Member postings for Pete Rimmer
Here is a list of all the postings Pete Rimmer has made in our forums. Click on a thread name to jump to the thread.
Thread: Bright EN24T steel vs Black EN24T for cutting gears
10/10/2019 11:34:39
My small hobber cuts conventionally, no facility for climbing.
Thread: Grinding wheel 'washers'
08/10/2019 14:07:35
Posted by Cornish Jack on 08/10/2019 09:12:32:
Thank you all again.
From all the advice given, I'm concerned about the compressiblity of the cardboard I had intended to use. As I said, it's just a standard piece of a cardboard box and doesn't have the less compressible qualities of e.g. gasket material - maybe I'm over-worrying!
rgds
Bill
I think you are Bill. All of the wheels I have in my workshop have simple paper blotters. Not much give in them at all.
Thread: At last - no more chattering when parting off!
07/10/2019 08:50:00
That's nearly as bad as that idiot Steve Jordan's idea of lapping lathe slides by hand - and then having to put two locking screws on his compound when he's realised that he's ruined it, and called that an 'upgrade' too.
Thread: Any geologists out there?
06/10/2019 17:00:23
It's an early bullet proof vest left over from the dino-wars. The fact that it's so full of holes and that there are no dinosaurs left are evidence that the early vests weren't very effective....
Thread: Closet Machinist
05/10/2019 20:51:53
Hi Mark,
The Bantam is a fine machine, yours seems to be a 1600 which will have come with 2 speed 3 phase motor. If you have no 3 phase supply into your workshop that might be a minor stumbling block but not difficult to overcome.
I had a Bantam and I found that the two-pedestal style of support made it possible to put significant twist in the lathe bed just from having it stand on slightly uneven floor. When you have cleaned it up and decided where you will stand it, be sure to research how to 'level the bed' so you can fix it down nice and straight.
Thread: Good practice for lathe circuit design
05/10/2019 00:02:28
I see no good reason for needing an isolator switch where there's a plug and a NVR switch. The NVR switch will turn the machine off, and not allow it to turn on automatically should there be a supply interruption. The plug is the isolator.
Thread: What motor pulley size for ML1 Lathe?
04/10/2019 12:26:17
Yes you can. That was standard fitment on the South Bend 9 and 10 inch machines.
The countershafts used in the underdrive models followed the design of that for the 9-inch where a V-belt from the motor passed over a narrow flat pulley on the countershaft, a system confusing to modern eyes but one that works well in practice.
04/10/2019 11:56:51
Michael makes a great suggestion. Poly-vee belts run very well on flat pulleys and you need a surprisingly small one to get the same traction as a larger flat belt. Some south bend lathes even run a vee belt on the flat pulley as standard.
Thread: Leadscrew material ?
02/10/2019 10:22:19
I like EN8DN for screws. it's free-machining EN8.
Edited By Pete Rimmer on 02/10/2019 10:24:15
Thread: Turning between centres on Super 7
01/10/2019 12:07:26
Posted by ega on 01/10/2019 09:46:08:
Posted by Mike Poole on 01/10/2019 08:32:24:
The chisels are spring loaded and do mark the end face where they bite into the job, sometimes you see the little marks left on the end of a component. They are often used for grinding but they are also used for turning. There are videos on YouTube.
Is the centre also sprung so as to take care of the work expanding?
And is there a hobby market for these commercial devices?
If the centre was sprung then the part could be ejected under cutting load. The driving teeth are the sprung parts.
C.J. - if you're worried about the length of the driving pin, make a extended driving pin with a fat base and just turn the end that engages the slot in the dog smaller.
Edited By Pete Rimmer on 01/10/2019 12:09:44
Thread: Vickers Bl 8 inch Howitzer cannon of 1917
22/09/2019 11:28:50
I was just relaxing here watching an episode of War Factories on the Yesterday channel (S1 E6 if anyone is interested) and about 20 mins in there's a momentary footage of a guy in a French factory who appeared to be hand finishing the cutout on an internal breech block thread with a large file or something similar..
