Member postings for thaiguzzi
Here is a list of all the postings thaiguzzi has made in our forums. Click on a thread name to jump to the thread.
Thread: A sight for sore eyes
27/03/2020 08:59:58
Posted by Steviegtr on 26/03/2020 23:08:42:
I saw one similar of an Asian woman rendering a wall. It was on a staircase. A right grafter.
Steve.
Common throughout Asia, and particularly SE Asia to have more women than men in most labouring jobs on site inc, to name just a few, tilers, roofers, plumbers, brick layers, rebar tying in, tarmac layers etc etc etc.
Go into ironmongers or an independent auto factors, or a steel stockholders, (yeah, remember them?), and quite often, the main person at the desk for all orders is a woman.
Thread: Using EZELAP sharpeners
22/03/2020 09:51:41
Honing yes, sharpening 1/4" HSS no, not really.
I find most of these hand held diamond sharpener thingies great for sharpening a knife in the kitchen, but certainly no better than a good honing stone in the workshop.
Thread: What are you reading?
20/03/2020 17:10:50
Posted by Neil Wyatt on 19/03/2020 17:46:16:
Yesterday I bought a copy of Wolf Hall (it was half the price of the new one, and I reckon I need to read them in order).
I'm sure some of us will be thinking this is a good time to tackle "Au Recherche du Temps Perdue" or "Ulysses" but perhaps there are some better suggestions for filling the hours?
So, what are forum members reading, engineering related or otherwise?
Hustler...
Thread: QCTP dilema?
20/03/2020 17:05:45
Posted by Graham Stoppani on 20/03/2020 06:00:53:
Last year I replaced my Dickson type tool holder with a wedge type one from ARC Eurotrade. Very happy with the new tool holder. My reason for changing was the old tool holder had too much play in it that allowed the tools to deflect downwards slightly while cutting. The wedge design by its nature takes up any slack when you tighten it which the Dickson type does not.
I like the wedge type too, mainly because extra toolholders are so easy to make.
But, re the Dickson design, i have to completely disagree. When clean and in tolerance, it is a great tool. I don;t baby my machines and have never had a problem, from my pro days 30 years ago with Colchesters to my current hobby days with a Boxford.
Clive as per usual, makes some very valid points above.
Thread: Does Silver Steel normally look like this?
19/03/2020 14:28:27
Posted by Thor on 19/03/2020 11:13:10:
Posted by Chris TickTock on 19/03/2020 11:00:22:
Just had it confirmed they are silver steel and apparently old Stubbs Stock...whatever that means.
Chris
Edited By Chris TickTock on 19/03/2020 11:00:38
Stubs used to make silver steel, seems the trademark is now owned by this company, more background info here.
Thor
Edited By Thor on 19/03/2020 11:14:52
A good read and a fwd thinking specialist company, thanx.
19/03/2020 14:24:20
Posted by Bo'sun on 19/03/2020 11:52:48:
Thank you all for the quick responses,
If I take quality and stupidly expensive out of the equation, does any particular design shine through? Although it sounds like not.
To answer one of the questions above, I intend to have about 7 tool holders.
I guarantee you will end up wanting more....
I started with 3 genuine, made another 10, then made another six, now 19 in total and i still want/need more...
Excluding a genuine 4 way i don't like using and a home made lantern that i do....
Thread: Lucky escape.
15/03/2020 07:31:27
Posted by not done it yet on 15/03/2020 00:20:20:
only a Wally
I came across one. He had not installed the propane bottles inside the house, but they were inside the attached garage. His local gas supplier/installer had words with him (I did not say anything to the fellow at the time as I did not want to fall out with him - but could not let it pass as un-noticed).
One can never rely on any isolation device unless it is designed as truly ‘fail-safe’.🙂. Many safety catches on guns only prevent the trigger being pulled - not preventing an accidental discharge due to a mechanism failure. Not many are aware of that.🙂
Ours is inside the house. Near to the cooker, in the kitchen.
Been that way 15 years and counting.
Also have a second LPG bottle outside, near to another cooker, in the outside 2nd kitchen.
