Member postings for Jim Nic
Here is a list of all the postings Jim Nic has made in our forums. Click on a thread name to jump to the thread.
Thread: The Workshop Progress Thread 2019
13/10/2019 14:23:40
Lovely little engine Jason. What's next, a Midget twin?
Jim
07/10/2019 12:44:47
Hi Geoff
Thanks for that descriptive post.
I am not well versed in how to approach castings, only 2 of my 10 completed engnes have used them so your guidance will be valuable indeed.
Jim
01/10/2019 14:44:54
I have made a start on Muncaster’s Double Acting Oscillating engine.
First off I gathered some bits of metal:
Then, since I hadn't figured out how to go about any other parts I made the flywheel, which still needs a bit of car body filler around the spoke ends to add a bit more realism.
Then I took delivery of the engine frames from Model Engineer’s Laser.
I had these lasered because I’m getting lazy in my old’ish age and could easily see me messing up forming the bowed feature halfway up and having to make more than one attempt.
Now I'm going to have to get my thinking head on and tackle the cylinder.
Jim
Edited By Jim Nic on 01/10/2019 14:51:51
Thread: Norden mill engine
02/09/2019 14:20:50
From your photo it's plain to see the problem at the top of the guides, what's it like at the bottom? If the crosshead has 1/4 of an inch to go before the bottom of the bars the problem could be in the length between the centres of the connecting rod. If the crosshead goes too far down as well as too far up then I would be looking at the throw on the crank.
Jim
Edited By Jim Nic on 02/09/2019 14:21:38
30/08/2019 14:42:41
Thanks for the kind comments gents.
A little bit of a mod to do on my Grasshopper Beam engine pipework then its on to the next project - a Muncaster designed Double Acting Oscillator using the cylinder casting kindly given to me by Geoff Walker. This engine will present me with its own challenges as I am not good with castings having only used them on a Stuart Models 10V and my Grasshopper Beam (which did not turn out well with several of the castings being discarded after my attempts on them!). I have the barstock materials on order, the cylinder casting and some drawings so I'm committed now.
Jim
28/08/2019 14:04:00
At long last I have completed Stew Hart’s Overcrank engine. I knew when I started that it was a step up from anything I’d done before but thanks to Stew’s excellent drawings (which I believe were not originally drawn with publication in mind) and a bit of thought and common model engineering sense the result is shown below.
And a vid:
It has taken the best part of a year but I’m pleased with it. Thanks to Stew for the drawings.
Jim
Thread: Digital inclinometers
18/08/2019 11:59:07
My Wixey Model WR365 is 9 years old. It uses 2 off AAA batteries which last for years, I think I've replaced them just once. The display can be turned off by holding down the "On/zero" button rather than wait for it to get fed up and turn off itself. The display has 2 readings: a level setting and a reading which can be zeroed to your own datum (eg machine bed) and reads from there.
When I need an angular indication I find it simple and quick to use and plenty accurate enough for my modelling purposes.
Jim
Thread: WM16B mill
07/08/2019 20:49:10
I also have a WM 16 to which I also fitted magnetic DRO from M-DRO.
The X axis scale is fitted to the front of the table utilising the channel provided for the table stops; I made some extra screws to secure the magnetic track backing. I also fitted a piece of aluminium angle to prevent swarf falling in to the minimal gap between the read head and the track
The read head is on the bracket originally provided for the table stop.
The downside is that I now have no table stops but I haven't really missed this facility, I just use the DRO to tell me when I've gone too far.
I made a bracket for the Y axis read head and mounted it on 2 tapped holes in the table carriage and I mounted the track using 4 tapped holes I put in the machine base.
The installation works well and has done for 6 years now.
Jim
04/08/2019 19:36:35
A good looking modification Nigel , well done.
Jim
Thread: It's not engineering but
01/08/2019 10:12:11
That's lovely Eric. Mrs Jim says can she make us one in 12" to the foot?
Jim
Thread: double acting oscillating cylinder engine
31/07/2019 11:29:13
A very good looking engine, Geoff. Nicely finished and it runs well too. I am enthused to get my current project finished and set to on the casting for this engine you kindly sent me.
Jim
Thread: Laser cutting service
29/07/2019 18:36:14
Model Engineers Laser did some parts for me not so long ago working from a paper drawing (actually a PDF of a paper drawing) at a very reasonable price. Quality was excellent and I didn't have to wait too long to get them. A very good chap to deal with.
Jim
Thread: not tightening
27/07/2019 20:04:41
What is it that won't tighten - is it that the nut won't run down the thread?
If the engine was running and then the shaft turned in the split crank it suggests to me that the split is closing fully before the crank grips the shaft. In which case make the split wider.
Jim
Thread: Lathe tooling
22/07/2019 10:29:13
When I bought my Warco lathe (admittedly a while ago) it came complete with a set of indexable cutters which as you would expect fitted perfectly without the need for shimming and have served me well for 9 years.
Are you sure you need to be buying cutting tools?
Jim
Thread: Fitting moving steadies
21/07/2019 20:04:39
Hi Allison, welcome to the forum.
I'm afraid I have no knowledge of your lathe but on my Warco machine the travelling steady attaches to the top of the saddle to the left of the topslide. The attachment is by 2 bolts, one to the front and one at the back. The necessary holes have screw in blanks fitted.
Hopefully this may give you a clue where to look or someone with real info will be along shortly.
Jim
16/07/2019 17:50:48
That's cheating George. (Says I with tongue firmly in cheek having had these parts laser cut myself.)
You certainly got a good looking result which has probably saved you a whole lot of tedious work with fretsaw and file.
Jim
12/07/2019 19:28:37
George?? Just between youand me, it's you Geoff.
Jim
12/07/2019 14:03:50
Nice bit of woodwork George.
Cladding cylinders in wood where appropriate adds a lot to a model for me.
Jim
28/06/2019 15:15:16
I like the slide lock George. I'll be making one of them soon.
Jim
26/06/2019 14:23:52
Well I've now received Muncaster's book "Model Stationary Engines" via Amazon.
As Jason pointed out the book doesn't contain a full drawing set, just the diagrams posted by Geoff at the top of this thread. I am now in a quandary: try and make the engine from the limited information in the book using bar stock, try and make the engine from the limited information in the book but to Geoff's metric conversion factor and using the cast cylinder he has kindly offerred me or try and make the engine at a larger size from Julius de Waal drawings using bar stock.
More coffee and cogitation required I think.
Geoff, I have sent you a PM
Jim
Ausee.com.au
