Member postings for Ian Skeldon 2
Here is a list of all the postings Ian Skeldon 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: screw cutting on a chester db10 lathe
21/08/2019 21:21:47
You got a hand book with your DB10, wow they've raised their game.
If you let us know what thread you are trying to cut it will help in deciding what gears you need to use, below is a picture of the gear settings on my DB10.
Thread: Chester 836 Milling Machine
29/07/2019 19:31:09
Hi Graham,
I'm sorry but i'm not sure how you would go about buying one of the cnc mills as used by Jason, I use a manual mill and have no experience of using a cnc mill myself. Having seen what Jason can do on this mill is impressive, in my hands it would just be gathering dust. I believe that Neil (forum admin) also has the same machine, but I have not seen any video of it in action. Might be worth contacting ARC as I believe they were the suppliers of said machine.
I think we need to start a new thread if we wish to continue talking about air rifles as we have strayed off topic somewhat. wink
28/07/2019 22:14:27
Hi Graham,
It's funny how many of us on this forum shoot air rifles and also modify them and make parts for them etc. I have not made a reg yet but have made a reg tester and tool for polishing the nylon/synthetic face accurately. Modified my EV2 and am over the moon with it now.
If you want to manufacture even on a small scale then I think a cnc mill the same as the one used by Jason, on here would possibly be a good consideration. Look at page 5 of the thread named Sieg KX3 & KX1.
If you can manage without cnc and want a Bridgport knowing it has been serviced properly, have a look at this LINK
Good luck.
Thread: Further Adventures with the Sieg KX3 & KX1
28/07/2019 19:36:19
Fantastic to watch Jason, thanks for sharing. If I had the knowledge to back it up then a cnc mill would certainly be on the cards, am I right in thinking it makes the rotary table almost obsolete?
Thread: TTFN
18/07/2019 20:01:49
I am extremely sad to hear of your decision Andrew, you have been one of the very helpful people that I referred to in the very same thread, your knowledge and willingness to help will be greatly missed by those genuine forum members, hopefully your absence will be short lived. So until your return I wish you well and hope the building of those traction engines continues so that you might share a video of them running.
Best regards,
Ian
Thread: Recent threads
14/07/2019 22:02:31
I have encountered the odd unhelpful response on this forum but I have received far more genuine replies and offers of help from quite a few members on this forum. Long may the helpful and friendly members continue to out post the not so helpful.
Thread: Different ways of boring a hole
14/07/2019 21:51:48
So Jason, if I understand correctly, the work piece is fastened onto the saddle with a special clamp arrangement, and travels along the bed with your home made tool mounted in the chuck and supported by the tail stock centre. Bore size increased by adjusting the tool. That's very clever, I would never have thought of doing that myself, thanks for sharing.
Thread: Warco Mini Lathe
22/06/2019 20:47:11
I would be inclined to try and get it working better before buying anything else. You could buy something bigger and dearer only to find that it too has problems, the experience in fixing it or at least improving the problem will be a skill you have acquired to take with you when you buy other machinery. I have had to make several modifications and adjustments to my Chester DB10 to get it to turn truly parallel and give a good finish. Even now I am thinking of buying or making a better tool post mounting arrangement as this is now the weakest link in it. Once that's done I will look at upgrading the motor.
Good luck.
22/06/2019 20:26:41
Posted by Neil Wyatt on 22/06/2019 19:57:25:
Posted by Ian Skeldon 2 on 20/06/2019 19:25:32:
I don't know a great deal about guitars but that bass looks great now you have cleaned it up Neil.
Thanks, it sounds good too. Very much a 'precision bass' sound If this works!):
Yep sounds very good, nice to have the skill to re-build it and play it.
Thread: Chinese tacho - beware
21/06/2019 21:04:52
Duncan (or anyone else) do you have a link to the project that uses the ardunio to make an accurate tacho such as the one you have made? I was thinking of getting one of the ones on ebay for my Myford mill but after reading your post I guess it was too good to be true to expect a tacho that would work and continue to work for that price.
Does anyone know if there is a tacho that you can buy where all that is needed is placing of the magnet and some simple wiring?