I must be a wally too.
Thread: Way oil vs Chain bar oil vs motor oil
14/03/2020 08:21:40
I've said it before, i'll say it again.
If for whatever reason you cannot buy a 5 litre can of way oil, the next best thing, which is available everywhere that has tractors and large lorries, is ISO68 hydraulic oil. Cheap as chips and sold anywhere that sells agricultural parts, tractor parts and commercial vehicle parts.
Thread: Finally got the milling machine home.
14/03/2020 08:15:43
Nothing wrong with MT2 in a vertical head.
Maybe in horizontal sure.
Possibly why TS had INT30 in the horizontal and MT2 in the vertical in the majority of his machines, early M1's being MT3 in the horizontal, but always MT2 in the vertical.
I like MT2, use it in the mill, the HV 6" Vertex Rotab,the lathe headstock and tailstock, the T&CG, cuts down on different tooling taper requirements.
As some may know, i use my machines a lot, and don't baby any of them, i have never had a MT2 milling cutter holder come loose, and never had one come stuck in the quill feed TS head. Just common sense needed.
13/03/2020 14:17:47
I would'nt worry about leadscrew play, especially as you have a DRO. My TS M1 has about half a handle turn, no DRO and it has never bothered me.
I certainly would not want to fit ball screws to a TS LV.
Edited By thaiguzzi on 13/03/2020 14:19:19
Thread: What am i doing wrong
12/03/2020 13:22:27
1. Boring bar as big as fits in the hole.
2. Two hands or digits on the top slide hand wheel. Lock everything else down.
3. I prefer sharp HSS on anything inc internal tapered bores if i want a super finish.
4. Stating the bleedin' obvious - yes, on centre with the cutting edge every time.
Along with all of the above, and a smooth, well oiled, no slop movement on said top slide, i can get perfectly workable, wonderful finishes on 2MT internal tapers on a 51 year old Boxford.
TG.
Thread: Shaper Vice?
11/03/2020 08:28:57
Posted by John Olsen on 11/03/2020 02:35:02:
I just took a look at my shapers to see what is what. The 18 inch Alba has the arrangement that puts the screw under tension. The 10 inch Alba does not, the screw will be under compression. Those are both original vices. The Ammco shaper does not have an original vice, but I have the drawings and that would put the screw under compression.
I think the main feature of a shaper vice is that they are usually low profile.
I don't think that the cutting forces on a shaper are any higher than with anything else, the only point you should watch is when the cutting force is along the vice jaws, when it may move the job. A piece of paper between the jaws and the job is enough to prevent this.
This.
+1.
Thread: Old time equipment coating
10/03/2020 08:22:46
Should still be able to buy/order it from an authorized Harley Davidson shop, sold in aerosol form.
Not cheap, but the proper stuff.
Thread: Does anyone watch Ades workshop on you tube
10/03/2020 08:18:25
This.
All TS quill feed heads came with a 4 speed belt drive, 1/2 hp motor and you do not need anymore, nor was it designed to take a bigger motor.
I have one on my M1.
The M1 has the back gear facility on the horizontal which takes a 1 hp motor which also drives the table power feed.
You have a Light Vertical, a very nice mill, and better/sturdier than the E, the only drawback from the factory was they normally did'nt come with power feed to the table.
Thread: Coronavirus
09/03/2020 10:05:34
Posted by Kiwi Bloke on 08/03/2020 07:42:07:
Well, 'thread drift' has allowed this thread to reach rock bottom, so, unashamedly continuing the theme... Anyone who has tried to clean chocolate spread off the face of a toddler, using only dry tissues, soon discovers it's impossible and will appreciate the superior cleansing abilities of 'wet wipes'. Pity they clog up the sewage works. In fact, dry tissue is such a poor cleaner, it's not surprising that cultures which use water for 'personal cleansing' (or whatever the PC term is) look upon the western paper-wiping world with scorn.
