Member postings for celso ari schlichting
Here is a list of all the postings celso ari schlichting has made in our forums. Click on a thread name to jump to the thread.
Thread: Tool post grinder step by step part final
13/11/2021 22:51:21
Posted by peak4 on 12/11/2021 15:30:27:
Lovely job, but a couple of comments from a less experienced machinist (me )
Do you have any paper/cardboard washers each side of the grinding wheel (hard to tell from the video), and maybe consider using paper towels and a bit of masking tape, rather than cloths to protect the bed from the grinding dust.
If a gust of wind from an open window catches the cloth and blows it into the chuck, it could get messy.
I always like watching your videos
All the best
Bill
Edited By peak4 on 12/11/2021 15:31:39
I used cloth soaked in cutting oil. I thought about using paper, but I was afraid of the sparks coming from the grinding wheel...
But thanks for the advice, maybe I'll get you a leather coverall,
A big hug from your friend from Brazil
Celso Ari
12/11/2021 14:57:36
Posted by David George 1 on 11/11/2021 22:42:04:
Very good job.
David
Thanks David
11/11/2021 22:02:09
Last video of the construction of tool post grinder
https://youtu.be/cOijnfpsKys
Greetings from Brazil
Celso Ari
21/10/2021 23:32:02
how i made a tool post grinder step by step
https://youtu.be/4rk_PKS2J8E
Celso Ari
Thread: big jaws for my milling vise
16/10/2021 18:35:46
How I made a couple jaws for my milling vise. And drilling tips:
Thread: parting tool for small lathe
22/12/2020 19:27:55
how i made this tool:
https://youtu.be/mUjkuTcNfIc
greetings from Brazil
Celso Ari
Thread: Professional Rotary Broach
22/12/2020 19:24:31
Posted by Steviegtr on 19/12/2020 20:58:09:
Hi Celso. Brilliant work as usual. Hope you are staying safe over in Brazil.
Steve.
Hi Steve, here we are taking care,
I know that the situation in England is worrying.
I wish that soon everything ends
Take care friend
Celso Ari
Edited By celso ari schlichting on 22/12/2020 19:25:56
19/12/2020 20:15:40
Posted by David George 1 on 14/12/2020 17:27:14:
Hi Celso nice work wish I had one, will have to look at making one.
David
Thanks David, greetings from Brazil
Celso Ari
13/12/2020 19:54:49
How i made this professional rotary broach:
[url]https://youtu.be/f9yH-Rg-nH4[/url]
Thread: die and taper helper (DIY)
24/07/2020 21:27:22
How i made this tool (DIY) die and taper helper:
https://youtu.be/8FWlVpRnlcU
Celso Ari
Thread: DIY tangential tool | Diamond Tool Holder and plans in video description
17/07/2020 21:31:10
How i made my tangential tool / Diamond Tool Holder:
https://youtu.be/3GN1U06cxDU
Thread: simple tongs
13/07/2020 23:16:55
Posted by Michael Gilligan on 12/07/2020 18:30:06:
The best translator I have found is DeepL
O melhor tradutor que encontrei é DeepL
Edited By Michael Gilligan on 12/07/2020 18:31:21
Michael, i will definitely use it soon, thanks for sharing
13/07/2020 23:15:19
Posted by Bill Dawes on 12/07/2020 13:21:11:
Well done, greetings from Somerset in the UK. Something I have been thinking about for a while so this has given me some inspiration, It is about time i used my welder I have buried in the back of the garage, never used it enough to get past the stick welding itself to the job! Thank you for sharing, interesting to see how many different parts of the world we get posts from on this forum.
Best regards
Bill D.
Bill, a welding job always helps in completing a project and is one of the things that I use a lot in the workshop
Cheers
Celso Ari
13/07/2020 23:12:45
Posted by DMB on 11/07/2020 22:22:00:
Celso Ari,
Just watched your youtube on making tongs. Thanks for sharing. I like your design of the joint, might make a set of tongs using your design.
Thanks John, I'm glad you liked it ... a big hug from Brazil
11/07/2020 21:22:41
Posted by Grizzly bear on 11/07/2020 18:50:34:
Very good, you made it look easy. But many operations.
I too liked the pivot.
Do you read the English OK, or do you translate?
Regards, Bear..
Dear friend Bear, I understand a little English, I get a little confused when people
use slang or very technical or specific words, except that I can communicate
reasonably well
11/07/2020 21:18:08
Posted by IanT on 11/07/2020 10:16:10:
I liked the small welded fabrication aspect Celso, simple MMA and it looked vey good after grinding. The oil quench was a bit hairy - definitely an outside job.
A well made and useful Blacksmiths tool though. Well done and thank you for sharing!
IanT
Thanks Ian...Regards from Brazil
10/07/2020 21:44:08
how i make this simple tongs:
https://youtu.be/O1FS9KktKH4
Celso Ari
Thread: apprentice vise
04/07/2020 21:32:45
Posted by geoff walker 1 on 04/07/2020 20:32:22:
Yeah Celso, freedom come tonight, great music.........and the vice is great as well, very useful
Geoff
..thanks Bro...greetings from Brazil
04/07/2020 21:32:07
Posted by Simon Collier on 03/07/2020 23:18:47:
Beautiful work and great video as usual Celso.
Thanks friend Simon
03/07/2020 21:43:54
I needed to build a diamond tool holder, and 12 degree inclination for each side was necessary, so I decided to build this vise to help me with the next project
https://youtu.be/r6bU8Kh3jJU
Celso Ari
MIDLNDS GARDEN RAIL Jan 2022
rapid Direct
JD Metals
