Here is a list of all the postings David George 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: My version of Potty Mill engine |
11/04/2021 22:12:50 |
Hi Jim the box is an exhaust with the outlet on the end. I have drilled the exhaust outlets on the top and cross drilled to end. Not tried it out yet and have some finishing to do on edges and corners as well as lube bits and pieces then clean up the flywheel casting. I probably will paint it red. David
11/04/2021 20:13:29 |
Just finnished the valve section and eccentric and done a first assembly. I have changed a few bits to my liking to give it a bit more strength.
David
Thread: Bandsaw - wood and metal ? |
11/04/2021 11:49:38 |
Hi Gerry I think you would be much better of with a horizontal type band saw than a vertical saw. You can get a horizontal saw which can be configured to be used as a vertical saw and that gives you options. If you were to try and cut a 5 inch diamiter bar on a vertical saw it would be challenging but thin plate is better on a vertical saw. I have a small horizontal saw from Chester machine tools and a vertical saw from Machine Mart and I use the horizontal saw most of the time but the vertical saw is used to cut wood, plastics, and non-ferrous metals and eavan with the correct blade is useless for steel etc. David |
Thread: How do I remove this small bearing? And the one behind it. |
09/04/2021 08:48:01 |
Hi pgrbff what is the casting part off and is the hole blind or is there a through hole from the back. A couple of diferent angle pictures may help. David |
Thread: Anti seize grease on Myford spindle nose? |
07/04/2021 08:02:38 |
When I go to have a service on my caravan there is a specified torque which is checked with a torque wrench to show that the nuts are correctly tightened whilst I watch. The data in the spec for these bolts are dry not lubricated. When I replace my chuck on to the nose of my M Type Drummond/ Myford lathe I give it a wipe with a slightly oily cloth. David |
Thread: Recommended suppliers and services |
07/04/2021 07:52:49 |
A few places to get services and tooling. Firstly JB cutting tools ( Jenny) http://www.jbcuttingtools.com for turning and milling tools. Secondly, bed regrinding and repairs etc Unislide grinding http://www.unislidegrinding.co.uk/lathes/ Thirdly, Tuffsaws for band saw blades for any saw or made to measure. https://www.tuffsaws.co.uk/. Fourthly, Rotagrip http://www.rotagriponline.com for chucks jaws and other tooling is a great resource for information as well. Another place for screws bolts threads etc is Spalding fasteners metric, imperial small and large sizes. https://www.spaldingfasteners.co.uk/about-us/ David |
Thread: Milling Vice Location |
05/04/2021 23:00:41 |
Hi I always put my vice to one end of the table. I swap it around and use either end and leave space for my rotary table or angle plate. I used to machine Bridgeport beds for Bridgeport and as the way that they were roughed out aged and then finnished they never bend. David |
Thread: strange 240v pump 'switching' |
04/04/2021 12:04:35 |
It sounds like there is some corrosion or resistance to spinning and that is causing a thermal switch in the motor body to cut out. Look at the spindles and bearings and for any foreign body's behind the pump blades etc. As it cools down the motor will start again till it overheats and trip out etc. David |
Thread: Steel type(s) used in mnfr of Hydraulic Cylinder shafts |
01/04/2021 08:02:57 |
I used to make piston rods for mining roof supports and the ones we made used 80M46 Carbon Steel a medium carbon steel which was machinable, ground nice for pre chroming. David |
Thread: Think you have trouble losing your chuck key? |
31/03/2021 19:27:18 |
Here's my 4 jaw chuck not quite as hard as a self centering 3 jaw. David
Thread: Buffing and Polishing |
30/03/2021 12:11:57 |
Hi Alan I set up a small polishing machine made from a small grinder from Lidl. The mops I use are from Cromwell tools as a kit . It includes three diferent grades of buffing compound and three mops for each grade. When polishing it depends on what you are polishing and the detail etc. It is a very dusty and dirty so you should be prepared for dust extraction, goggles and catching escapee parts. I quite often Finnish with Solvol Autosol metal polish to Finnish with as well. The Lidl grinder is just big enough for me for the small parts and cutlery that I polish. I had to make a new pair of wheel washers to allow them to grip the mop correctly.
