Member postings for Jonathan Garside
Here is a list of all the postings Jonathan Garside has made in our forums. Click on a thread name to jump to the thread.
Thread: A nice find
05/12/2021 13:50:12
Martin
The Starrett is more likely to be a 2"-8" internal micrometer rather than a bore mic.
As regards Shardlow I have a 0"-4" outside mic. They were quality manufacturers in their day
Jonathan
Thread: LMS 6202 Turbine Locomotive
27/07/2021 10:41:38
Greensands
You could try the book The LMS Turbomotive by Jeremy Clements and Kevin Robertson published by Crecy.Publishing in 2016
Jonathan
Thread: Alfred Herbert No.2 SafeTap
27/05/2021 11:27:20
Martin
If you searched under Alfred Herbert Saftap tapping attachment you may have more luck
Jonathan
Thread: Identifying a Parker Hale thread size.
19/04/2021 12:15:03
Just a thought British Brass thread 1/4" is 26 tpi x 55 deg may suit better than cycle 60 deg thread
Jonathan
Thread: Magazines, Newspapers, etc
18/02/2021 14:11:11
DMB
The answer to your query is BRAD (British Rate and Data)
It is published monthly and is the go to for all mediia information
Jonathan
Thread: Collector's Item
23/10/2020 21:38:13
£565,000 and cannot even spell metre !!
Thread: Jones and Shipman 540 surface grinder serial number ID?
04/08/2020 22:22:19
Donovan
Your machine serial number dates it to between Dec 1971 (72000) and Feb 1973 (74000)
The first 2 digits do not refer to the date of manufacture that would be far to easy.
Hope this helps
Jonathan
Thread: Archdale Horizontal Milling Machine
11/04/2020 17:57:05
Ghost
I do not have an Archdale mill I was merely advising you of the type and age from my machine tool serial number records.
If you go onto the www.vintagemachinery.org website and search for Archdale or James Archdale they have a downloadable pdf of a sales leaflet which includes horizontal milling machines.
As Andrew says above I do not think Archdales ever made a vertical head for these machines as there do not appear to be any attachment points or suitable drive mechanisms.
Just as a matter of interest I was part of the Auction team that sold the Blackpole, Worcester works of James Archdale in 1973/4. Archdales were by this time part of Staveley Industries who had bought a whole tranche of British Machine Tool manufacturers in the 1950s and 1960s but managed to close the vast majority by the 1980s.
Jonathan
11/04/2020 10:12:03
Ghost
First of all the manufacturers plate starts with HM and in the simple Archdale terminology this stands for Horizontal Milling. Consequently it is highly unlikely you could fit a vertical head without reconfiguring the machine and drive.
Secondly the serial number of 1906 would make it well pre WW2. My serial number reference book has a number of 4096 for 1940. They would appear to have manufactured approx 500 machines of this type per year so that would make your machine to be approx mid thirties..
Hope this helps a little
Jonathan
Thread: 4x6 bandsaw
18/01/2020 15:25:25
Steve
If you put 6" x 4" bandsaw you tube into google you will be inundated with videos of what you are looking for
Jonathan
Thread: Old Brown & Sharpe dividing head
09/01/2020 19:26:13
David
If you search the vintagemachinery.org website you will find lots of info on Brown (no e) & Sharpe incl reprints of their dividing head instruction manualls.
A fantastic website
Jonathan
Thread: Hello
30/10/2019 14:02:01
Marcus tells us bhe is from Todmorden in West Yorkshire in his second sentence.
Welcome Marcus
Jonathan
Thread: broken calipers
03/04/2019 15:21:27
M Machine Metals list 3/4" x 16 swg which is 1.6 mm spring steel strip at £3 per 300 mm.
Jonathan
Thread: Warco 918 Lathe Tumbler Reverse
13/02/2019 14:17:53
Thanks John, PM sent
Jonathan
12/02/2019 20:09:44
Thanks for your replies and I will investigate further the information you have kindly provided.
Jonathan
12/02/2019 11:10:16
Andy
I cannot post a link as the only info I have ia a very poor photocopy of the original article as detailed in my first post..
If you can find the original copy of ME dated 1st Jan 1993 I would be grateful for a better copy myself as I cannot read all the measurements in the poor copy I have.
Jonathan
12/02/2019 08:54:47
What nobody?
Jonathan
10/02/2019 21:57:46
I have a Warco 918 and recently saw an article from ME 1 Jan 1993 by J F E Weight about the design and manufacture of a tumbler reverse mechanism.
Has anyone on the forum made such a unit to the drawings in the article, and if so how did it go. I am looking at any problems or pitfalls, or was it straightforward to make and does it work satisfactorily.
Jonathan Garside
Thread: Stanley - Quality?
03/08/2018 20:14:19
I rarely post as my posting number will attest and I do not get involved in political discussions but before you close this post may I have a say. I used to work for a firm of industrial auctioneers nationally for over 50 years so have some knowledge, and I can assure you that the greatest number of large industrial concerns closing was in the 1960s and 1970s well before Mrs Thatcher became PM. And before you jump to any conclusions I am no Thatcher apologist. before any member on this forum posts regarding this period of British Industrial history it would be as well to do their homework and check on when major industries actually closed rather than blaming it all on one person. I was there and I saw the reduction of industry through a lack of investment and a lack of care by ALL political parties. .Just remember the folly of nationalisation of the steel and aircraft industry not to mention the creation of British Leyland. All well before Mrs Thatcher. In most cases it was a lack of investment in new technology and poor marketing. Who remembers the introduction of the latest super British Leyland motor Car the Allegro with the Quartic steering wheel need I say more.
Jonathan
Thread: D profile tube
29/10/2017 15:33:26
www.vintagecarparts.co.uk sell 19mm x 10mm D shaped steel tubing
Jonathan
JD Metals
walker midge
rapid Direct
