Here is a list of all the postings Dave Daniels has made in our forums. Click on a thread name to jump to the thread.
Thread: Concrete Panel Garage/Workshop |
02/03/2022 09:07:04 |
Looks vaguely like the cast pattern on mine. From these folk: https://www.leofricgarages.co.uk/index.html Agree entirely with comments re: Fibre Cement Roofing. Durable it ain't. D.
Thread: Book Your Covid Booster! Errr, How? Where? |
11/11/2021 07:52:22 |
Reading some previous posts I now feel rather pampered. Got a text message from Surgery to book for flu and COVID Booster at Babington Hospital, Belper. Booked online for 10:10 AM Tues. 10 min. drive, parked up at 09:55. Bit of a queue but it was always moving. Jab in each arm, then wait 15 mins. Drove out at 10:20. Home at 10:30. Some 47 mins. door to door ... so the NHS can work
Thread: Replacement surgical blades for Swann Morton scalpel handles |
03/11/2021 15:43:30 |
I use these :
https://www.scalpelsandblades.co.uk/index.php
They have the craft knife kit also.
D.
Thread: Where to get small Electrical component? |
01/11/2021 17:05:45 |
Just what I know as a 'Delta Capacitor / Suppressor'. https://cpc.farnell.com/evox-rifa/pzb300mc13r30/capacitor-delta-network-0-1uf/dp/CA08123 https://www.farnell.com/datasheets/2755385.pdf Electrically about the same except the Y2s are 4700pF not 5000pF Physically obviously different. which may be significant.
D.
Edited By Dave Daniels on 01/11/2021 17:07:11 |
Thread: Time code Updates with clock change |
01/11/2021 09:23:02 |
My Acctim in the w/shop had changed by 08:30 ( GMT ). No idea where it derives it's signal. When I replace the battery it gallops around to 12 o'clock then usually waits a bit then resets to correct time. Had it for years, always seems to perform. Don't recollect ever having to intervene. D. Just found the Instructions PDF. Apparently MSF, 60 KHz, Anthorn, Cumbria.
Edited By Dave Daniels on 01/11/2021 09:26:42 Edited By Dave Daniels on 01/11/2021 09:27:00 Edited By Dave Daniels on 01/11/2021 09:36:16 |
Thread: WM18 spindle heat |
30/09/2021 20:56:43 |
My WM18 ( not used a lot in the 18 months I've had it ) bearings run warm. Probably around 40 - 50C after about half an hour at 1500 RPM .
Beware your IR thermometer. Mine is wildly out on a reflective surface. Just tried it and I get 57C on a radiator but 103C on the chrome body of the thermostat which is about 4" away.
D. |
Thread: Cleaning Circuit board - Replacing NiCad Batteries |
10/07/2021 17:09:14 |
CPC stock fibreglass cleaning pens.
https://cpc.farnell.com/c/tools-maintenance/cleaning-chemicals/precision-cleaning/fibreglass-pens?searchref=searchlookahead
D. |
Thread: Covid test |
13/02/2021 13:56:35 |
Had mine last Saturday, 12:20 PM. Woke up at about 03:30, shoulder in agony. Roundly cursed Astra Zeneca until I realised it was the left shoulder and I had the jab in the right. Other than that it seemed to have no effect whatsoever. Why do they ask ' What ethnicity do you consider yourself to be' ? Didn't realise we had a choice. Tried 'Little Sweetie' but that didn't work so settled for White British. Have the flu jab every year and they never seem to have any effect, adverse or otherwise. Seem to remember having TABT, Yellow Fever and another ( Polio ? ) one afternoon in July '62 RAF Bridgnorth but felt nowt although some keeled over .. ?? D.
Thread: T51 Dixon style tool holders? |
13/11/2020 11:28:42 |
I had the same 'effect' with mine. Clamps on one face but not t'other. Well, they did but not very effectively. If you faff about as I did swapping bits around to see just what the hell was going on you may find, as it appears Mr. Hinckley did, that the discrepancy lies with the ( WARCO ) tool-post parts. In my case was one of the pistons / top-hats. I don't have a work-around. I only use one face at a time anyway. Now I know what the game is it doesn't cause me any problems. If I get really chokker with it I'll make another piston. The two WARCO tool-holders clamp up at different 'angles of clamp' on the wrench depending on which face I use.
Summary: I have 8 toolholders. 2 WARCO & 6 RDGT51 ALL fit on one clamping face. The RDG holders don't clamp properly on the other. The 2 WARCO holders need more clamping on the second face. The effect follows the piston on face 2. D.
Edited By Dave Daniels on 13/11/2020 11:31:42 Edited By Dave Daniels on 13/11/2020 11:32:11 |
Thread: Dickson style QCTP? |
10/11/2020 10:57:31 |
I have had the items from RDG and they fit my WM280. Just had a look and they don't seem to be listed at RDG now. I seem to recall they are/were described as T51 ( ? ) with a 16mm slot. But you would need to verify that with RDG themselves. D.