Thread: Thread form for Atlas 1 1/2" X 8 lathe spindle.
21/09/2019 18:50:25
1-1/2" 10TPI on an Atlas is bound to be UNS. Can't see any USA lathe manufacturer specifying a Whitworth thread back in the 1930's/40's.
Thread: Brown & Sharpe 2L surface grinder - drive gear teeth pitch?
21/09/2019 00:59:49
The pressure angle doesn't matter one jot if you're replacing the rack and the gear.
If the rack is only broken in the one spot and the budget was tight I would cut that rack right at the broken part then grind the two ends so that they ended right in the bottom of the tooth valley, then flip two two halves round so they meet in the middle. Pin and bolt the two bits in place and buy or make a new gear. if the travel is lumpy over the join then shim or grind it to suit.
I'd offer to cut the gear for you but I can't do 10DP on my hobber.
Thread: Surface plates
20/09/2019 16:35:47
All of the people who have been guests at my workshop to learn a bit about scraping have had a revelation when they saw just how little bearing their cross slide actually had on a flat way, and how easy it was to fix. An easily made scraper, some blue and a small surface plate can improve things a huge amount, for just a few hours work.
20/09/2019 11:45:21
You can't use length and diagonal measurements for checking the squareness of surface plate corners to the tolerances that surface plates are supposed to be good for. Taping corners would get you at best ten thou, plates are flat are square to ten thousandths (100,000x less). If you're going to use such a crude method you might as well check a bench corner.
If I wanted to check the squareness of the corners I would stand the surface plate on a long edge on top of a larger surface plate and use a DTI on a surface gauge to make comparative measurements against the opposing vertical ends. If those measurements match then both corners are square to the 'bottom' edge. If I didn't have a larger plate to stand the test piece on I would put a box square against one edge and run a surface gauge along the square face and check the measured face for parallelism to the box square. That would let you prove each or any corner individually.
Edited By Pete Rimmer on 20/09/2019 11:46:03
18/09/2019 12:41:54
You can expect it, or you can inspect it. Only one of those can you trust.
Thread: Denford viceroy
15/09/2019 23:31:09
Removing the small nuts will release the bed from the cabinet IIRC the studs poke through the larger 'nuts'. If it's an underdrive model you'll still have the belt to think of and if it's a 280VS or Synchro there will be some electrics to take care of too before the bed will come off. Interlock switches, lo-volt light etc.
Thread: Thread Size Help
15/09/2019 23:14:32
If you can single point that small cut a 3/32"-40tpi thread in silver steel, harden, grind 3 sides to make a tap then use the tap to make a nut. Cut the same thread in your part.
Thread: Need help with meddling pillar drill.
15/09/2019 11:40:47
I would suspect the extension lead first even given the test results.Several times at work I have tested leads which showed voltage at the socket but only had a few whiskers of conductor connected at the plug or socket so could not run the machine they were supplying.
Plug something else into the lead which has a fairly heavy draw, like a vacuum cleaner or heavy portable tool.
That will confirm for sure that the lead is not at fault.
Thread: ACME thread identification question.
14/09/2019 23:05:57
Posted by S.D.L. on 14/09/2019 22:04:13:
Posted by Pete Rimmer on 14/09/2019 21:44:44:
I guess you'd need to find an ex-employee from the factory for that, or a drawing.
BTW I had an Denford TDS1 and the cross slide thread on that was clearly cut (or at least finished) with a die. The marks where the die stopped were plain to see.
How are you sure it was a die? Threads cut with an Anjest attachment have a run out like a die as do modern CNC threads no need for an undercut with either.
Steve
I'm not sure, just how it appeared to me. I figured if it was done with an auto knock-off device then the marks would be right at the end of the thread. This appeared to be cut further along then finished slightly short of the end. I only mention it as a matter of interest really.
EngineDIY
