Member postings for Pete Cordell
Here is a list of all the postings Pete Cordell has made in our forums. Click on a thread name to jump to the thread.
Thread: 5BA / M3 - Interchangability
04/11/2019 11:28:42
Somewhat expensive but i can find them in the local department store
Thread: Cast Iron Straight Edge
21/01/2019 11:41:29
If you have deep pockets and long arms this guy has them
Edited By Pete Cordell on 21/01/2019 11:41:54
Thread: Removing Grit after Lapping Ways
11/12/2018 21:03:18
Ultrasonic Cleaning looks promising
What Ultrasonic Cleaning Can do
Its Cleans Oil, grease, polishing compound, waxes, cutting fluids, lapping compound, dirt, swarf, residues, resin, silicones, carbon deposition, scale, finger prints, solder flux, plating salts, blood, ink, photoresist, lacquer, paint etc
ref: saisonics
11/12/2018 13:59:59
I believe you are saying your abrasives have embedded in the cast iron
Next time it may be worth consider using Timesaver or Garnet lapping compound (supposed to break down)
Or use a soft lap, abrasive gets embedded in the lap then not the work
Only thing i can think of to get it out is have it hand scraped
Thread: Alan Stepney’s Model Engineering Website
03/12/2018 10:41:58
You could try the wayback machine
https://web.archive.org/web/*/http://www.livesteambuilds.com/
Thread: Cheap 3D printers
10/11/2018 16:04:04
I have a P802MA from well know online auction site, after fixing it to a piece of 50mm board (for stability) and adding two 210A MOSFETS(to move the high power load off the main board) one for the bed and one for the hot end, and also a Scrub Surface Hot Bed Sticker (so prints stick to the bed and can be removed)I have been pleased with it
Thread: PLA Filament Breakage
23/08/2018 18:49:17
There is very little cost to cutting a meter or two and giving it dip in boiling water. so i see no reason for anyone to just desregard this without testing, it has worked for me
23/08/2018 05:27:13
The filament is dry before you bin it , give it a 5 sec dip in boiling water then let it dry
Thread: Help needed making Harold Hall's Grinding Rest
19/06/2018 09:52:12
hi joe
I just finished making that rest last week and say the 5.2mm holes are not critial size, you will need a little play to aline the leadscrew and center pin
mid gard rail Jan 2020
