Here is a list of all the postings Dick H has made in our forums. Click on a thread name to jump to the thread.
Thread: Walter dividing head |
02/12/2020 21:01:00 |
In German but with photos. https://forum.zerspanungsbude.net/viewtopic.php?t=11546 Hope this helps. Search under Walter Teilapparat. |
Thread: Pivot Steel |
06/11/2020 21:51:51 |
Just use silver steel and harden the ends afterwards, blue pivot steel can be a pig to work. Which version of the JW 8 Day Wall Clock are you working from? |
Thread: PC unable to read PNY flash card |
05/11/2020 21:57:05 |
Does the USB stick show in Disk Management? I forget how to get to it in Win 7. Resist all requests to format something! It might be something as simple as the USB disk not having a name or a letter (H:,J: etc),. In disk management look for a disk with the right size. Google USB, Win 7 and Disk Management. I´ve had one of these but it was a while ago. |
Thread: Soluble hard varnish that sticks tightly to metal? |
03/11/2020 11:31:15 |
How about polystyrene (eg. CD case) or a bit of Lego (colourful ABS) dissolved in acetone to make a paint? Use acetone again to remove. How hard are you abrading it? |
Thread: Optimum products? |
18/10/2020 19:57:14 |
I´ve got one of their bandsaws, it works and you can get spares here. Else it looks like many other offerings. The first think it did was to eat the rubber tyres that drove the blade. Dick.
Thread: Troubleshooting Instructions |
18/10/2020 19:52:27 |
Press any key to continue. Where´s the "Any Key"? If is was you I wouldn´t have started from here |
Thread: Proxxon collet size? |
23/08/2020 16:12:56 |
Just to give the pot a stir, I looked at a German Proxxon dealer´s site and they sell a set of ER20 collets for the FF400 for machines with a serial number beyond 401-10910 manufactured after 05/ 2012. Before then I think they used the Proxxon style collets with slits from the front face. Around 2012 the ER20 collets became the norm, hence the confusion. See https://www.fluidonline.de/proxxon-24304-81-ersatz-spannzange-12mm-fuer-ff400-pf400_3629_4029. Dick. |
22/08/2020 22:29:51 |
Look at the annular slot that locks into the tightening nut , then you understand how it works. |
22/08/2020 22:06:31 |
I think the Proxxon collets are a special design, you have to engage the collet in the nut before you tighten it in the spindle. Conversely if it doesn´t disengage on loosening you have to jiggle it a bit until you can remove it from the tightening nut. I hope this is clear but I don´t know the correct terms to describe this. I have a Proxxon FF230 (notmy choice) and I know if the collet is not properly engaged it will move in use. |
Thread: What Did You Do Today 2020 |
11/08/2020 17:22:12 |
See this one on fleabay.de "Sehr schöne dekorative antike Uhrmacher Drehbank Messing auf einem Holzsockel"it could be its twin but with the rest,. |
Thread: Assistance in identifying material composition of some wire |
16/07/2020 23:18:44 |
Maybe a nickel alloy. Have a look at Espacenet patents search and put in Metcal and browse the results. |
Thread: Nivellator |
15/07/2020 22:38:41 |
See patented by Otto Paul in 1926. https://worldwide.espacenet.com/patent/search/family/007386036/publication/DE479442C?q=%20wasserwaage |
Thread: Another mystery tool |
17/06/2020 19:19:31 |
How about using it to decide whether the upper surfaces of two plates/ or railway tracks are level before welding / tightening a joint? |
Thread: Can summer car tyres be used in winter? |
17/06/2020 10:29:33 |
In Germany people swap from summer to winter tyres end of October / early November. The winter tyres have a grippier profile and lots of little ribs like slits or vanes in the tread pattern which are supposed to pump more water as well. The ADAC (the German equivalent of the AA ) publishes tests on summer and winter tyres (https://www.adac.de/rund-ums-fahrzeug/tests/reifen/) every year rating the tyres for grip, braking performance, noise and fuel economy. I do so miss the daily commute, every November when we got the first dusting of snow you would find those who still had the summer tyres on creeping along in the slow lane. If you don´t have the appropriate tyres on there´s a fine and a point on your licence. |
Thread: 3D CAD software - what do you use? |
18/05/2020 18:26:12 |
Try TinkerCad. For creating simple solids and assembling blocks and putting holes in them to create an .stl file it does what I want for 3D printing. |
Thread: Identify plastic glue |
16/05/2020 15:32:20 |
A fish in the internet suggests the tank is made of polycarbonate. The dispenser shown on the web is is for a two component syringe with a static mixer nozzle attached. Epoxy might do the job but you might never get it apart again. I would have guessed it was a clear two component addition (platinum) curing RTV silicone. Shouldn´t attack the polycarbonate. Anything with a solvent in, is a no go. A clear sanitary silicone would probably do the job. Put a blob somewhere out of sight and see if you can get if off again. However I had a look at this German site (https://www.poolpowershop.de/waterrower/glue-kit) and it helpfully has the supplier details of what they are selling for the job. It turns out to be an electronics grade; unfilled, room temperature fast curing; two- Dick.
Thread: Cheese grater strip/band |
12/05/2020 21:37:21 |
Try "perforiertes Blech" or Lochblech. (perforated sheet). |
Thread: Ideal Extruder Temperature for PLA |
06/05/2020 22:52:22 |
There are things (tower shapes with bridges) for this in Thingiverse, search calibration and pla. The problem is to get the printer to print different parts at different temperatures, so as far as I can see you have to import their g-code and run it, i.e. no stl and slicing. I run at 210°C and 65 °C bed. |
Thread: Clarkson Autolock Mystery Tool |
06/05/2020 16:22:50 |
MichaelG. Try pr = gb19690030371. pr is priority. |
06/05/2020 10:38:34 |
Searching patents is a bit of an art. Transposing application no.s, i.e. getting the application no. into the right format for Espacenet is tricky, older Japanese documents with emperor years as dates, US serial codes that cover several years. Espacenet will accept wildcards but you have to specify the field. Often it is a problem to pad out the number with the correct no of leading zeroes. You also have to know whether it is a priority or a straight application no. A good start point is to have a look at the publication data on the front page of a published application or patent and try and make sense of the various numbers and then try and find the document again using other tags (priority instead of application or publication no.) |
