Here is a list of all the postings Mark Gould 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford M Type tailstock alignment |
11/10/2020 21:48:04 |
Posted by Chris V on 11/10/2020 11:47:03:
Hi Nick, Thank you yes I have found plenty of these but I'm after a longer one around 12". Have found one in Ali this morning but I shall not be buying that, must be a steel one somewhere?! Regards Chris. Edge Technology sell one. Not cheap but a nice bit of kit. I’d lend you mine but shipping from NL to you would make it cheaper for you to buy one yourself Chris. https://www.machine-dro.co.uk/lathe-tailstock-to-headstock-alignment-gauge-bar-from-edge-technology Mark Edited By Mark Gould 1 on 11/10/2020 21:49:15 |
Thread: Gear cutter, possibly a Jacobs |
16/08/2020 11:39:52 |
Knock 10% off, you may find the seller in a good mood. |
Thread: What Did You Do Today 2020 |
13/08/2020 21:05:01 |
I almost melted today, we have now had 8 consecutive days with temperatures above 30 C here in the Netherlands. This has never happened before. The previous record was 6 consecutive days above 30 and that dated from 1975. |
Thread: Measuring tilt angles |
13/08/2020 20:27:13 |
Posted by Bandersnatch on 13/08/2020 17:26:37:
For"standard" angles I usually find a set of these makes it easy: Good recommendation, I have the same set, very handy. Arc sell that set too, but for less Mark |
Thread: Myford Mk1 Super 7 restoration |
29/07/2020 18:27:44 |
Loving this thread as I suspect many are Pete, any chance of some new photo’s? Mark |
Thread: Emco FB2 Quirks and Additions |
29/07/2020 09:13:06 |
Thanks Gray, you did say you needed the occasional prod |
27/07/2020 21:19:59 |
Nice of you to start this thread Graham. Always handy to see other FB-2 machines and exchange ideas. i have made Grahams most excellent spindle lock. |
Thread: TOOLS EXPLAINED BY A DO-IT-YOUR SELFER |
02/07/2020 11:45:18 |
Funniest thing I’ve read in weeks! |
Thread: MEM Corliss progress |
12/06/2020 21:46:00 |
Looks beautiful so far, looking forward to some more updates, Mark |
Thread: Parting off |
08/06/2020 17:23:42 |
Is the tool exactly perpendicular to the work? Is the tool height correct? Is the carriage locked? Is the work not spinning too fast? Are you using enough lubricant? Are you feeding the tool at the correct rate? I am by no means an expert on parting and have had my share of mishaps but these are the questions to answer. Good luck, Mark |
Thread: Tailstock die holder |
07/06/2020 14:43:02 |
Nice work. I once bought a tail stock die holder and regretted not making it myself. Hope to see yours completed soon, Mark |
Thread: Reading... |
07/06/2020 14:40:01 |
I learned a lot by watching youtube video’s. There are several excellent “creators” who have made videos on lathe basics. Easier to digest than text from a book but that might be my inherent laziness shining through Mark |
Thread: Newbie trying to thread |
05/06/2020 21:31:43 |
Mart, Thanks, there's a long way to go! It;'s nice to know there is such a wealth of knowledge here and (more importantly) people willing to share it! Mark |
05/06/2020 18:58:53 |
Thanks Bear, good tip, I have enough Delrin lying around to mess around with. |
Thread: Stuart 10V Build Log - Complete Beginner... |
05/06/2020 18:01:32 |
Loving your progress Garth, you seem to be doing everything right! Quick question though, how do you get all of your photos to be oriented correctly? I have the occasional one that turns out rotated when I upload it to my album. Sorry to hijack this lovely build thread with a question. Mark |
05/06/2020 17:18:23 |
@NDIY, yes I had a half dead center to support the work. @Martin, I initially tried to establish 30 deg by using a precision ground angle plate from a set I bought from Arc but couldn’t get it exact so reverted to a direct plunge method. Your way sounds logical, wish I had thought of that! I find setting the angle on a Myford compound difficult to get exactly right. Mark |
05/06/2020 14:34:28 |
Martin, good idea. I have not examined the insert yet but will do that, thanks. I will also pull it back into the holder a bit more. No reason at all for the over hang. Mick, yes this was a plunge cut. I used copious amounts of oil As you can see in the photo but will cut them at the proper angle once I have discovered how to accurately establish the 29,5 deg recommended for a Metric thread. Thanks for the tips, |
05/06/2020 07:01:13 |
That is a pic I borrowed off this site. I'm not sure who's it is and all I did was added "this one" to show the appropriate gear. Mark |
05/06/2020 06:51:25 |
No worries David, I am not at the level to have properly understood what you said anyway so no harm done. Thanks anyway though. @Steviegtr this is the wheel to place the 33t or 34t gear. Because it is a bit bigger than the gear normally in that position you have to drop the banjo a little bit lower. This means you have to make a simple drop arm. |
04/06/2020 21:10:17 |
Gents, I took all of your advice to heart and had another go today. Total succes, even pleased with the fit. This is not a functional part, merely a test cut to validate Brian Woods drop arm and 33T/34T set up. Worked like a charm. Thanks for all the tips, Mark |
