Member postings for Paul Relf-Davies
Here is a list of all the postings Paul Relf-Davies has made in our forums. Click on a thread name to jump to the thread.
Thread: Jacobs model 6414 chuck - removal
27/10/2019 14:55:25
Thanks all for you input
27/10/2019 14:23:22
Thanks.. I'll give it ago....
That said, I have also come across some photos of old B&D literature/advertisements...It seems the HU-1 was first manufactured in 1946. I saw an ad dated1952 which exactly matches my model, as well as another dated 1955 showig the same drill but with a later type of chuck (the kind referred to above with the central locking bolt).
So it could be that the chuck on my drill is non-removable and that the lathe attachment was intended for the post '55 models of the drill...?
Regardless, I should be able to make up a driven center drill bit. It will just mean I will lose a couple of inches of lathe capacity.
27/10/2019 14:02:28
Posted by Clive Brown 1 on 27/10/2019 13:51:25:
Try putting say a hex. allen key in the chuck, or the chuck key, if it has one, in one of the 3 holes and giving it a whack. with a mallet. Don't overdo it though.
Just looked at the link, seems to be no key.
Edited By Clive Brown 1 on 27/10/2019 13:53:32
unfortunately not... this chuck has an intersting cam-locking mechanism. The 3 jaws are linked (held together) by rubber fillets. You insert your bit, and hand tighten the collar, then to lock it down, you use an alan key or screwdriver to turn a cam in the main body of the chuck., This pushes on the jaws, locking them against the conical collar. As a result, the cam operated face that pushes up on the jaws is where the locking bolt would be in the more common style of Jacobs chuck.
In this model however, as far as I can see, the chuck should just screw off, if I can just work out how the drill spindle shouid be locked...
27/10/2019 13:55:01
Posted by vintage engineer on 27/10/2019 13:48:25:
Does this help? **LINK**
alas no - I've already found that video...that is a completely different style of chuck...the model 6141 does not have any through bolt.
27/10/2019 13:36:24
I appreciate that is question isn't directly ME related, but it occurs to me that ME enthusiasts amy also have experience with antique tools.
I have a (1950s) Black and Decker model HU-1 power drill and the matching (contemporary - model. D7638) wood-lathe 'attachment'. One missing piece is the powered center, which would have replaced the chuck, when the drill was set up to power the lathe.
I see no rason why can't make a replacement, if not to the original design, at least such that it would all fit together & function.
The chuck (a Jacobs model 6141) is supposed to unscrrew from the the drill body and the lathe center screws on in its place.
My problem is that I can't see how to unscrew the chuck. There is no way to lock the spindle and I can't imagine that the user was required to disassemble the drill (to somehow grip the other end of the spindle) just to convert the drill for the lather.
Any ideas...?
If it helps, my chuch is identical to this one on eBay (except mine says made in Sheffield UK)
cheers
Paul
Thread: Small Volume PCB printers?
13/08/2019 08:17:55
Hi all,
Can anyone reccomend a service that will produce a small number of PCBs from an image of the tracks?
I have an existing PCB that has been damaged (missing the copper track*) and is no longer available.
I figure I can scan the PCB, 'fix' the defects, then if I need to find someone who can use the image as mask to produce a replacement PCB.
I'm sure there are companies out there who do this...looking for recommendations.
Thanks
Paul
*the damaged track is part of a spiral contact, so it needs to be both electrically conductive and smooth/accurately placed, so simply bridging the gap won't do.
Thread: Is this a bad idea...?
12/03/2019 21:44:10
Indeed. The plan will be for the gears to be in mesh all the time, but as has been mentioned, engaged/disengaged using a single-tooth dog clutch.
The extra 1/8" I found still allows for the gears to be meshed all the time.
I'll post some pictures when I'm done.
P.
12/03/2019 20:00:16
So..I've gone back and re-measured things.
The shaft the tumbler output 'twin' runs on (and the spindle holding the 2 gears) is an 1 1/8" long. I think there is enough clearance beyond that (before there is a risk of interfering with any change gear combo) to increase the spacing between the 2 gears from 3/8" to 1/2". I think that would give enough space to fit a clutch of some sort.
It certainly should prove an interesting little project.
P.
12/03/2019 14:36:19
Thanks Hopper.. I have read all I can fin on Graham Meek's (elegant) design.... but I think it would need a complete re-design to have ant hope of fitting to my lathe....
It was actually Martin Cleeve's March '77 article in ME that got me thinking on this in the first place...
What I'd really like to see are more detailed pictures of the dog clutch on the ML7 that were in that article. They seem to show the clutch operating mechanism on the outside of the gear pair, rather than between the gears, which would seem to give more 'wiggle' to, but I imagine could limit the change gear combination that you could use...?
P.
12/03/2019 12:55:07
Hi all,
I have a small screw-cutting lathe (similar-ish to an ML7, without the gearbox) and I've been pondering how to improve accuracy, repeat-ability & simplify screw-cutting. Specifically, how to automatically stop the saddle at a the same point on multiple passes.
I did a fair bit of research and have found numerous references & articles talking about de-coupling the change gears from the tumbler with a single-tooth dog clutch.
As far as I can see, the primary facility that these dog-clutch assemblies offer is the ability to dis-engage & re-engage the timing gears while the motor is running. The point (assume) being that the dog tooth in the clutch assembly is stronger than the gear teeth, and is therefore un/less likely to break when the gears are re-engage, while the motor is running...?