This forum is a mine of information - perhaps someone can enlighten me, especially in view of the possible imminent paper shortage. Having been far abroad and seen milk bottles half-full of water in lower-class conveniences and small hand-held shower-heads on flexible hoses in more salubrious ones, how on earth is one supposed to use water instead of paper, without getting it everywhere? Such knowledge could be very useful soon...
Google Thai bum gun.
Toilet paper, and wiping one's arse with it, is oh so yesterday, and quite frankly rather filthy.
The West has a lot to learn when it comes to personal hygiene...
Thread: Powder coating
08/03/2020 08:07:58
Posted by vintage engineer on 07/03/2020 19:35:35:
At the end of the day YOU may call it what you like but it is plastic and it's cheap nasty crap product.
Try looking at the bottom of road sign posts and you will see how bad it is. The only finish that lasts on exterior steel work is galvanising!
Posted by thaiguzzi on 05/03/2020 14:41:16:
Posted by Joseph Noci 1 on 04/03/2020 06:43:41:
Posted by thaiguzzi on 04/03/2020 06:24:33:
Posted by vintage engineer on 03/03/2020 09:27:35:
Powder coating is a plastic coating despite what everyone tell you. It is a cheap and quick process that gives an excellent finish for manufacturers and does not last and will fail as soon as you break the surface!
Utter tosh.
And it is NOT PLASTIC coating.
Go and see how it is applicated in a finishing shop or factory, or even, heaven, forbid, watch a YT video.
Jeez.
Now THAT is close to utter Tosh! Really no need for such a frothy , esp if your facts are awry...
Of course it is a 'plastic' . That may be a loosely used generic term, but it fits.
a sound description:
There are two main categories of powder coating: thermosets and thermoplastics. The thermosetting variety incorporates a cross-linker into the formulation. When the powder is baked, it reacts with other chemical groups in the powder to polymerize, improving the performance properties. The thermoplastic variety does not undergo any additional actions during the baking process as it flows to form the final coating.
The most common polymers used are polyesters, polyurethanes, polyester-epoxies (known as hybrids).The latter is not common for general use, eg, garden furniture, household white goods, street signs, etc, but most often used in Marine and hi-demand/cost applications.
And as Model Engineers all know, polyesters, polyurethanes, etc fall under the category of engineering PLASTICS..
(jeez..)
Edited By Joseph Noci 1 on 04/03/2020 06:53:04
Whatever.
Was the other part he quoted utter tosh or not?
I would call powder coating powder, not plastic myself, but hey each to his own.
I aint that pedantic. Nor frothy.
Mmm, don't tell me, tell every major motorcycle manufacturer in the world who uses it on steel frames and swing arms and steel and alloy wheels.
They must all be wrong too, and have huge warranty problems replacing all that powder paintwork constantly.
Geez.
Thread: Hello
07/03/2020 14:27:56
Hello.
Both your bikes are wonderful machines when mechanically sound, i am familiar with both, the ES2 is one of THE GREAT ENGLISH singles.
79 T140 owned from new
89 Guzzi Cali lll owned since the late 90's
2 x off 84 Yamaha ty250 mono trials bikes
All very non std.
69 Boxford VSL lathe fully tooled
73 Tom Senior M1 with the quill feed head
79 Boxford 8" shaper
and all the usual... inc linishers, grinders, welders, pillar drill, T&CG etc etc
For m/c work i would say a big thing is spindle bore size, you want minimum wheel spindle size up there.
Regards.
05/03/2020 14:41:16
Utter tosh.
Jeez.
(jeez..)
Whatever.
04/03/2020 06:24:33
Utter tosh.
Jeez.
03/03/2020 09:07:11
Yep, sounds like the people with lousy experience have been using companies with poor preparation and quality control.
There is a reason why EVERY motorcycle manufacturer in the world have their frames and steel chassis components powdercoated.
Done correctly, with the right preparation, PC is the most economical, hard wearing, corrosion resistant paint surface available today.
My PC put on my 89 Guzzi in 2000 (20 years ago) is still holding up well. Perfect on steel surfaces, little chipping on the corner of an aluminium fork leg.
EngineDIY
