Member postings for norman valentine
Here is a list of all the postings norman valentine has made in our forums. Click on a thread name to jump to the thread.
Thread: Pop device
07/07/2021 22:28:14
Clive Hartland your comments are racist. This is not the place for such remarks. Nowhere is.
Edited By norman valentine on 07/07/2021 22:30:15
Thread: Scrap aluminium for casting
07/07/2021 21:32:55
If you put vinegar on magnesium it will fizz! In fifteen years of melting scrap I have never had a magnesium fire.
07/07/2021 21:28:14
Aluminium wheels provide good quality material. Gearboxes and other car related parts are also good. Just don't go for parts of speciality engines, avoid magnesium"
Thread: Photo orientation
01/07/2021 22:20:32
Howard, that is how I managed to do it in the Past, there must be a simpler method.
Thread: Boxford Model A
01/07/2021 22:18:39
Boxford produced a book- "Know Your Lathe" It is available from Amazon (rather pricey) or free on line.
01/07/2021 21:47:40
This is a problem that I have had before and it has taken a lot of fiddling around to get it right but I am not sure how I have done it. I have a photo in the memory in my computer and when I try to insert it into an album it flips through 90 degrees. What do I have to do to get it right?
Thread: Fractal vice
26/06/2021 10:51:19
I came across this on youtube. The chap did a complete restoration which dd708c32-2422-47ae-8846-2cf5981030ec.jpegincluded making a replacement jaw to replace one that was missing. d3271766-3dcf-4680-a48a-d644a56cdb7f.jpeg
Thread: Auto sign in?
24/06/2021 19:38:20
I used to have the same problem but for the last several months I stay logged in for over a week at a time. I am not aware of having changed anything.
Thread: Chuck keys
22/06/2021 15:30:07
But you have to buy the speed brace, most people would have a bit of round bar in stock.
Thread: Moving machines
22/06/2021 12:57:28
Howard, thanks for your suggestion. I had planned to have the tailstock end towards the wall. As I said earlier I don't have any round bar, to use as rollers, of a suitable size and to buy some would be a waste as I have little call for it, plus the cost of a pinch bar that would probably never get used again. If I had the headstock against the wall I could cut a hole in the wall to pass long stock through, with a flap to keep the draughts out. All my stock isl less than 600mm so whip wont be a problem, I made that mistake once and it is not something that I wish to repeat. I will be buying a ratchet strap as suggested by Michael, I can see further uses for that.
Edited By norman valentine on 22/06/2021 12:59:07
Thread: Chuck keys
22/06/2021 12:30:00
I often have to change my chuck jaws to accommodate different sized and shaped jobs.I find it extremely tedious winding a jaw out to reverse it (4 jaw) or exchanging for inside/outside (3 jaw). I even have two of each chucks with the jaws set differently but I still end up having to change the jaws. I have seen the idea of making a carpenters brace type of tool to speed things up but it has never appealed to me as it seems to be a lot of work to make a simple tool. This is my solution, sorry if it has been invented before but I have never seen it. As I have multiple chucks the chuck keys are different sizes, so I took a piece of 12mm diameter bar and spent ten minutes to file it square at each end. Now I can use it in my cordless drill, what a difference it makes! What used to be a pain in the neck is now no problem at all.26925140-f9ae-4d35-9c56-85d5aea4e4dd.jpeg
22/06/2021 11:56:47
The box and the floor are 20mm osb. The box has 3x2 corner posts and the floor is fully supported so I am confident it would be strong enough. Ratchet strap sounds a good idea, I could screw the anchor point(s) directly into the floor wherever needed, and a ratchet strap would have other uses, a pinch bar would unlikely to be needed again. Thanks for the suggestions.
22/06/2021 07:41:48
a91c34d1-0b3b-482d-81c4-e28abd26fac8.jpegMy Loughborough is on a wooden floor but it is standing on a wooden box to raise it to a sensible height. It is not fixed down but I am not able to move it with my strength. I like the idea of a pinch bar. I had been thinking of complicated ideas like jacking it up and inserting rollers but I have neither jack or large enough steel for rollers.
Edited By norman valentine on 22/06/2021 07:42:25
21/06/2021 18:46:54
What to do? I wish to move my loughborough training lathe through 90 degrees. I have tried but I cannot move it an inch. I don't have any friends to asksad, also I am impecunious. Any suggestions?
Thread: KENNIONS MODEL ENGINEERING SUPPLIES
03/06/2021 21:31:52
I can thoroughly recommend them. I have dealt with them for a number of years. Very quick service, good quality and if you need to phone them you will find them very helpful and knowledgeable.
Thread: Practice material for a newbie
24/05/2021 11:04:39
Free cutting mild steel is the best, in my opinion. With brass you will have needle sharp bits of swarf showering over you and aluminium has a tendency to weld itself to the tip of the cutter.
Thread: Which type/brand of razor blades stay sharp longest? (cutting card/greyboard)
27/04/2021 14:54:12
If you just strop them on a piece of card you will get a little more life out of them.
I assume you are using a proper cutting mat?
Edited By norman valentine on 27/04/2021 14:55:14
Thread: Distorted ship's hull steel panels
13/04/2021 11:42:17
Referring back to Ady1s comment about them being big speedboats with guns I was fortunate to have a tour of one in the Falkland Islands back in 2009. They did a demonstration run at full power and you could certainly feel the acceleration and the centrifugal force as they turned at high speed. So I would say that his description is accurate.
Thread: Covid 19
23/03/2021 22:31:20
A few months ago one of my front incisors broke off as I was peeling a chestnut. I do not have any embarrassment when I am in public due to my mask. So no need for an expensive trip to the dentist.
Thread: Mad Modder site not secure?
10/03/2021 13:20:52
I have been using the site daily for the last several years and have never had a problem.
Dreweatts
Rapid RC
