Member postings for vic francis
Here is a list of all the postings vic francis has made in our forums. Click on a thread name to jump to the thread.
Thread: Landilift
07/05/2022 19:45:49
Hi I emailed landylift twice in the past for two different machine moves, and called him, and never received a reply.... not sure I would bother in all honesty. Hard to find reliable guys at times.
Good luck
vic
Thread: Pride of Penrhyn Steam Wagon drawing and construction notes
10/04/2022 05:01:11
Hi Neil, Julia Old did a extensive build of one of these engines, doing necessary mods to make the engine work. She is on traction talk forum.The series was published on her web site years ago, not sure if I still have it but I will look. She has gradually moved up in scale to little Samson 6 inch scale engine. So is well qualified. I think this engine is based on the Robey steam wagon.The boilers were good, commercially made, but some of the engineering needs work.This wagon was better than some of the locos, I have the tiger tank.! Made by them which is basic compared to armourtek now.
I think she stiffened the road springs as we lack of ground clearance with driver on it.
Vic
Thread: Steel tyres on alloy rims
28/01/2022 08:04:49
Fine advice from old mart! Precision models left outside , well I have seen a few suffer this sad fate; the damp shed... perhaps due to various unfortunate circumstances.I have a couple as well; it is the metalwork which needs thought, I wondered about plating , or lacquer coat. I have a gm showmans which had this fate of the damp shed... took alot to get it reasonable, but the metalwork has some staining / pitting ... anyway a coat of lacquer, but what type ? Seen it flake badly in time. What do you chaps think?
keep the good work going Jon!
regards
vic
Thread: Help please with inherited items
10/01/2022 14:13:10
Posted by br on 03/01/2022 17:32:23:
I would happily I would bid £1500 for the plant and £3500 for the Allchin for two such fine items
I would initially try them on ebay with the above figures as your reserve price.
SRS are currently listing a comparable Allchin at £4750, but that comes with new certificates which enhances the price.
Edited By br on 03/01/2022 17:35:35
That is a honest valuation 👍so I would second that Bill! The Royal Chester is finely made, even the padlock! Err spare key anyone??
regards vic
Thread: electronic cylinder indication
07/08/2021 20:53:36
Great work Werner!!
And utube explanation! I wondered why at the rhs end the graph line dips down , and bounces back up... ? What was causing that do you think?
Have you tried this on your Fabulous Fire King Fire Engine yet? With or with out the Turbinators in operation? From the utube videos your machine looked spot on perfect already! Certainly clean running, and long runs!!
Vic
Thread: Another Stolen Loco
21/06/2021 18:27:28
Hi Paul, Thank you for the worrying update as regards Mr Day’s Sentinel; I shall keep a lookout even if it was repainted the high quality of the Sentinel would be hard to disguise. Would Mr Day make another Sentinel to replace? I wonder?I am lost for words about the situation.
regards
Vic
21/06/2021 18:25:54
regards
Vic
13/06/2021 17:31:49
Hi That is sad news; also does anyone know if Mr Day who built the superb 4 inch Sentinel steam waggon( see cover of me 4557) got it recovered,? That was sometime ago ...As I understand it the crooks were definitely professional as it was well secured and in a trailer, front drive ect I can understand that being a professional job and with limited copper value on it, but special built Rare item,but for a Maxitrak r1 with a 70 lb ? copper boiler seems a bit wild... even if it was £2 a lb scrap copper value... it would not add up to a lot... it is a bit confusing really... a worry all the same...perhaps things will get worse now, with economic downturn...?
vic
Thread: Advice on moving an Archdale radial drill
03/06/2021 23:59:08
Hi , well done 👌on moving such a beast! Ok it is a very good thing about spindle breaking in case of the work breaking free; however I would bolt a safety stop fixing on the bed , using more than one tee slot as well... I did see a video ; whereby the long bar material being drilled ( large hole) snagged broke free and hit the operator ,mid torso. Like a scything motion, only stopping when at the main column...Very sadly it was fatal. If he had a mechanical safety stop he would have survived, and bought time... I have seen a few milling damaged tables with tee slots broken, and often wondered what happened....
So safe working and Please show us what work you can do on such a fine versatile machine? Maybe fullsize traction engine parts??
ps it looks more than 1.2 tons!!
Vic
Thread: Modded 1" Minnie Progress
31/05/2021 15:49:58
Great work of art ,Richard Forget the mower restoration!let the grass grow long!!
