Member postings for Keith Rogers 2
Here is a list of all the postings Keith Rogers 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Merry Christmas Everybody!
25/12/2019 11:36:03
Merry Christmas to you all and a happy and healthy new year.
Keith
Thread: 3D printer recommendations
08/12/2019 12:38:09
I took delivery of my Ender 3 on Thursday and like Pete Rimmer found it required a 0.5mm shim behind the motor mount to align the Z axis screw. I also adjusted the Y axis carriage wheels slightly to alleviate some slight play, apart from that it went together very easily with some care to set everything square. All in all a very good machine for the money, I'm very happy with the quality of the prints and look forward to many happy hours playing with it.
Keith.
Thread: Harrison M300 or M250 pulley/belts problem
09/08/2019 13:52:59
Michael.
No. I haven't done this on your model, but I have come across this method of fitting gears and pulleys many times on various machines in the past.
NDIY.
I don't think anybody has suggested Michael hammers directly on the shaft with a steel hammer !
Keith.
09/08/2019 13:15:17
You wont be hitting it hard enought to do any damage. ( at least I hope you wont ! ) they should enter with a light tap.
Keith
09/08/2019 13:05:34
Michael, I wouldn't worry about the roll pins at this stage, if it all comes apart as I think it will you should be able to tap the roll pins back in with a soft drift. Even a mild steel drift would not damage them as they should be hardened. I doubt you will need new ones unless you damage them in some way, but I can't see that happening!
Keith.
09/08/2019 12:40:17
Michael, have you got or can you borrow a puller large enough to fit the pulley?
If you can, fit that and push on the partially unscrewed centre bolt, I think you will find
the pulley will slide off the shaft. Don't worry about the cap it will come off with the pulley.
You may find you have to replace the bolt with a longer one to get the pulley to clear the end of the shaft.
Keith.
Thread: bearing research
27/07/2019 13:43:46
Try Simply Bearings
https://simplybearings.co.uk/shop
If you can't find the bearings listed try phoning them 01942-269-837
I have always found them extremely helpful.
Keith.
Thread: Threads used on electrical brass fittings
19/07/2019 14:07:29
Back in the day when I repaired chandeliers and light fittings I came across all sorts of threads.
Most fitting tended to be Brass thread , 9/16 x 26 BSB is 14.2mm OD so as Jason says is a very likely candidate.
Electrical conduit threads are based on american national pipe pitches, so 1/4 NPT would be .540" OD (close to 14mm ) but is 18t.p.i which sounds a bit coarse for the OP.
Later fittings were mostly Metric, again as Jason says 1mm pitch being common. Alth'o being from the US I would think that less likely.
Keith.
p.s. Sorry for the acronyms devil
Thread: TTFN
19/07/2019 12:20:17
Hi Andrew,
I can only echo all that has been said.
It just proves what a nice friendly group the majority are here on the forum, it's a shame it has to be spoilt by the views of one individual.
I do hope you will reconsider, the forum will be all the worse without your input.
If not, maybe I'll see you at Forncett some time.
Best regards,
Keith
Thread: Colchester Bantam lathe lead screw
26/06/2019 10:37:33
Pence.
My imperial Bantam leadscrew is 4tpi.
Keith.
Thread: Myford Lathe on Ebay
11/03/2019 12:06:28
Posted by JasonB on 11/03/2019 11:27:59:
Personally I also prefer not to get links to sales elsewhere but Neil would have final say.
You never know if people are posting just to promote items they have for sale or are just being "helpful" though making an item known to a wider public does not help the chap who found an item that nobody else was interested in. one of the other ME forums had a period where lots of e-bay items were being posted and pulled to bits by "those in the know" which got very boring and does not help sellers and puts buyers off what may have been perfectly reasonable items.
If someone is looking for an item on the forum and you happen to have seen something that may be of interest to them then a quick PM can be used to let them have a link.
+1 to that Jason.
Keith
Thread: Filling defects in slideways
13/02/2019 11:46:02
That looks like useful stuff.
Downside is it has to be heat hardened at 425F for one hour.
Not easy with a lathe bed smiley
Keith
Thread: Thick walled copper tube
12/02/2019 22:31:11
Hi guys.
Thanks for all the replies, most helpful.
At the moment it's a toss-up between JB's idea or increasing to 3/16.
Unfortunately Duncan there is no space between the boiler and the cladding on the Tich, I don't think LBSC believed in insulation sad.
Thanks again .
Keith
11/02/2019 13:58:31
Hi, I,m currently helping a friend progress with building a Tich loco he started 40yrs ago. We are close to assembling his boiler parts but have got stuck trying to source some thick walled (5/32 OD x aprox 1/16 ID) copper tube for the hollow stay. I can find some 22g but as this has to be threaded 5/32x40 it only leaves 12thou at the root -- not good for a boiler stay
I know it was available 'cos I have it in my own Tich boiler (which was not built by me)
Any suggestions where I might get some would be much appreciated.
Keith.
Thread: Learning CAD with Alibre Atom3D
13/01/2019 11:54:08
Neil, as Nylon 6 is hygroscopic would that really work as a steam turbine? I guess it would be fine if run on air though.
Keith.
Edited By Keith Rogers 2 on 13/01/2019 11:54:52
24/12/2018 23:40:53
Merry Christmas everyone and a happy and peaceful New Year.
Regards, Keith.
Thread: 26th Model Engineers' Day at the Forncett Steam Museum
28/09/2018 13:39:45
Does that mean you're not going this year Andrew?
Keith
Thread: Facing Error
15/08/2018 19:12:25
_______Need to double-check, but the absence of error when cutting parallel (tbc) suggests that the headstock and ways are true making the cross-slide chief suspect.
SOD, Do I get the impression you are turning your test bar between centres (as in tbc above) in which case it wont tell you if the headstock is out of square only if the tailstock is in line with the headstock.
Keith
15/08/2018 17:15:03
My bet's still on headstock misalignment thinking.
Keith.
15/08/2018 11:17:11
Please forgive me if i've missed something as i have only skimmed through these posts, but
I don't recall seeing anyone mention to check that the headstock is correctly aligned to the bed.
If there is any misalignment it would surely face either concave or convex. Perhaps it's worth checking?
Keith.