So...to my (potentially bad?) idea...
My requirement is to be able to automatically dis-engage the timing gears only. I'm happy to re-set things manually. As such, I wonder if I even need to add a dog-clutch assembly?....Could I just add a trigger to disengage the existing tumbler mechanism at a repeatable point each pass?
I guess the bottom line is this: while I appreciate that there is a risk of damage if the tumbler gears are engaged with the lathe spindle turning, is there a similar risk when dis-engaging them with the lathe spindle turning?
BTW - the reason for this train of thought is that the shaft that the tumbler output gear & the timing gear chain input gear is 1) very short - about 3 gear-widths long and 2) acts as the pivot for the tumbler-actuation lever.
I'm sure I could design something to fit, but it occurred to me that there might be a simpler approach
Any thoughts, much appreciated!
cheers
Paul
Thread: combining dis-similar DC power supplies
07/03/2019 19:15:46
Thanks for your replies...
I had a sneaking suspicion that would be the outcome. Fortunately, for the project at hand, I only need +5v and +12v, for which my donor PSU can supply far more current than i actually need.
I was simply curious as I can envisage that the additional potential combinations to be gained could have been useful for future projects.
Thanks again
Paul
07/03/2019 17:19:35
Hi all,
I'm building a bench PSU to support a project in relation to my mill (power for a 3-axis DRO and a powered X-Axis (using an old car wiper motor) & my rusty O-level electronics has failed me blush.
I'm making use of an old but usable PC PSU, which will give various voltages: 3.3v as well as +/-5 &12v.
Given these, I should be able to 'make up' other voltages, for instance +12v & -12v should give a 24v supply.
However, my question is this: Were I to combine 2 supply lines with differing max current outputs, how do I calculate the resultant max current?
In the example above, the +12v supply can deliver up to 15A, but the -12v is only rated up to 0.5A. Were I to combine these to give 24v, what would be the max current I could expect to draw?
I'm sure there is a simple formula...it just escapes me!
cheers
Paul
Thread: Welding helmet
25/02/2019 12:50:07
I bought a 'Tacklife PAH03D' (LINK) from Amazon a few months back. it's currently about £50. It seems extremely good. It is very comfortable & the view you get of work is excellent.
P.
Thread: Sources of 1" bore involute gear cutters..?
14/02/2019 13:30:20
Posted by Brian H on 14/02/2019 13:14:41:
Clock gears are normally a different profile from the involute ones.
Indeed.. I seem to recall reading about cycloidal gears...?
TBH,this is purely experimental.. I'm starting from a set of plans for a wooden clock (ie just a cutting list - no explicit specification of the tooth profile on the wheels) and trying to tweak it to meet the limits of the tools & have (the largest wheel on the plan is 12" is diameter - there is no way I can make that!!.
This is more a learning exercise (in terms of machining techniques) than a requirement to build a particular thing...it's be nice to have a 'thing' at the end of the process!
I'm working on the theory that the this point in time, my limitations as a machinist will far out weigh the 'incorrectness' of cutting involute teeth, rather than some other variety (cycloidal?)
cheers
Paul
14/02/2019 12:44:09
Thanks all, for your input!
I think a new 22mm arbour & a set of 'eBay specials' is the way simplest forward
They will initially be used to cut the wheels for a simple clock, though I can see change-gear cutting duty i the future too.
cheers
Paul
14/02/2019 10:30:42
Hi All,
I'm looking for a selection of involute gear cutters. I have a suitable arbour with a 1" bore (originally bought to use with slitting saws). Unfortunately I'm struggling to find a source of suitable & reasonably priced cutters to fit this arbour.
Ebay seems awash with cutters with 22mm bores in the profiles I need, at around £9 each
RDG sells then with a 1" bore at about £25 each
That seems to be about it in the ME world, as far as I can find - at least in the cutter profiles I'm after (M2.0)
The bottom line is it would be cheaper for me to buy the cutters from eBay, plus a new 22mm arbour, than to buy from RDG (and and use my existing arbour)
So...
  1. Are RDG's cutters worth the premium price - given I don't imagine they's see that much use...
  2. Does anyone know of any other suppliers of involute cutters with a 1" bore at a more eBay-like price?
I don't object to buying the smaller cutters & a new arbour. or paying extra for the larger cutters, if they represent a significant quality improvement..I'm just interested in exploring as many options as possible
TY
Paul
Thread: One off castings
08/02/2019 16:33:59
If you're handy with a computer, you could design a 'virtual' casting plug and then get it 3D printed in metal...?
Paul
Thread: Dore westbury mk1
30/01/2019 17:18:12
I'd concur. Its a quiet group, but extremely knowledgeable & willing to lend good advice.
P.
Thread: Hi from North Yorkshire
29/01/2019 14:45:52
Welcome
P.
Thread: Uncomplicated Steam Boiler for first wobbler please
29/01/2019 12:56:39
I'm not sure where you are based, but you could do a lot worse than to sign up for the Society of Model & Experimental Engineers' 'Polly' course, starting in May (in South London).
You will end up marvellous little vertical boiler & wobbler engine, plus get a great grounding in a wide range of model engineering techniques.
The ability to ask questions & get feedback on on you progress - plus getting your boiler properly pressure tested - is invaluable. You can't get that from books & videos
P.
Full disclosure: I built this on the course last year...
Edited By Paul Davies on 29/01/2019 12:59:50
EngineDIY
