Member postings for Mark Gould 1
Here is a list of all the postings Mark Gould 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: How to use a round column mill
01/11/2019 08:57:55
Graham, that looks like a fantastic spndle lock on your FB-2. Do you still have any drawings for it? It’s one of the less popular things on this otherwise great little mill and together with powerfeed on Z the only thing I would like to add. If you have anything left and don’t mind me copying your design I would love to make that addition.
Thread: Fortis lathes
24/10/2019 21:16:56
Hello Vic,
Welcome to the forum from another newbie, have you checked www.lathes.co.uk ? That is probably the mother lode when it comes to lathe info.
Hope this helps,
Mark
Thread: Stuart No. 1 Build Progress
16/10/2019 12:37:26
I would great appreciate any help in rotating these photo's. If the moderators have any tips I'm listening.
Thanks,
Mark
We have also done the top and bottom cylinder covers (what a joy a PCD function is on a milling machine!)
Edited By JasonB on 16/10/2019 16:36:44
Edited By JasonB on 16/10/2019 16:38:57
Thread: Telescopic bore gauges
15/10/2019 23:20:24
I too bought a set of Chinese telescopic bore gauges and found them horrible. They came in a blue plastic wallet thingy (on Banggood). I have thrown them away and bought a second hand set of Mitutoyo's on Ebay.
15/10/2019 23:01:57
We have been whittling away at the Stuart and are getting there. We have completed the steam chest and cylinder.
Thread: S50 Conrod test
29/09/2019 14:57:00
Looks beautiful, well done. Is the shank tapered?
Thread: Complete newbie question - RC car from scratch
19/09/2019 09:28:07
I had never heard of a tether car either and was amazed by what I saw after Googling them!
Thread: Any interesting lathe projects for beginners?
17/09/2019 15:31:24
What about a Kentucky-do-nothing?
http://www.homemetalshopclub.org/news/14/kentucky_do-nothing.pdf
Edited By Mark Gould 1 on 17/09/2019 15:32:47
Thread: Lubrication
15/09/2019 05:34:41
Roger,
David Hawthornthwaite made an excellent maintenance booklet for the S7, describing where to oil and how often to oil. I printed it out and had it plasticized and keep it near the lathe.
If you Google “Myford Super 7 maintenance” you’ll find it on his website.
Mark
Thread: V-Twin 100cc Design & Build
12/09/2019 09:39:07
Craig,
Loving this build thread immensely. As an alternative to holding your milling cutters in a collet you can also buy end mill holders from Arc which have fixed sizes. I have 2 ready to go with cutters in them 6mm and 10mm, being 2 sizes I use often.
Mark
Thread: The Workshop Progress Thread 2019
09/09/2019 16:40:54
John,
I am amazed to think you are designing a gearbox, i only vaguely undertand them! looking forward to seeing the progress, do you plan to take any phtotos to share with us?
Mark
Thread: Just bought an ML7, what should i do first?
09/09/2019 06:10:04
Shaun, watch Geoffrey Crokers’s most excellent youtube channel where he restored an ML-7 to what looks like almost new. Most rewarding to watch. With some effort and advice for which this forum is the best place to be your ML-7 will be fitting fit again!
07/09/2019 06:05:55
Here are some more build pics. It was challenging getting through that hard layer in the casting.
07/09/2019 05:56:41
I can't rotate the photo's sorry. I'm still not sure how or why they end up turned 90 degrees.
07/09/2019 05:54:52
We have been steadily chipping away at the Stuart. We got the cylinder honed and both cylinder covers done. We also got the crankshaft pinned.
Overal glad with the progress, no major snags except one which was quite a biggie. Whilst turning the cylinder on the rotary table I was distracted by the neighbour who popped into the garage to see how we were getting on. After he left I got back to the mill and promptly turned the x-axis handwheel instead of the rotary table handwheel! Gave it a good old yank too so the cutter plunged into the cylinder by 0.5mm so to clean it up we reduced the overal diameter of the cylinder to match the notch I'd just cut. Very frustrating!
Thread: Stuart Turner #1
21/08/2019 17:02:44
John, that is a beautiful No. 1 and as already said a welcome change in colours. Well done, I know how much work goes into making a running No. 1 as I am experiencing myself.
Thread: Myford
21/08/2019 11:09:10
If you decide to make them yourself, here are the dimensions you require. You’ll have to scroll down 3 or 4 posts to see the drawing. I think thats valid for both ML7 and S7 lathes.
Edited By Mark Gould 1 on 21/08/2019 11:11:20
Thread: Good YouTube videos
21/08/2019 10:47:55
I’d like to add another member here who has an excellent youtube channel. His name is Craig and he’s making a loco as we speak. His youtube channel is no23mk2
Thread: Pet peeves!
16/08/2019 12:59:18
Mick, I bought mine second hand and yes it still works but I am bery gentle with it and having to screw it closed to get it in the box makes me cringe every time. I think I’ll take Jan B’s advice and construct a new case.
16/08/2019 02:24:52
Posted by ega on 15/08/2019 23:57:52:
Posted by Mark Gould 1 on 15/08/2019 21:12:51:
I’m sure we all have one and mine regards to my favourite Mitutoyo micrometer. It only fits in the box when the anvils are nearly touching. And it’s one of those old Mitutoyo’s with the mechanical numerical wheels so every time I have to store it I worry about the wear and tear to that rather intricate bit of kit.
Why didn’t they design the box so that the thing would fit with the thimble “extended”?
Mark
They did:
But, so far as I know, M&W didn't!
I need a box like that! Haha exactly what I was referring to,
Mark
