Member postings for Brian Sweeting
Here is a list of all the postings Brian Sweeting has made in our forums. Click on a thread name to jump to the thread.
Thread: Unusual miniature
01/04/2019 09:19:38
I would imagine that there is a differential driving the two tracks with brakes on the drive shafts.
You can see that he doesn't need to 'spin' the steering, just turn it a small amount.
Thread: Dishwasher detergents
30/03/2019 18:58:11
Haven't tried Aldi but swear by the ones from Lidl
Thread: LED replacement bulbs
30/03/2019 18:54:58
I've just bought some 106W halogen bulbs from thelightbulb.co.uk , equiv to 150W for a limited sight lady friend of ours.
So, if you look you can still buy proper bulbs.
Thread: Myford workshop Manual
29/03/2019 18:50:13
A good start would be lathes.co.uk **LINK**
Thread: Odd furrow like finish when taper turning?
26/03/2019 14:37:44
Apron tight?
Thread: AC Capacitor
26/03/2019 14:34:44
Posted by john fletcher 1 on 26/03/2019 14:19:10:
Hello Raphael, I note Dave Davies 8 say he bought a capacitor and start relay. Has your compressor start relay got 3 pins on it similar to a fridge start relay, if so check it before buying a new capacitor, as you have the symptoms of a faulty relay. You mentioned the hum and then turn off, which I think the overload is switching things off ,because the start winding is not being energised.due to a faulty relay. Usually the capacitance value is printed on the cap can.John
Good comment John, I must admit when I was on the fridge tools it was standard practice to replace the complete starter kit, relays, capacitors etc, when one item had failed.
It wasn't worth the cost risk to skimp on the starter kit compared with blowing the compressor.
25/03/2019 23:58:01
Posted by RAPHAEL VAL GOLEZ 1 on 25/03/2019 23:11:37:
Thanks Simon, great help. I hope this is an easy fix as I really valued this old compressor. Jus another follow up question, do I need a motor start or motor run capacitor? Is the 450 volts to high for the 270 that I have? I appreciate your explanation, I just don't want to blow things up or fry the motor.
If you have motor start capacitor there should be a resistor fitted across it. If not then it is probably a motor run capacitor so make sure that you specify it as a 'motor run' item.
Thread: Unusual knurling tool
22/03/2019 19:26:53
Plasma, one use in clock making that I can think of would be knurled clock case feet but seems kind of expensive for that.
Thread: Calculating piston length
13/03/2019 14:27:06
Perhaps machine a Delrin piston first to see how it fits before the final metal version.
Thread: Myford Lathe on Ebay
11/03/2019 11:13:06
Posted by Bazyle on 10/03/2019 22:42:56:
Posted by Brian Sweeting on 10/03/2019 22:33:29:
Seeing this thread content may I ask if it is okay to post links from Facebook?
That's up to Neil really but I would suggest people resist the temptation. There are half a dozen lathes, plus mills and so on newly listed every single day so we would be inundated and just turn into a repeater function for adverts. Not really what the forum is for.
Fair comment, thanks.
10/03/2019 22:33:29
Of late there have been a few lathes and mills for sale in my area, Newton Abbot / Torquay, which may have been of interest to some.
Thanks, Brian
Thread: Tube Notching
04/03/2019 13:39:14
AJ 1, very many years ago I worked for a firm that made tubular steel trolleys and the tubes were notched on a machine providing a similar method to the one that you are proposing.
If memory serves, it had a rotating cutter like a milling tool but mounted horizontally The tube was clamped into a movable vise and pushed onto the cutter.
Maybe make a sliding plug to go inside your tube so that a spare(?) drill chuck could be used to hold the non cutting end of the tube and improve your grip.
Thread: E bay
24/02/2019 12:27:43
Seems fine to me using Chrome on a tablet.
Have you tried clearing your computer cache? Sometimes helps.
Thread: Modern equivellent idea's please
14/02/2019 17:23:22
If you need new mounts for that motor try Remco......
Thread: lathe wanted
10/02/2019 22:20:09
Whereabouts are you located, roughly.
Thread: How do I adjust the quill?
10/02/2019 12:54:59
Thank you for the update, always good to know when a resolution is acheived.
Thread: J&S 540 Manual PDF
09/02/2019 14:27:30
Have you tried lathes.co.uk ?
Thread: Overload trip
08/02/2019 19:41:55
Right, 8amps and 230vac would be a suitable size for a regular motor overload device however a temperature sensing motor protection thermistor might be a better solution.
This link is to an American source but gives a good insight into the device.
08/02/2019 19:36:56
Posted by Michael Gilligan on 08/02/2019 19:34:19:
Brian,
The thread subtitle declares:
"8 watt 250 volt AC motor / gearbox."
Thank you MichaelG, I hadn't read or adsorbed that bit of the title, I'll sit in the corner quietly for a bit.
08/02/2019 19:25:52
May I ask what the voltage of the motor is and is it ac or dc?
Ausee.com.au
