Member postings for Mark Gould 1
Here is a list of all the postings Mark Gould 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Aircraft radio scanner
14/07/2019 18:25:46
Bob, I would suggest looking online at a pilots shop or something. Aviation is generally done in VHF. Frequencies used start at 118.0 Mhz and go up to 135,9 Mhz. If you want ti listen to mil traffic a UHF receiver would be advised. VHF transmissions are line of site and both the aircraft and ATC will be broadcasting with enough power to go 250 miles. Thats generally the limit, depending on the altitude, with ground control frequencies generally have a slightly lower output,
Mark
Thread: Stuart No. 1 Build Progress
11/07/2019 15:19:31
Posted by Glyn Davies on 11/07/2019 11:19:23:
I find the way to happiness with a four jaw chuck is to use two chuck keys. Tighten one whilst slackening the other. I made a second key for my 6 inch four jaw chuck that was small enough to use at the motor side of the chuck.
That's a good idea, Glyn, I'll try that thanks. I suppose it lets you see the change 'on the fly" so to speak.
11/07/2019 15:00:49
Ok Loctite and pin it is then! Thanks for the advice gents. I will have a look at those sewing machine LED;s, Lainchy, many thanks.
11/07/2019 07:02:01
My dad and i got a bit more done on the Stuart yesterday. We have basically completed the crankshaft but still have to decide how to join it all together. This engine won't be powering a boat or anything and will probably only run on compressed air for short periods. Perhaps Loctite is good enough or otherwise pinning the crankshaft with taper pins. Anyway here are some quick photo's of everything loosely joined.
Thread: Bridgeport
09/06/2019 08:55:59
I am green with envy. That Bridgeport looks fantastic. I would love to own one, one day. Enjoy!
Thread: How often do you oil your lathe ways?
06/06/2019 10:24:45
Posted by Neil Wyatt on 01/06/2019 22:54:38:
Do other folks slather on neat oil like I do?
I'm more likely to worry about it pooling up on the ways than them looking dry!
I do too Neil, I actually enjoy cleaning the machines!
06/06/2019 10:22:09
Posted by Hopper on 01/06/2019 00:46:40:
Beginning and ending of every session of use.
Beginning for lubrication. Ending for corrosion prevention.
Edited By Hopper on 01/06/2019 01:01:41
Thats how I do it too. Leave them wet (ish). Helps me sleep better.
Thread: Myford boring bar help
31/05/2019 09:05:45
Ok thanks for the replies. I will give it another look.
30/05/2019 22:06:31
Gents,
I recently bought a boring bar from Myford. It runs between centres and I was planning to bore the cylinder on our Stuart steam engine with it. It comes with some tiny cutters but I am not sure how it works. The bar itself has 2 holes drilled (both smooth, no threads in either) and these 2 holes are perpendicular to each other. The cutters fit very nicely in the holes with no discernable play but slide in and out without much effort.
My question is how are the cutters fixed in the bar?
Mark
30/05/2019 22:00:20
Got another bit done. It's not perfect but I am happy with it. Somehow (I have no idea how) I messed up one of the inside dimensions so I might have to run this part with a thin bushing on either side. It took us hours and hours and getting the damn thing to run nicely in a 4 jaw chuck is a black art not mastered by me.
20/04/2019 16:29:06
Got a bit more done. The con rod bearing and the slide valve. The con rod bearing is actually 2 parts super glued together for the machining. They turned out nice although this gun metal is very “bitey” to drill into!
Thread: Lathe Carriage Stop
05/04/2019 13:14:18
Nice looking stop Justin, reminds me of another project I keep putting off!
05/04/2019 09:44:04
Almost completed the next component. This also took quite a lot of time as we kept having to take it out, measure, put it back, find zero etc. It still needs a general deburring but the fit in the standard is excellent.
Thread: from a 3.5 inch Gezina to 5 inch tramway Plettenberg locomotive
21/03/2019 08:55:31
Looks great Werner, I look forward to seeing more!
20/03/2019 17:34:58
Progress is slow. The workshop is at my folks place which is 50km from me and with work in the way our days spent machining have been few and far between. I hope to step it up a bit soon.
Today we finished machining a simple but time consuming bit. Not even sure what it's called but it still needs a bit of light filing and sanding but the basic shape is there. It takes a lot of time if you're a newbie and this took quite a while! It tapers by 2mm from end to end, not clear on the pics.
Edited By Mark Gould 1 on 20/03/2019 17:35:59
Thread: Older/cheaper lathes
10/03/2019 08:43:50
I live in the Netherlands and Myfords often go for €1000 here. Funny, we are only seperated but a timy bit of water.
If you are interested look on www.marktplaats.nl
Thread: Myford cross slide backlash
20/02/2019 13:36:25
Amazed at the responses, all welcome and informing. Many thanks for that and it will take a while before everything is clear to me. I am unschooled in metal works and am learning on the fly. This forum and ahum, youtube.
I understand that it won't change the backlash, thanks Martin and JohnF. My understanding on how it works was flawed but it is slowly becoming clearer now.
I use inserts tooling (all 10mm due to tool centre height). Some Chinese cheapy inserts, others are known brand (Sandvik, Mitsubishi) DCMT and CCMT inserts.
The bar was 300mm to start with, the finished shaft is about 230mm.
I was turning at 640rpm.
@ega, I found the illustration when Googling "Myford Super 7 cross slide friction" and came across it on another board. I am not sure who's illustration it is, sorry. I will look into that book and dito washer!
Thanks again gents,
Mark
20/02/2019 08:50:20
Gents,
I turned a shaft down for a machine that needed one. The long main section (20mm dia) had some irregularities in the finish, almost as if the set up wasn't rigid enough.
I started looking at the cross slide in more detail and stuck a DTI (referenced from the lathe bed) and discovered about 0.06mm in and out movement on the cross slide. By that I mean movement to and from the operator so perpendicular to the bed.
We started paying with the adjusting collar on the cross slide spindle (see pic).
Now for the newbie questions:
1. Is this collar to remove backlash and make the in and out positioning of the cross slide more consistent?
2. Am I right in concluding that this collar, if not correctly fastened will result in the cutting tool being pushed back the same distance as the backlash in the screw?
3. If I tighten this collar and remove almost all of the above mentioned 0.06mm I cannot turn the crossfeed handle at all. Is the trick making a compromise between ease of operation and trying to eliminate backlash?
Sorry for the questions, this new hobby and taken me hook, line and sinker
Mark
Thread: Another newbie question!
19/02/2019 21:04:46
Thanks for the very helpful replies gents. Using the steady seems a good idea. I think I was perhaps trying to cut the corner a little bit and gain some time. Thanks again for taking the time to help,
Mark
19/02/2019 10:41:00
Thanks for the replies. The stock was 300mm, so sticking out a fair bit from the 100mm 3 jaw chuck. I will use a DTI to ensure the stock is as centered as I can get it and go from there. An increase in speed is a good idea Al, I will try that too.
Thanks again,
Mark