David
Thread: Component Suppliers - Recommendations? |
30/03/2021 11:55:30 |
Try www.component-shop.co.uk you can phone them as well 01248719353 north Wales. David |
Thread: Myford dividing kit |
29/03/2021 07:24:30 |
Have you looked on here http://www.myford-lathes.com/accessories6.html don't know anything about them but they don't look cheap. David |
Thread: Replacement Chuck for Hobbymat MD65 |
28/03/2021 07:49:58 |
Hi Keith is the original chuck mounted by studs screwed into the body of the chuck or has it a back plate which is screwed onto the back of the chuck with the studs in that plate. If the Chuck has a back plate you should be able to buy one from most places but check the sizes off location diamiter etc. If the chuck has studs screwed into the body of the chuck you will have to make a back adaptor plate to allow it to mount a new chuck unless you can buy a second hand original chuck. David |
Thread: Steel Rule Graduations Re-Blacking |
26/03/2021 22:12:33 |
I used to fill lettering etc on labels for tooling pre engraved I used paint sticks from RS components. Paint over engraving let to dry and clean off with a solvent damped cloth. I had red black and yellow. Edding Black 10mm Broad Tip Paint Marker Pen for use with Metal David Edited By David George 1 on 26/03/2021 22:21:30 |
Thread: Chester mill spares amazing |
24/03/2021 06:46:28 |
Hi Peter just found your question and it looks like you have all the questions answered already. The head on my mill is just held on by two bolts and a nut, make sure the T bolt is not lost. On the table I would unscrew the end plate, two screws, with the handwheel and wind out the leadscrew before sliding out the bed, you are less likely to damage the leadscrew. You may have to slacken the gib strips if the table dosn't slide out. Take boxes and plastic bags for screws etc and label where they came from. Take a set of combination spanners. Socket set and Allen keys as well as a set of flat and cross head screwdrivers. Hope the M Type is working ok my lathe is turning out pieces ok. Take a picture before dismantling or removing wires is always a good idea. David Edited By David George 1 on 24/03/2021 07:07:31 |
Thread: Tea Spoons |
23/03/2021 12:48:57 |
I had a similar problem with spoons but they had been cleaned with a scouring pad to remove staining. Do I had a great idea when I saw a small bench grinder in Aldy with the guards removed and a polishing mop from Cromwell tools it pleased SWMBO and they looked like new. Note the before and after. David Edited By David George 1 on 23/03/2021 13:00:31 |
Thread: Cleaning up BSW threads |
21/03/2021 08:17:48 |
Hi pgrbff In you case you would mostly use plug taps to clean out threads in holes and nuts and I would have thought standard type and second hand would work in most cases. The only place where you would have to use a first taper tap is if the hole needs plugging and 're tapping from solid. David |
Thread: 3-Jaw Chuck not running true - how to fix |
21/03/2021 08:02:46 |
I bought a 4 jaw self centering chuck with jaws that were mixed up and didnt match the body but we're numbered 1 to 4 with diferent set numbers. It was cheap at the Doncaster show. I mounted it up on a new back plate and with a test piece there was about 0.65 mm run out and needed grinding. I made a set of holders for the jaws, a four hole cloverleaf plate for the inside grinding and a set of rings for the outside faces. After grinding the run out was less than 0.02 mm. You have to load the jaws in the direction of his they are used and direction of clamped. I borrowed a toolpost grinder from a friend and ground both inside and outside faces on the jaws. David
Edited By David George 1 on 21/03/2021 08:05:10 |
Thread: 12V Motor for a Top Slide Drilling Attachment |
19/03/2021 08:14:24 |
This is the toolpost spindle I made for my M Type Myford lathe. It has a 12 volt DC motor and a combined power supply with speed controler. David |
