Member postings for Brian Sweeting
Here is a list of all the postings Brian Sweeting has made in our forums. Click on a thread name to jump to the thread.
Thread: Tube Notching
04/03/2019 13:39:14
AJ 1, very many years ago I worked for a firm that made tubular steel trolleys and the tubes were notched on a machine providing a similar method to the one that you are proposing.
If memory serves, it had a rotating cutter like a milling tool but mounted horizontally The tube was clamped into a movable vise and pushed onto the cutter.
Maybe make a sliding plug to go inside your tube so that a spare(?) drill chuck could be used to hold the non cutting end of the tube and improve your grip.
Thread: E bay
24/02/2019 12:27:43
Seems fine to me using Chrome on a tablet.
Have you tried clearing your computer cache? Sometimes helps.
Thread: Modern equivellent idea's please
14/02/2019 17:23:22
If you need new mounts for that motor try Remco......
Thread: lathe wanted
10/02/2019 22:20:09
Whereabouts are you located, roughly.
Thread: How do I adjust the quill?
10/02/2019 12:54:59
Thank you for the update, always good to know when a resolution is acheived.
Thread: J&S 540 Manual PDF
09/02/2019 14:27:30
Have you tried lathes.co.uk ?
Thread: Overload trip
08/02/2019 19:41:55
Right, 8amps and 230vac would be a suitable size for a regular motor overload device however a temperature sensing motor protection thermistor might be a better solution.
This link is to an American source but gives a good insight into the device.
08/02/2019 19:36:56
Posted by Michael Gilligan on 08/02/2019 19:34:19:
Brian,
The thread subtitle declares:
"8 watt 250 volt AC motor / gearbox."
Thank you MichaelG, I hadn't read or adsorbed that bit of the title, I'll sit in the corner quietly for a bit.
08/02/2019 19:25:52
May I ask what the voltage of the motor is and is it ac or dc?
Thread: Very soft stretchy rubber grommets, where from?
06/02/2019 22:10:30
I think I know the type of thing you are looking for but for the life of me I can't name them.
In the meantime is there anything suitable from this grommet company....
Thread: Copper Round Head Rivets
01/02/2019 23:48:39
The power of Google ....
Thread: nylon gib strip grub screws?
15/01/2019 00:11:44
Try "self locking grub screws" to get started.
Some similar here - **LINK**
Thread: Piston rings
14/01/2019 14:05:55
Why not use what is specified, worst price I've seen was £4 a metre.
Thread: Yet more confusion!
12/01/2019 18:13:33
Posted by Brian H on 12/01/2019 15:12:20:
It didn't take long for someone to jump on the "it must be climate change" bandwagon.
Brian
Who jumped and where?
Thread: Unimat 3 - lost my variable speed.
04/01/2019 21:19:18
A bridge rectifier does not control voltage only ensures DC voltage.
Thread: Nylon for axle boxes ?
04/01/2019 21:14:54
Try looking at Acetal.
Thread: Jan Ridders Pressure Controlled 2 stroke Engine
04/01/2019 21:07:49
Congratulations, well deserved.
Thread: Workshop headphones
02/01/2019 17:29:26
If you search the net for "wireless ear defenders" you will find quite a range.
Thread: 1.5 hp dc motor
29/12/2018 18:25:17
What machine did it come from, this might gives clues to the controller ?
Thread: Merry Christmas from Australia
24/12/2018 12:46:58
Thank you and the seasons greetings to you and yours.
EngineDIY
