Member postings for BOB BLACKSHAW
Here is a list of all the postings BOB BLACKSHAW has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart No 10 drawing help
07/01/2021 13:01:52
Hello all, I picked up this booklet from 1940 of the castings needed for a Stuart No 10, the dimension needed is part A , marked with two arrows. Also I would like to add the reversing gear has anyone got those please. Interesting the set of castings cost 8/6, the finished engine was £2-10, around 200% inflation to today's prices. I know the rough size but I want to get it correct
Thread: Flame resistant material
18/12/2020 17:25:16
Thanks for the replies, pgk that's the stuff I want, it will be perfect.
Bob
18/12/2020 14:45:53
I am looking for some flame resistant material which must be a few millimeters thick, checked out manifold wrap will this do the job or is this just insulation. I have some white cotton wool looking material which is flame proof but is now falling apart and not what I need. Any ideas please.
Bob
Thread: My Bungalow fogs up outside
15/12/2020 08:21:51
Good Morning all, This morning all of my windows in my bungalow were fogged up on the outside, this has happened many times in the past at this time of year. The conservatory which had no heating on so similar temperatures to the outside was the same, my neighbors bungalows I noticed are not fogged up, I don't have the heating on at night as we don't like being to hot at night, but the temperatures in the morning when I got up was just below 15deg c, if the inside temperature of the bungalow was the same as my conservatory I could understand this, any idea why this happens.
Thanks Bob
Thread: BT e-mail
13/12/2020 10:18:55
Thanks all, I just use the BT site only.
Bob
13/12/2020 08:53:21
Hello all, can you tell if a BT e-mail has been read by the receiver, is there a setting that can be done. Where I worked this could be done on internal e-mails but this was set up by a colleague at the time.
Thanks Bob
Thread: Pea shooters illegal
12/12/2020 08:34:34
A rolled up newspaper is a good weapon that can give a injury.
Bob
Thread: Boat hull formula
10/12/2020 08:59:21
Great replies thanks all. The Maersk ship showing the load line you can just see the top of the bow bulge, how much of the ship hull is in the water in depth, say fifteen feet for example. Looks like a good storm would roll the ship over, as stated light loads on top.
Bob
08/12/2020 10:45:50
I have a load of packing carboard from a fridge that was delivered, I am to make the hull out of that and see how much weight it will take for the the correct water line.
Bob
08/12/2020 08:52:11
Again thanks for the replies, I can see the differences balsa wood and 16g copper weight and the displacement has been noted with the imput here. I am going to rough make the hull out of cardboard cover with plastic and put the weight of the copper and parts distributed and see what happens.
Bob
07/12/2020 17:55:30
Thanks Dave for your interest , I shall weigh the amount the hull will weigh in the morning including engine and boiler water etc, I'm finding this interesting
Bob
07/12/2020 15:47:20
Thanks for the replies on this,it seems that a lot more thought is needed as a lot of work could be wasted. Tug .the steam launch looks fantastic, a question when you planked the hull did you rebate the edge for the next plank to fit on. I have no wood working skills so that why I was looking at a metal hull.
Bob
07/12/2020 09:18:59
Hello, I have made the engine and near finishing the boiler for the tug boat I am making. I am to start on the hull but would like a formula to see if it will float at the correct line after all the parts are installed. The problem is that I am making the hull out of 16g copper cut into strips and soldering up to 18g steel formers. I have a 1/2 sheet of copper that will never be used and it will be easy to work around the shapes needed. But I worried that after making it with all the parts in will it be to low in the water, is there a formula that can be used to determine this problem .Hull size is 30 inches x 7.6 inches, or will it be to heavy and sink
Thanks Bob
Thread: Pop ups on my Samsung phone
03/12/2020 13:07:12
Thanks all, my phone is a J4 model different way of getting rid of the pop-ups on the S10 but with the advice I've done it ,no more breasts. I shut the phone down for a short time and now the videos are back so hopefully that to is fixed.
Bob
03/12/2020 12:12:18
Thanks I will try that out. Another problem is now all my videos will not play only sound, a comment comes up Video Codec not supported, how can I get those back please.
Bob
03/12/2020 11:42:13
It must be Android as has been said here as my computer is fine, I have McAfee antivirus on all my devices and this can't stop it. I will just have to put up with it and enjoy breasts instead of a 2mm die.
Bob
03/12/2020 10:32:35
Hello all. Please can you help me stop these pop ups coming up on my Samsung phone, Its getting worse with now obscene photos and advertising taking over what web pages I look at. It has become embarrassing if someone is with me when this happens, if I had ever looked at the crap in the past then I could understand stand how this has infected my phone but I'm more interested in a 2mm die than a pair of breasts.
Bob
Thread: Model tug boat plans
30/11/2020 17:11:53
Thanks all, looking forward to making it, problem is where to float it after its made. Boiler certificate needed if used in public area, how do others get on who make steam models ? not over bothered as its making it is the interest for me.
Bob
29/11/2020 17:26:40
Thanks for all the replies. ways of scaling up noted, but I think that a full size plan will be the best way to go as Michael has made a 42 inch hull with out scaling up.
Bob
29/11/2020 11:18:19
I've been looking on e-bay for a set of model tug plans and have found one I quite like, as I haven't seen a boat plan before a question I need to ask. With engineering drawings there is no need for or I haven't come across the need to use the drawing as a pattern. The important part of the tug drawing is the shape of the hull but the drawing shows the profiles but not at the scale as the tug, which is 27 inches long and a 8 inch beam. The drawing looks half that size, how do you convert the drawing profile to the full size, is a drawing set needed to double the size. I've made model glider in the past and used the drawing as the pattern for the wings etc.
Thanks Bob
EngineDIY