Thread: Soluble hard varnish that sticks tightly to metal? |
03/11/2020 11:08:52 |
Conformal Coating ? Sticks to clean copper PCB. Can be removed with cellulose thinner. Not sure how it would stand up to being abraded though. Other stuff that springs to mind is Rustin's Metal Lacquer.
https://cpc.farnell.com/ambersil/6130004030/conformal-coating-acrylic-400ml/dp/SA02317
D. Edited By Dave Daniels on 03/11/2020 11:12:26 |
Thread: Motor repairs |
27/08/2020 10:05:59 |
Posted by Phil Boyland on 27/08/2020 09:33:58:
Hi, can anyone recommend a motor overhaul place in the Derby area. My lathe motor has developed an issue so need to get it looked at. Cheers
Bowers Electrical Heanor ?? You could try them but they are at the 'big stuff' end of the trade. Could well be cheaper to get a new motor. Used to use a firm in ( Shaftesbury St. ? ) but I think they're long gone.
Thread: Coping with voltage spikes |
15/08/2020 22:30:47 |
Wow, this one's gone on a bit I think Malcolm was on the right lines. Connect a LM317T as a current limiter with a 120R resistor will give circa 10mA. That's where I would start. Cost about 50p. If the problem still persists then it may be you need someone with a scope to see what's really going on. Meters, analogue or digital are often of little help under such circumstances.
D.
Thread: Quality small metric spanners |
27/07/2020 20:12:33 |
+1 for Proxxon, but .... I have a 'set' of these, issued years ago at work. ( I was actually issued with TWO sets but I didn't feel it was my place as a lowly Fault Ferret to embarrass them by pointing out the deficiencies in their arithmetic skills ).
Rather heavy on the beer fund though ..
EDIT don't know what went wrong with the link... Search ebay UK for STAHLWILLE 16
Edited By Dave Daniels on 27/07/2020 20:13:33 Edited By Dave Daniels on 27/07/2020 20:18:06 Edited By Dave Daniels on 27/07/2020 20:18:42 |
Thread: Mild Steel Flat Bar? |
21/04/2020 09:54:10 |
Live Steam Models ( Little Eaton ) appear to list it on their cat. page 09/101. £1.00 / metre. I believe they are trading postal only at the moment. Not sure of that or if it's from sheared sheet. You could enquire 01332 830811.
D.
Thread: Connectors for multiple LED lamps |
29/03/2020 09:24:23 |
Posted by Frances IoM on 28/03/2020 20:28:25:
I have the following connector system on some small audio interfaces which would work well the male plugs (8mm wide) have small screw fixtures for the wires - however I don't know the manufacturer Colour looks a bit like Camdenboss. The O.P. might look here to see if there is anything suitable. ttps://cpc.farnell.com/w/c/cable-leads-connectors/connectors/pcb-connectors/pcb-terminal-blocks/pluggable-terminal-block-headers-sockets/prl/results?brand=camdenboss&pageSize=100 D.
Thread: Are there any left? |
21/08/2019 12:51:46 |
Posted by Frances IoM on 21/08/2019 11:33:32:
2 years ago walking up the hill to Lincoln Cathedral came across such a shop that took me back to the late 50s and early 60s with its collection of radio 'surplus' inc some that dated back then! I subsequently noted their adverts in one of the electronics mags but can't recall seeing them recently so maybe it has ceased
Probably this chap: John Birkett. http://www.zyra.org.uk/birkett.htm Used to go there a lot in the 70's. D.
Thread: Know of a good lathe bed grinding firm? |
16/05/2019 09:57:21 |
Posted by Lee Kennedy on 08/04/2019 17:54:36:
Hi, I have been dealing with Matt @ Unislide in Nuneaton. I have his mobile number which he has said I can give to anyone interested, although I don’t want to put it in a post on forum for obvious reasons. I’ll PM the number if you like? Other than that a quick google would give a landline number. I have found Matt very helpful, I am dropping my Model A Boxford off at the end of this month for regrind.
Lee
I'm interested in having my Super7 done but after several tries on the landline number .. no answer. Anyone else had any joy on L/L phone ??
D.
Thread: Sending of heavy items |
09/04/2019 12:01:26 |
Posted by RMA on 09/04/2019 11:15:41:
Thanks for the link Michael. I've tried them and several other's and they all say 3050mm is too long to carry. It would only be cost effective if I could use a national carrier, so I won't be buying that item!
I have had some of this delivered by Tuffnells ( pretty sure it was them ) a couple of years ago. https://www.aluminiumwarehouse.co.uk/1-2-in-x-10-swg-aluminium-round-tube 5 metre lengths. Came in a cardboard tube. D.
Edited By Dave Daniels on 09/04/2019 12:02:50 |
Thread: Any idea what this connector is called |
08/03/2018 18:15:29 |
Looks somewhat like what I once knew as a 'CES QD' connector. One ref. I found but you won't be interested ... www.amazon.co.uk/Disconnect-Harness-Connector-Bullet-Coast/dp/B00MYDR18A
D.
