Member postings for David Standing 1
Here is a list of all the postings David Standing 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: ER40 square collets
13/04/2017 23:59:16
Posted by John Haine on 13/04/2017 17:14:50:
David, not sure why it's interesting, but it isn't a shank it just fits on the Super 7 spindle nose.
I asked because you can get a square section holding 5c collet plus a cnc collet holding bushing with a parallel shank, but unfortunately the bushing is too big to go in an ER32 collet.
Thread: Parafin blowlamp
13/04/2017 23:47:47
Posted by Henry Artist on 13/04/2017 21:50:26:
I still use blowlamps for some jobs. Gas torches are very convenient for most soldering and brazing tasks but for boilermaking the soft bushy flame of a blowlamp is wonderful for getting heat into the copper.
I use modern blowlamps rather than antiques. Yes, they are still made because butane and propane gas are not readily available in all parts of the world.
The blowlamps I use are made by Motor Sich. They are made from steel and while they are primarily designed to use gasoline, by changing the jet size kerosene can be used as an alternative fuel.
The very comprehensive instructions include not only how to use the lamp but also maintenance, troubleshooting, and complete testing procedures. Helpfully, they are bilingual being written in both Ukrainian and Russian. thumbs up
Those of a nervous disposition who have only ever used butane powered DIY gas torches may find a sudden and pressing need to change their underwear when using one of these for the first time...
Now that's what I call a proper blowlamp! smile d
13/04/2017 23:46:55
Posted by Bazyle on 24/01/2016 23:09:13:
If the valve chamber is brass and it didn't free when sitting in paraffin then I don't think that WD40 will help. Instead tap the joint maybe with a brass bar keep tapping and it will break open the joint.
Or apply heat......with a blowlamp wink 2
And yes, WD40 is crap as a release agent.  I'd douse it in Plus Gas.
Edited By David Standing 1 on 13/04/2017 23:49:38
13/04/2017 16:37:33
What shank is your ER40 collet holder?
Thread: Encouraging new hobbyists
07/04/2017 10:26:13
Posted by Bazyle on 06/04/2017 23:40:52:
One advantage of model boats is that all of the bodywork is just wood so does not require much machinery and the flywheel is probably under 2 in diameter. Even a Super Adept can make a marine engine.
And, according to some, the Super Adept can also double up as the anchor wink 2 devil
Thread: Run out on a rotary table
30/03/2017 11:55:42
Posted by Journeyman on 30/03/2017 11:52:03:
Dave, I think you will find that those slots are for fitting keys to align the rotary table to the mill table without the need for measuring or setting up. Clip from the Grizzly/Vertex manual:-
** Manual Link **
Edited By Journeyman on 30/03/2017 11:54:52
You realise that just made Dave now unemployable until 2090? wink 2.
30/03/2017 10:39:17
Posted by SillyOldDuffer on 30/03/2017 10:20:54:
Posted by David Standing 1 on 29/03/2017 23:03:45:
Personally, if the workpiece is unsupported at the other end (and better practice even if it is), I would never use a rotary table just being clamped to the mill table by the base, even with a clamp on the back as well, as there are lots of leverage forces at play.
As well as the RT being clamped to the mill table, I would use a big angle plate or box big enough to also reach the top flange mount of the RT and clamp it there, as well as to the table.
Supporting the workpiece at the other end would probably cure most of the issues, but it still offends my engineering eye to see a RT just clamped near the table like that.
Not a criticism as such, just an observation wink
Excellent! I hadn't thought of doing that.
Reinforcing the sense of David's suggestion, although I successfully jammed a rear clamp into the groove at the back of the table, I don't think the slot is intended for that purpose. It's only about 5mm deep and using it didn't feel quite right.
The only down side is that I don't have a box or angle big enough to reach the top flange. On no! Another new entry on my ever growing 'to-do' list.
Many thanks,
I've got a WM18 and an HV6 RT, but I have never used it on its side. If I ever do, I might need a big angle plate or box too! smile p.
