Member postings for David George 1
Here is a list of all the postings David George 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Watching for long enough.......
24/05/2019 20:05:30
Hi welcome to the forum not to far from you down the A38. Loads of info on here you just have to ask.
David
Thread: Threading plastics
24/05/2019 06:51:52
Hi Chris what is the coil for will the coil get hot or warm in use? Have you thought of using tufnol you can get it in tube sections it is machinable and an insulator.
David
Thread: sieg mill: normal chuck or collet chuck?
23/05/2019 08:46:43
Hi Ace drill chucks are not recomended for milling and I would always use a collet set to hold a cutter. You are likely to find that the cutter moves if held in a drill chuck and it may push back or pull out to ruin your job. You will also have to have a vice and clamps for holding the work piece. Talk to ARC they have some starter sets unless you gave some equipment already.
David
Thread: Hello
20/05/2019 19:48:43
Hi Philip welcome to the forum. It helps to say where your locality is so local supliers etc can be suggested. Being an ex motorcyclist what bikes have you worked on. I had a Matchless 650 twin then a Triumph 500 tiger before racing a 500 Suzuki based Dresda, a FEW years ago.
David
Thread: Equipment required
19/05/2019 07:32:45
Hi i see that you havn't had a reply but i can't help as i don't know about locomotives but I would have thought that you could find out what diamiter the larger parts are and find a lathe which is capable to turn it. But don't restrict yourself as the next job will probably need a larger lathe etc you can turn small parts on a larger lathe but not always the reverse. I would buy what you can afford and as good as you can get.
David
Thread: Where can I get a 2 step pulley
16/05/2019 13:32:11
Hi Grant I made one for my M Type here is a copy of the sketch. It is the one for the motor to drive the counter shaft made of aluminium.
David
Edited By David George 1 on 16/05/2019 13:32:56
Thread: Green Grit Wheel
16/05/2019 07:12:04
Hi Nick the first thing I did when getting my grinder was to change the rough standared wheel to a silicon carbide wheel as if you use brazed on carbide tools and boring bars you will need one. I use the fine wheel for HSS tool and drill grinding.
David
Thread: Long time reader, newly joined
16/05/2019 07:05:24
Hi DC welcome to the forum. What are you interested in and where are you based as it helps to suggest local supliers etc.
David
Thread: Shipping to USA
14/05/2019 20:11:12
Hi Matt The rules for shipping go America are terrible and even the wood and packing materials must be to regular US standard. Any oil and coolant etc must be removed and certified clean. Get an agent to prevent it being impounded and or returned.
David
Thread: fobco drill
14/05/2019 17:53:02
I have had to repair a similar problem with a Fobco bench drill it had been used in a toolroom to drill graphite and the graphite was abrasive so that the clamp wouldn't lock but the and of the ring closed when tightened. I just had a larger slot cut with a wider slitting wheel to allow it to clamp.
David
Thread: Quick change tool post for myford mtype 31/2" long bed
13/05/2019 18:03:20
Hi I have fitted a Dickens type bought from Myford. Here is picture and sketch of my mod.
David
Thread: Result - the 2019 Stevenson Trophy
12/05/2019 21:50:35
Congratulations Mike
David
10/05/2019 19:59:16
Any news or results
Thread: Drummond type m
09/05/2019 17:53:26
Hi Dan There is a mod to fit an extra thrust bearing just behind the chuck location and into the bronze bearing. The bearing is a roller thrust bearing with two hardened washers and fits perfectly into the space there now. It gives more support to the spindle and reduce chatter. I bought mine from Simply Bearings NTA1625 Needle Roller Cage Thrust Assembly with 2 TRA1625 Washers 1.00x1.562x0.1381 inch (NTA1625-TRA1625) = £6.41
David
Thread: Fobco Star Modifications
09/05/2019 13:30:20
Hi Phil The floor standing one has a solid column and a wind up mechanism for raiseing and lowering the table. It would have to be bolted to the floor or a substantial plate fastened to the floor of a wooden floor. You could make a new spindle with a Morse taper, they were available on some models.
David
Thread: Sump Plug
09/05/2019 10:46:39
Ian Did you get the sump plug out !
David
09/05/2019 09:55:27
Hi Dan welcome to the forum. I have an M type like you and there are quite a few mods and bits I have done to ny lathe they ard in my albums for you to look at. I have bought a few parts from Keith Robinson in shefield you can try him. I will send a personal message with his details.
David
Thread: fly cutter or face mill
08/05/2019 21:33:55
Hi Martin this is the fly cutter that I use it has a solid tungsten carbide piece as the actual cutter.
It has a 12mm diamiter shank and a 25mm diamiter body with a grub screw to hold the carbide in an angled hole easy to make. If you like I have a spare carbide piece you could have to make your own. You can run it at a fast speed and get a lovely finish and little or no wear on the cutter. Send me a PM if you want me to send the carbide.
David
Thread: Soft Solder v Silver Solder
08/05/2019 13:12:12
Lead solder is only banned from plumbing for potable water.
David
Thread: Mastiff
08/05/2019 13:09:31
Have you any pictures? Please.
David
Ausee.com.au
TRANSWAVE Converters