TIA ,
Ian
20/06/2019 19:25:32
Thread: Super Mini Lathe belt problem
15/06/2019 23:25:43
Posted by Haggerleases on 15/06/2019 22:48:06:
I'm going to cop some flak for this, but buying a reasonably 'big ticket' item like a Chinese lathe, smacks to me of another example of the 'baby boomers' and yes, successive generations too, selling the world down the river for their own brief amusement (again).
I've been on the Warco site, The Axminster site, and so on, and my finger has hovered over the 'buy' button many times, but I just can't bring myself to do it.
...Ducking and covering.
So don't press the buy button, nobody really gives a damn what you buy, it's your hard earned money, go out and get the best British lathe you can afford if that's what your personal choice is. I hope your driving around in a British made car, hopefully with enough space for you and that chip your carrying around.
14/06/2019 21:10:40
Posted by Haggerleases on 14/06/2019 20:37:00:
Perhaps what they say is true, a Chinese lathe at this price is a kit of parts. Sad though. 1000? years of development of this tool and this is where we're at? Really?
Well as you have mentioned it, yes it is where we are at, however all is not lost in fact it's better than it ever was. Many, many years ago I wanted to own my own lathe, an engineering company were selling a couple of old Herbert's, even though they were well worn and very basic they wanted almost a years salary for them, (I was in my last year of apprenticeship so my salary wasn't great). Move on to where we are now and I can engage a few places who can discuss my needs (wants more than need) and then sell me a new lathe suitable to my requirements. It might not be up there with the best available, but look at the cost of a British lathe similar in function, (say a new Myford) I couldn't justify such a purchase even if I could afford it.
Hopefully the OP will get many years of use and enjoyment from his lathe and he knows that Warco are there to help if needed.
Thread: WT2527 15cc Glow Engine
08/06/2019 22:18:58
Great work Craig, sounds lovely, hope you get many happy hours flying it.
Thread: Oh bugger, I told you I was ill
05/06/2019 20:12:04
Posted by Neil Wyatt on 05/06/2019 20:09:46:
Posted by Plasma on 05/06/2019 18:29:59:
I even won an Ebay auction while I was under lol.
Good job you are OK, might have had a negative effect on your feedback otherwise!
All the best for speedy recovery now.
Love the banter. Hope your better soon mate.
Thread: HSS or CS taps and dies
22/05/2019 11:01:07
Having read through this thread I will admit that I mostly have and use HSS, I am sure at some point I have broken both CS and HSS through my own fault. I might just give the spiral flute taps a go in the future, I hadn't realised that they would work as a hand tapping tool.
I had a quick look at Presto web site and they are asking to log in before seeing prices or buying taps or drills, do they only deal with companies or bulk orders?
Thread: indexible internal thread cutting tool
20/05/2019 21:55:45
Posted by Roderick Jenkins on 19/05/2019 23:52:53:
I use exactly the same tool from RDG. Generally I get good results, usually winding the spindle by hand. Tougher materials like silver steel do tend to have a burred up finish which needs a bit of work afterwards to clear up the crests with a file. I suspect it is your hydraulic tube that is causing the problem. As has been suggested, you may need a rather more frightening speed to get a good finish straight from the tool. Perhaps the in to out reverse method as advocated by Jason may be the answer.
Rod
Hi Rod,
Yeah I think the tube is made of some well treated steel, the cutter does cut it ok, just that the finish is awful.
I will give it a go over the next few evenings and let you all know how I get on.
20/05/2019 21:51:48
Posted by Emgee on 19/05/2019 23:11:00:
Ian, be aware that you need the designated thread size for each insert as the crest form varies from the small to larger sizes, best to just buy the sizes as needed and you soon build up a number of common sizes, same info goes for different TPI inserts.
Emgee
Thanks Emgee, I will bare that in mind, it does look a bit on the small side for the job I am doing.
19/05/2019 22:30:54
Hi John,
I will have a look at that, currently I have set it the conventional way so that the tip is at the centre of the tube which could well be part of the problem. Sadly the tool holder and insert came with no technical data.
19/05/2019 22:27:50
Hi Emgee,
I think your right, the crest does look and feel sharp. I might have to look at the same supplier that Andrew uses. What is that saying about buying cheap sad
TRANSWAVE Converters
Ausee.com.au
Advertise With Us
Meridienne Sept 2019