Thread: What Did You Do Today (2017)
30/03/2017 10:10:34
Posted by Martin Kyte on 30/03/2017 10:06:24:
Day length is approx 10 1/4 earth hours and there are 9749502 1/2 days in the year. It doesn't appear to have a moon so there are no months. All this means you don't get many Christmas prezzies and if you received 12 MEW's per year you would get a new editor each time. At least you would have plenty of time to complete the bit of your serialized project before the next one turned up (with or without the corrections)
:0)
Martin
And at 812,458 days per month equivalent, Neil would have plenty of time to check the print magazine had the right issue number on wink 2.
29/03/2017 23:03:45
Thread: What to buy next??
29/03/2017 22:37:01
Posted by duncan webster on 29/03/2017 19:46:51:
If you want to work to thous, don't rely on digi calipers, buy a micrometer
Or just get some decent digital calipers wink 2.
Thread: 3-phase to single phase
27/03/2017 18:21:47
Posted by Bob Brown 1 on 27/03/2017 18:15:29:
It begs the question why are they scrapping it?
I think the answer may be in line two of post one wink
Thread: Poor cutting
22/03/2017 15:08:33
Curtis
Got your PM, thanks.
Will call you in the next evening or two.
In the meantime, what I would suggest is that rather than replace the brass with a piece of mild steel and trying the tangential tool on that as has been suggested; I would keep the piece of brass in the chuck, but replace the tangential tool with a conventional tool and holder, and try facing the brass off with that - and, as has been suggested, preferably with a round nosed tool.
The reason for this is because it will then show up whether or not there is a problem with the tangential tool/holder, or an issue with the lathe, such as spindle or slide/gib wear.
I am also assuming that the tool tip was centred on the brass?
21/03/2017 22:45:56
Posted by Curtis Rutter on 21/03/2017 22:41:40:
Posted by David Standing 1 on 21/03/2017 21:37:59:
So here's an even more off the wall suggestion - is the tool holder contacting the brass?!
It's definitely not I'm paranoid about that! I'm located in Ware, Hertfordshire, UK
Ok!
I'm regularly in Stansted Abbots, would be happy to cast another pair of eyes over it, it's often much easier to diagnose these things when you can see them before your eyes?
21/03/2017 22:28:52
Curtis, where are you located?
21/03/2017 21:37:59
21/03/2017 18:16:55
I am guessing that the marks across the face are made by the cutting tool being dragged across the face of the brass after the spindle has stopped.
I'm also guessing that the circumferential marks are made by the cutting tool being advanced into the material when it is stationary, then the lathe is being switched on.
Thread: Machinery removals
20/03/2017 21:00:02
Posted by Martin Connelly on 20/03/2017 15:07:12:
Muzzer the term for looping slings over hooks or through shackles or lifting eyes is reeving. It is a big no no in the eyes of anyone with any lifting training since it is easy for a load with a high or offset centre of gravity to start to move with the result so aptly shown in your photo.
Martin C
That second example is almost as bad as the first!
A spreader bar should be used in those circumstances, so there is a straight lift on the eye bolts, not introducing side forces on the eye bolt threads, as the example shown would.
Thread: Milling - What am I doing wrong
16/03/2017 19:00:10
Posted by petro1head on 16/03/2017 18:48:58:
Well, for those who were skeptical .................................................
Edited By petro1head on 16/03/2017 18:49:36
Oh God, have you just edited out another Seasick Steve video? wink 2 surprise.
Thread: Warco WM18 has arrived
09/03/2017 13:09:14
Posted by petro1head on 09/03/2017 09:57:20:
Crumbs, you must have patience of a saint
Tell me about it. I've prioritised my jobs, and sorting the workshop has to wait, probably until around June-July, so not far off now cool.
09/03/2017 13:07:39
Posted by Scrumpy on 09/03/2017 12:21:02:
Blow the garage for the car swarf needs to be made if you leave the machines outside covered over a light coating of rust will start then you will spend all your time cleaning and no swarf
You must live in a crime free area as around were I live a machines would be gone by know
Machines are in the garage, car lives outside, despite the fact that is my pride and joy too, and also highly nickable wink 2.
I'm also in a rural area in the middle of nowhere wink.
EngineDIY
