Member postings for Mike E.
Here is a list of all the postings Mike E. has made in our forums. Click on a thread name to jump to the thread.
Thread: Diametric Pitch
20/06/2017 08:57:57
Posted by richardandtracy on 19/06/2017 16:03:22:
I have BS 436: Part 1:1967 on my desk at the moment. It's 'Specification for Spur and Helical Gears... (diametral pitch series)'
So I can confirm it's been 'diametral' since at least 1967...
Richard
Since at least 1955, according to my earliest Machinery's Handbook.
Thread: Telescope mount
17/06/2017 17:23:26
Google "Stargazers Lounge", which is great site for amateur Astronomers; you will find a lot of good information about equipment there and advice from experienced observers.
Thread: Was in Penrith and this pulled up.
15/06/2017 13:02:58
Wow, what a jewel !
I remember seeing a Rolls similar to that for sale for ten thousand dollars at the Rose Bowl swap meet in California back in 1970. There was also a gull wing Mercedes for sale for fourteen thousand at the car show held on my High School's football field the same year. If one could only have speculated their future value and desirability in todays world.
smiley
Thread: Latest forum posts
13/06/2017 13:04:44
+ 1 for a longer list. It would be nice if "all" the advertising was on the Home page, with a bypass on the Toolbar to click onto to get to the meat of the forum.
Thread: Abergavenny Steam Rally
25/05/2017 20:40:21
Thanks for posting, I wasn't aware of the event; not too far away either.
( Take two wheelbarrows full of money. ) smiley
Thread: Workshop tips from long ago
24/05/2017 18:01:25
Use Lacquer Thinner to tap aluminium. Learned this 40 some years ago from an old machinist at Lockheed Aircraft.
Thread: Opus die filer
23/05/2017 15:36:25
And here is a view of crank and slider mechanism. It would be interesting to see an internal photo of Tractor Man's filer for comparison.
Opus 120 Die Filer
23/05/2017 15:31:55
Here is a photo of the filer's guide wheel & track.
Opus 120 Die Filer
23/05/2017 15:25:19
I had a look today and was able to see the elongated slot in the flywheel where the connecting rod is attached. There doesn't appear to be any index marks to designate stroke length, so I guess you just adjust it by trial & error. Here is a photo.Opus 120 Die Filer
Edited By Mike E. on 23/05/2017 15:26:16
Thread: Is Knurling a health hazard?
19/05/2017 13:24:22
Posted by ChrisH on 19/05/2017 13:02:40:
Rozalex Barrier Cream,
- if you can find it, Mole Valley sell it, or did, always used to be good. They do wet and dry versions. Used it for years when I was at sea in the MN in the engine room.
Chris
Thanks, I'll look for it ! yes
19/05/2017 09:58:11
Posted by ega on 18/05/2017 16:41:20:
Mike E.:
As a barrier cream for dry (ie not involving water) work I have found nothing to beat PR88; certainly not cheap but very economical used correctly.
Thank you. yes
17/05/2017 19:17:51
Posted by mechman48 on 16/05/2017 17:32:45:
At present I am using barrier cream; mainly as I'm working with cast iron on the Stuarts kit S50 & as we all know the cast iron gets into the pores & creases in your skin so it makes for easier clean up afterwards, I also use disposable latex gloves as first line protection with cast too.
George.
What is a good economical barrier cream to purchase ?
Cheers, Mike
Thread: My models and our workshop
17/05/2017 18:10:50
Very nice miniature models William, Well done !
I don't have game consoles either, never have. If my Dad were still with us today, he would say....... Live a real life, not a virtual one.
16/05/2017 22:57:04
Posted by the artfull-codger on 15/05/2017 20:41:09:
Hi MikeE, to adjust the stroke you open the long narrow door at the upper left hand side, inside you'll see a flywheel with a 19mm spanner size nut with a bearing & a tee slot just like a shaping machine which you slide nearer the centre for a shorter stroke & outer for a longer stroke.
Graham.
H Graham,
When the filer was delivered I noticed the narrow cover on the left side. I popped it open for a look, but couldn't see much as I didn't have a torch at the time; I'll check it out.
Cheers
Thread: A Filing Machine with motor drive
14/05/2017 15:55:11
If it's of any help, the stroke rates for an old industrial filing machine I have are 70, 110, 150, & 280 strokes per minute.
14/05/2017 15:37:02
Hi daveb, The pulley system only controls file speeds, and the hand wheel operates the pulleys by a long vertical screw. I just don't see any adjustment device on the surface of the machine to vary the stroke length. I have a shaper, so I understand what you mean about the sliding block, which makes sense. I now think the adjustment is likely to be inside the main casting, which I'll check it out next time I'm at my storage unit; thanks for the tip.
Edited By Mike E. on 14/05/2017 15:37:40
13/05/2017 20:48:25
Opus 120 Die Filer
The 120 model of the Opus filer is capable of table adjustments of up to a 10 degree angle, but no elevation adjustment like the larger 140 model. According to the information on the lathes.co.uk site, this filer is supposed to have a stroke adjustment range of  0 > 4 3/4" but I can't see how to do it ?  The only control beside the on/off switch is the hand wheel for pulley tension & selection. Opus 120 Die Filer
Edited By Mike E. on 13/05/2017 20:49:57
Edited By Mike E. on 13/05/2017 21:03:56
Thread: What is it?
13/05/2017 16:42:43
The tailstock seems to be reversed, and by the addition of a belt drive on it, it looks similar to a glass blowing lathe.
Thread: Centec 2 drop arm dimensions or for sale
12/05/2017 09:14:19
Have a look on the quillstar.co.uk used tools site, and scroll down to the very bottom of the page. Currently they show a pallet load of Centec parts which includes an overarm with an arbor support. You might want to give them a call to see if its compatible with your needs.
09/05/2017 23:28:32
I learn something every day. Thanks Graham, that's a good trick to know.
EngineDIY
