Member postings for Matthew Davenhill
Here is a list of all the postings Matthew Davenhill has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarkson Auto lock - 3 ish questions!!
19/05/2020 13:12:15
Gents thanks for the advice, this far I’ve created two albums and added one photo! However it won’t do anymore, not sure why!
19/05/2020 11:24:16
19/05/2020 09:36:45
19/05/2020 09:36:06
Just a couple of more photos of the large chuck
19/05/2020 09:34:10
19/05/2020 09:33:01
I was given an old clarkson autolock MT3 that has stamped on the side of it type c c’. it came with the below
the collets with nibs on are type c, can anyone tell me what the half crescent Collets are?
i think this is what’s classed as miniature chuck; however I didn’t know they did them with c collets? Am I correct in my assumption?
now on to the 3rd is question.
I’m waiting for the below to be delivered, very reasonable price. It has no collets and is described as very large, I think it’s a large autolock S. Can anyone confirm and will it take all S collets,
Thread: Bridgeport quill feed gear box
29/04/2020 13:59:12
Not sure if that makes sense, I can try and get some close ups
29/04/2020 13:58:36
28/04/2020 09:56:12
Hi
I’m rebuilding a 2J head Bridgeport, I’m re assembling the quill feed gear box, each gear is held in place by a brass bearing and two set screws. When I tighten the set screws to nipping up level of tight( any of them) the gear box seizes up. Has anyone else come across this?
It is worth noting the gears seem to tighten ever so slightly at certain positions normally.
regards
matt
Thread: Assessing machine wear
27/08/2018 10:32:55
point
hi all,
A straightt forward question I hope! I’m stripping a Bridgeport and it’s seen a shift or two! On each of the machines ways there seems to be what I assume are machined datum surfaces either side of the dove tail. So for the question ! How do I assess the wear and what kit do I need?
Thread: Bridgeport
29/05/2018 21:56:31
Some indication of wear, can see some remnants of scraping on the rear slide, thanks for the advice both.
David- I think I have a copy in pdf format, also have the lion industries book. Don’t really want to scrap it, more because I’m not sure where to start!
28/05/2018 22:47:18
Hi
I’m in the process of stripping and cleaning a Bridgeport j2, all works but showing a fair amount of wear. Other than scrapping or re scraping the ways, any advice on working with worn machines?
Thread: Tool grinding
04/06/2017 08:34:03
looking at buying a new grinder, has any one found a better way of doing it that a traditional two wheel grinder? I.e. Something like this. http://www.screwfix.com/p/scheppach-tiger2000s-200mm-whetstone-sharpening-honing-machine-230v/40540
In addition has anyone found a rest that you can set the angle on for sale, I know there are lots of DIY designs out there, or found a bench grinder with a system or the angle already marked?
Thread: 3 jaw chuck run out after machining
30/05/2017 21:56:12
Tipped tool ,about 3 thou cut an inch from the chuck
30/05/2017 21:48:22
This is the reading on the freshly machines surface, any thoughts on the cause? The mounting surfaces are clean.
30/05/2017 19:37:23
Hi,
I'm in the process of commissioning my lathe, when I place a dti on a machined length of bright bar which has been turned in a 3 jaw, I get around 0.02mm run out on the machined surface. Does this sound acceptable?
Edited By Matthew Davenhill on 30/05/2017 19:38:30
Thread: Accuracy of an old machine
30/05/2017 19:31:56
Thanks for the input, it turns out a gasket I had installed on the saddle was too thick and was removing clearance out of the leadscrew, it was slightly rubbing the lead screw and causing it to lift the saddle and alter the cut
02/05/2017 09:45:28
I've checked headstock play in accordance with the Lang manual, initially I put a piece of bar in the chuck and used a length of wood against the ways to lift; however, Lang recommend an end load test of 200lbs from which you determine play with a DTI. I've don't this and it shows 1 thou which is within the tollerence allowed by Lang.
01/05/2017 22:23:55
All,
Thanks for the advice thus far, in response to one of the comments, I have the manual from lathes.co.uk. I've done a little more work, unsupported the machine cuts parallel for around 75mm but the suddenly cuts a .05mm taper towards the headstock over the remaining 75mm. (I.e. The dia of the work piece reduces) I did wonder about bed wear but surely it would do the opposite? It has been mentioned that the headstock could be out of alignment, I'm a little sceptical my self. I've put a new gasket between the saddle and the carriage, I did wonder if that could be causing issues. Any thoughts ??
Matt
24/04/2017 22:48:24
To test for play in the bearings it states the following in the below photo, any idea where I can get a 200lb spring