Vic
Thread: cl500m milling & drilling
31/05/2021 15:18:54
Hi Danni, Have you the cast iron milling table which bolts to the cross slide? , if so mount your vice on it! Then measure your material diameter, and put it in the vice , put your milling chuck in the mill head and tighten the draw bar. Select the cutter and note the size, so for example two cutting edges for a blind hole for example. Moisten a small strip of rizla paper to the outside of the bar, then start the machine and slowly advance to the outside of the bar, the paper will be caught on the os of the cutter, then all you do is raise the head on the quill handle, retracting the cutter.Zero or note the dial reading on the cross slide,and you need to move 1/2 the diam of your cutter, plus 1/2 the diam of your material diam . Then you will be on the centre line of your material!That is a old fashioned way, but the mounting of a digital display makes light work of it! Even a inexpensive digital calliper display... msg me if you want info ...
ps it is better to mount the work on the table and vice than in the 3j chuck limitations !
regards
vic
Thread: david king engineer from norwich
28/04/2021 15:04:24
Hi there is a mention of a newton coil boiler in a old ME; vol 186 issue 4139 page 129, but unfortunately I dont have that issue to be able to say any more...
regards
vic
Thread: Horizontal Bandsaw Problems - -Advice Please.
22/04/2021 10:51:48
Hi Nigel, speedy recovery, err well I used said bandsaw, think it was a pinacle? Early 4.5 hori / vertical typical design but after experimentation in setting esp the crown wheel used it alot ie daily! And with the thin cork on the lower drive wheel it hardly broke any blades, perhaps one per year! I used very little blade tension.... so blades lasted a long time, unless snagged...and a reasonable downcut pressure to avoid rubbing.I used it for 6 years plus as well! It came from another dept so it was second hand .Useable when I got it as well.I always cut dry or friction would be lost...The procurement woman was tight about buying things, ( packs of blades) so I made sure things lasted! The sort of work it did was bar and tube upto 30mm ; I once cut 70mm bronze bar ! But best to turn it...There is a quality difference between blades, the thicker blade was superior, and fine pitch was preferred. The workshop was too small to have a decent cutoff type so I made do... I also improved the work holding clamp... Evo stick glued the cork to the wheel... I tried rubber originally, but creep occurred! , cork was the best; boiler insulation would be perfect around 2mm thick.
regards
vic
Thread: Boiler number
19/04/2021 12:21:49
Hi Robert ,White rose was a club in the leeds area, as mentioned above,operated around 1984, looked to have a road vehicle bias to its members, found some refs vol 154 3742. I have a Sent you a message!
regards vic
08/04/2021 19:39:36
Hi Nigel, I had the similar bandsaw; I found that a thin layer of cork glued onto the drive wheel gave friction and cushioning drive... not only did the blades last longer and needed far less tension... but always cut material dry...
vic
Thread: Tom Senior s head alternatives?
05/04/2021 14:50:20
Hi everyone , and thankyou for the useful suggestions! The overarm mounting is not a route I would go having tried that wth the Bartlett head idea, when mounted on the arm droop is present! Centec mk2 head looked possible, just the drive motor issues and mounts; even a cl500clarke mill head... as mounted ontop of the M1 machine column.
Alan Jacksons work and solutions is outstanding; , and thank him for the pictures here and The mew article I now have!
thanks
vic
Thread: Antique gun springs
04/04/2021 06:55:44
Hi Bob, sent a message;, err it will break in time, or be difficult to get the correct strength required... the section would also need care re shaping , not to mention hardening and tempering.What caused the break ?was it someone trying to to remove the spring without skill or material defect or working fault? The taper of the material is very important ! Regards vic
01/04/2021 21:22:43
Posted by Alan Jackson on 01/04/2021 18:30:23:
Buffer,
I did spend some time when I first got the machines. I stripped them down to basic parts and I think I spent some time cleaning them up. I do use them though they are not just like that all the time, and the photos were taken after a good clean up. I know what you mean about the dull brown look, but I love the look of these great british machines.
Alan
Hi Alan and Buffer, thanks for the great ideas! Alan great work ! Lovely Design idea, I shall track down the mew issue! Your swivel head design is most useful feature as well. Thanks for sharing the idea.
01/04/2021 09:33:54
Thanks “buffer” yes I have seen that , its a useful idea about column raising... Yes you are right the senior head; I have had a few tries at buying one even buying one at ebay and then someone else buying it privately at the end ;I even considered buying a whole machine but the head was very worn...
thanks for your reply👍
01/04/2021 09:08:06
Hi I am fond on the Tom Senior m1 but mine only came with the knuckle head, and though it works fine, it has limited clearance in use,I have seen bport milling heads grafted on, or the actual senior main column raised upwards, and various other ideas such as the Bartlett milling head which mounts on arbor support ( which is just not accurate enough due to droop!) nor has it a quill feed...
I only do light work but need more clearance so any ideas appreciated! Has anyone tried these far east milling spindles? Senior heads are rarer than hens teeth, some people just buy a machine for one!
The top of m1 is not machined? So any mounting on top is a bit hit or miss! I am not moving another mill ! Which would be the best solution....
Any ideas appreciated! Or what you have done!
thanks vic
Rapid RC
Dreweatts
