Here is a list of all the postings Garry Martin 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: brass needed |
10/07/2019 17:40:58 |
does anyone have or know where I could get a piece of brass cz121 75mm dia x 20mm thick from that does not cost more than the clock I have bought could be 75 x 75 square 20mm thick Edited By Garry Martin 1 on 10/07/2019 17:42:13 |
Thread: Myford lubricated with grease |
20/02/2018 23:54:40 |
undo the nipples and clean out as much as you can the purge with the correct oil |
Thread: myford motor |
28/11/2017 18:39:23 |
yahoo sorted someones been in the back of motor and wired the terminals up wrong it should be AZ-A Z-T mine is AZ-T and A-Z so as soon as I realised that wired up accordingly bingo now got reverse happy days
Thread: empty drill case |
18/11/2017 17:39:22 |
Jason £ 16-76 don't know if vat added but eBay got one at 15-00 free postage at moment full so as you say might be better getting that and using the drills for DIY and restock with tin coated one we use at work |
18/11/2017 17:36:30 |
thought someone might have one kicking around with a lot of drills missing ect ect |
18/11/2017 17:35:52 |
Anthony I thought about that but was going to use ally just looks a lot better in a case |
18/11/2017 17:07:26 |
JasonB you are the man |
18/11/2017 16:51:27 |
good afternoon all does anyone know where I can get a empty imperial drill case that will take 31 drills from 1/64" to 1/2" I have spent all afternoon searching Clarke do a complete, set but I can get drill free and as many as I want so only need the case hope someone can help getting fed up with them all in a box and trying to find the right one.
Thread: myford feet bolt dimention |
05/11/2017 15:30:52 |
can somebody tell me what the sizes are for the feet on a myford super seven to be bolted down on the base ie what is the size from front to back and side to side hole centres are need to get it bolted down and working getting ichy fingers |
08/06/2017 10:17:24 |
Still cant get it to go in reverse brother is a top sparky at this type of thing and he is scratching his head time to take motor apart I think |
Thread: brass wanted |
08/06/2017 08:33:27 |
where can I get a piece of brass 85mm dia x 19mm long have tried everywhere to no avail |
25/05/2017 15:06:06 |
hi all I have been given a myford super 7 lathe it has a Crompton Parkinson motor and a Dewhurst rotary switch my problem is I cannot get it to go in reverse switch is wired up right and have power to both windings goes forward but not reverse tried every thing pulling hair out now grrrr any ideas why it wont go into reverse ?
Thread: hi |
24/05/2017 17:29:57 |
hi I am a new member and would like to say hello to everyone I have just been give a myford super 7 lathe and would like to get the best out of it so does anyone have a users manual for one will to pay
