts the syphon action.
regards
Edited By Oldiron on 23/01/2022 10:06:56
Thread: New highway code rule.
22/01/2022 22:39:04
Exited as soon as the Yahoo logo appeared.
regards
Thread: Lathe change gears vs gearbox
21/01/2022 13:07:03
I would vote for the Boxford AUD (as I have one). Whichever lathe you choose make sure it comes with the possibility to cut metric and Imperial threads. For example you need a 100/127 gear ( or a variation of) for an Imperial Boxford to cut metric threads. Also if you go for the AUD make sure you get the change gears that should be with it. Not sure on the Myford but plenty of members can point you in the right direction.
regards
Thread: Help need with Traction Talk
19/01/2022 10:02:23
I tried to view a couple of posts on TT this morning and was greeted by the following message.
regards
vBulletin Message
PLEASE NOTE: You Now Need to Be a Signed Up Member to View Posts on Traction-Talk
Edited By Oldiron on 19/01/2022 10:02:46
Thread: Wire wicks
18/01/2022 18:19:17
Posted by duncan webster on 18/01/2022 13:35:15:
Posted by Paul Lousick on 17/01/2022 21:46:34:
Does a bare wire work as a wick ???? I have my doubts.
There's no point saying it doesn't work, it plainly does, what we need to know is how. Capillary rise doesn't need a tube.
I am given to understand that once the wire is wetted surface tension drags the oil down the wire. A bit like pulling a string the end will always follow. regards
Thread: 1st milling with the ZAY7045 Milling machine-Question
18/01/2022 17:58:59
Although my lathe has got a flood coolant system on it I generally use a squirty bottle when needed as the flood makes far tooo much mess. Same on the mills unless using a big face cutter then I use mist coolant. I got fed up with wet floor, bench etc with flood coolant. On Ali I use a WD40 squirty bottle.
regards
Thread: Wire wicks
17/01/2022 21:35:39
I have a very old stationary engine of unknown make that has wire wick oilers. As it is a non runner I have never tried them but they looked original so left them as is. If it had been a runner I may have thought "what idiot put those in" and changed them to cord. We live and learn. I subscribe to Robs channel and he does expel quite a few myths on brazing, casting and a few other things.  He also builds engines from scratch.
regards
Edited By Oldiron on 17/01/2022 21:36:28
Thread: Calculator App
16/01/2022 16:49:54
Derek. Have a look here Calculators Not a perfect answer but these calculators will satisfy most needs.
regards
Thread: Three phase reversing
16/01/2022 11:14:18
Posted by Steviegtr on 15/01/2022 21:55:27:
Old mart. Take a look at this youtube video. Indian i think reversing a huge lathe while threading.
Steve.
Reversing a large lathe while threading.
Egyptian Steviegtr. He is speaking some vernacular dialect of Arabic
regards
Thread: Bearingboys Ltd Excellent Service
15/01/2022 11:26:33
Ordered SKF 6201 bearings on Friday14th @ 14.30 & delivered by my postman @ 10.45 this morning. I selected 5 day free delivery as I was in no hurry for them, Excellent service from them. Its the first time I have used them but they will be my goto bearing supplier from now on. No connection to them.
www.bearingboys.co.uk sales@bearingboys.co.uk
regards
Thread: To start the discussion
15/01/2022 09:41:28
Posted by Zan on 14/01/2022 12:54:49:
I’d like to look at this, but don’t like the cookies. Too many
Just go to manage cookies and turn as many on or off as you wish.
I imagine there are no more cookies on that site than on the many you visit everyday.
These cookies have been there for a long time it is only lately that sites have to tell you which cookies they have by law.
Also set cookie preferences to delete at PC shut down.
regards
Thread: Midlands Model Engineering Exhibition 2022
14/01/2022 12:02:09
Will be going if its on. Keeping an eye on their website.
regards
Thread: My next project
13/01/2022 16:16:03
Neil, The protractor in your picture above or something very similar is on my to do list ( steal idea) for the cutter head tilt.
A little update. I machined the spindle of the head down and made a sleeve for it to enable me to try my Stevenson ER32 block as a temporary measure. I was going to use a Cutwell long shank ER32 holder but it has a 10mm hole up the centre. This brings some difficulties when trying to fit the dial and handle to it. So thats on the back burner for now. When I need to do flute sharpening I will revisit this part.
The rectangular mounting block for the head on the compound overhung each side of the swivel by 0.040" so milled it down so there was only 0.005" overhang. This will make it easier to fix the hinge plates when I get them done.
Am now working out the dimensions for the hinge plates that will be fitted to the sides of the block and be swivelled from the compound. I will try to incorporate some kind of protractor similar to one in Neils post.
The compound is not quite as well made as it first appeared. Nothing was square and looked if it had been sawcut and filed to shape. The block on the top was out by about 3 degrees so I had to sort that out. Now it is all square I can get on. I mounted the head to make sure I had enough clearance to sharpen cutters up to 16mm.
A few pictures follow.
regards
Thread: That Strange Calculator Again
13/01/2022 15:15:30
I have trawled through my countless calculator books and have come up with nothing. Also spent many hours on the internet since the first post and nothing found. As a collector of Mechanical calculators and slide rules I will be very interested to know its origins & usage.
regards
Thread: Milling machine, but which brand ?
12/01/2022 17:02:37
Many many posts on here about that subject. Try a search. It will bring many answers.
regards
Thread: Resurrecting an old model
12/01/2022 16:57:20
I tried that many moons ago, it took me ages to get her up and walking again. devil
Thread: Royal Fail
12/01/2022 16:52:47
Posted by JA on 12/01/2022 14:58:15:
I think these postings are a year old.
JA
With the speed of some peoples internet you may be correct that they have just arrived. devil
MIDLNDS GARDEN RAIL Jan 2022
JD Metals
rapid Direct
