Member postings for Carl
Here is a list of all the postings Carl has made in our forums. Click on a thread name to jump to the thread.
Thread: Only for Myford lathes
05/02/2020 11:07:05
In the link above it says the bed was changed to wide in preparation for the power cross feed.
Does any one know if it is possible to retro-fit the power feed to one of these lathes without the powered feed (if all bits were available) ?
Thanks
Thread: Have a look at this, view from the chuck
08/01/2020 21:41:28
Thread: Just for fun what’s this stuck in my tyre?
28/08/2019 14:18:52
Looks like a bit of flint, maybe a Belemnite (bullet shape) fossil. Been to the beach ?
Thread: Myford super 7 Tailstock Spindle Damage
31/07/2019 14:06:49
Thank you for the replies, sounds like good advice on controlled use of the MT reamer. I think i will give it a go.
Carl
29/07/2019 17:47:56
Hello all,
The MT2 spindle bore in my tailstock has some damage i can feel, has anyone any idea of how to best clean it up ?
Has anyone any experience of using a MT reamer or any other way that proved successful ?
Thanks
Thread: Bonus content ?
16/05/2019 08:49:07
Thanks for that, I had tried a search but strangely nothing was found, but searching now it appears ...?
15/05/2019 14:05:28
Hello folks, in issue 280 under website bonus content on page 7 is listed Streess relieving mild steel bar, which I can’t find any where. Have I missed something obvious ? Thanks all
Thread: harrison m300, spindle run out...bearings?
18/12/2018 13:31:12
Although work is tight in chuck jaws it can move causing vibration/bad finish and still be tight after moving. Jaws may not be true and gripping along their length.
How much work was out of the chuck when cutting and was it supported ?
I have seen seen the bolts supporting top slide shear causing movement under load whilst top slide felt tight, also clamping on a Dickson style tool post was damaged and the tool moved under load but felt tight to the hand.
C
Thread: New old 1950's Myford 7 Lathe still in the crate
07/09/2018 15:58:39
A few old 40’s Harley’s in crates ! where are they hiding then ? Over in the USA I suppose ...old WLA/C stock maybe ?
Thread: Shingle bells
20/07/2018 23:40:16
Excellent advice here, get antiviral treatment early and avoid extreme discomfort, like someone sneaking up behind you and turning a blowtorch on your skin.Had it once and don’t want a second go ! First sign for me was a feeling I’d burnt my thigh which I hadn’t.
Carl
Thread: Myford Super 7 binding spindle
10/07/2018 23:51:46
Help...So i’ve adjusted the spindle/bearings on my Super 7 following the Myford instructions and the way described on the Myford Ltd website and still the spindle comes to s halt under power if anything other than a light force is put on it by the tail stock and i’m sure i’m not being heavy handed. It seems to be getting worse, any one got any ideas, have I missed something crucial to correct clearance ?
Thanks
Thread: Milling table regrind
05/07/2018 17:50:18
Thanks for the info.
Its a Hayes Diemaster and all the Horizontal surfaces suffered in storage, condensation i suspect. There are a couple of tool marks but still to be cleaned up, its the table surface that will need attention first
Carl.
03/07/2018 14:00:03
Hello all,
I am thinking of getting the surface of my new old machines table re ground as it's been standing for about 30 years, size is 26 by 9 inches. Any idea of costs to be expected or recommendations ? I'm near Bury St Edmunds.
thanks
Thread: Model engineer's workshop to be cleared
23/04/2018 22:39:47
Alison, i have sent you a private mail.
Thread: Taylor Hobson engraving spindle
17/11/2017 19:44:15
Mark, i’ve seen this, overpriced I think and incomplete missing the closing nut and vertical adjustment wheel amongst other things.
Michael, many thanks for the link. This makes things a lot clearer. I understand getting the top bearings out is ok but after that ? There was some info. on a engraving forum but all the instructions and pictures have disappeared frustratingly.....
Thankyou to you both.
17/11/2017 11:21:10
Has anyone any experience of taking apart one of the Taylor Hobson pantograph engraving spindles, D model type ? I can’t figure out where to begin. Also i’m looking for the collet holding version if anyone has one lying around unused. Thanks.
Thread: Move to a Miller
10/08/2017 19:54:45
Yes I was trying to put a slot into a piece of 12 mm steel plate which I managed but you get the feeling the cross slide is not really up to it. The piece was mounted onto an adjustable vertical slide, older style which is lightly built. My real problem is capacity. I need to make some conical reamers up to 300 mm long, which may be possible by making up a jig to attach to the cross slide, but using a mill to do the job is pretty straight forward. I was spoilt in the past by having the use of a Bridgeport, rock solid. But it is an interesting challenge so perhaps I'll give it a go if I don't manage to find the right machine.
Carl
04/08/2017 23:53:14
Thanks for the input. I think that going for a generous size is sound advice and the availability of second hand UK make mills for the price of a new import makes me think of looking out for a well looked after example. Floor standing with power to the table preferably.
Carl
01/08/2017 11:27:33
Hi, I have been trying to mill on my Myford S7 but have run into problems re. capacity and lack of ridgity. Not sure about going for a new machine probably from the east or an older used UK make. Any suggestions would be helpful thanks.
Thread: Super 7 cross-slide flex?
10/05/2015 11:44:54
Thanks for the input, I suspect a bit of swarf/debris, I'm sure it wouldn't need much. Both lathe and slide are not new so perhaps if a good clean does not sort it out then a thorough check for flatness.
EngineDIY
