Here is a list of all the postings Stuart Bridger has made in our forums. Click on a thread name to jump to the thread.
Thread: Tomato seed recommendation? |
09/03/2022 15:53:53 |
My Dad, now well into his '80's has been gardening all his life. he never uses growbags, but large individual pots. |
Thread: T pylons |
09/03/2022 14:46:45 |
Most of the paint used for pylons is micaceous haematite based. Edited By Stuart Bridger on 09/03/2022 14:48:46 |
Thread: DRO's and mental agility |
23/12/2021 07:26:56 |
I would say essential on the mill for ones own sanity. Mind you there was never a DRO on the mill I used during my apprenticeship 40 years ago. |
Thread: Plans and castings |
18/11/2021 18:20:50 |
If you are willing to look beyond castings, take a look at Elmers Engines. Free plans available online Not a beam, but I am (slowly) working on #29 mine engine |
Thread: Music on TV Programmes. |
08/11/2021 17:46:43 |
Posted by Peter Bell on 08/11/2021 13:45:08:
Stuart, Your comments and setup are interesting as I have just got a flat screen TV and now realise after experimenting with settings that I'm going to have to spend to improve the sound quality. Speech is fine for me but overall it sounds very much like its coming from a tin can. The previous CRT 20 yr old Phillips TV sounded great! So looking around and of course so much to choose from, are home cinema kits much of a step up from sound bars and is a "modest home cinema setup" just a smaller/cheaper version of a larger outfit? Peter Hi Peter, |
08/11/2021 12:16:16 |
Personally I think this has a lot to do with modern flat panel TV design and potentially the decoding of surround sound audio to the TV speakers. There is no room for anywhere near decent sized speakers in the cabinets. The sound experience is going to be seriously comprised, without investment in external kit such as a sound bar or full home cinema setup. It amazes me that all the technology seems to go into the display with sound being an afterthought. I have a modest home cinema setup with a full size front speaker delivering the center (mostly speech) channel. Two additional stereo speakers deliver the L&R front effects, which is mostly the incidental music. |
Thread: Chuck Guard |
03/11/2021 13:58:57 |
My chipmaster didn't come with a guard and the first thing I did was fit a quality industrial guard. |
Thread: My new favourite threads |
16/10/2021 09:53:45 |
I needed to make up a missing nut for a thermal cutout. Thread was M11 x 1. Tracy tools to the rescue as usual. Tapping drill 10mm and so easy to cut. |
Thread: Cleaning glass. |
16/10/2021 09:50:34 |
Autoglym Fast Glass for me, not cheap, but a little goes a long way |
Thread: Hermes. A Company in Total Confusion! |
14/10/2021 18:30:12 |
Just had a positive experience with Hermes. |
Thread: Multimeter recommendations |
10/09/2021 12:02:03 |
About 35 years ago, a short part of my career was spent both using and repairing AVO multimeters. Also we went out of "field jobs" outside of the workshop around the factory. If an Avo was needed this went in the basket of a butchers style trade bike as they were damned heavy to carry any distance. Hand held Fluke DMMs were a godsend as they would just fit in a lab coat pocket. |
07/09/2021 17:12:43 |
I have a 70 series Fluke handheld, that I have had since the mid 1980's. It is bulletproof in its rubber holder. |
Thread: Backing up computers across a network |
23/08/2021 16:37:37 |
Iain, agreed cloud backup is very viable. I use Carbonite to back up my files from my home PC |
23/08/2021 16:17:12 |
As "one of the pros" I worked in backup and storage for over 20 years. I would say that home grown backup solutions are not the way to go. This is one time to get in the "pros". As others have said, it needs to be implemented, documented and restore regularly tested. I have too many "war stories" of data loss and inability to restore data when it is really needed. There a lots of network backup solutions out there, but also remember you need copies offsite as well. What if you have a fire? A simple copy is NOT good enough, If you have bad data (virus, corruption, etc) having an exact copy of bad data on your backup drive is not good enough... |
Thread: GigaFactory |
16/07/2021 17:21:01 |
Posted by Anthony Knights on 16/07/2021 09:29:57:
I think the points made several times about infrastructure are significant, especially in my case. My house, built about 1960, along with about 150 others in the street, has an electric meter rated at "MAX 40 amps". I would assume that the input fuse to the house and the supply cable are similarly rated. Would this be able to supply electric heating + charge a car + supply the normal domestic load. I think a major up grade will be required, especially if all the other houses in the street are the same. Not just the fuse rating (100A is normally recommended), but some older buildings have a "looped service". This is where the main incoming supply cabling is daisy chained in and out of properties along the street. This you can tell if you have two big cables coming into the fuse block. If this is the case you will not not be allowed to connect an EV charger until the looped service has been upgraded to a conventional star type feed. This means running in a new cable. |
14/07/2021 15:52:25 |
The ideal situation for home charging has to be Solar PV plus a power bank. But how many homes can accommodate this? Suitable roof layout and direction, plus it is a significant investment. It certainly doesn't work for my property. Sucking huge amounts of power off the grid is not attractive to me and if everyone goes that way can the grid support it? I already have a ground source heat pump, which is not cheap to run Second point is whole life cost of the vehicle. I have an 11 year old diesel Saab. It passes the E5 emissions MOT fine and owes me nothing. I have no plans to replace it in the short term. I generally try and avoid cities. Locally Oxford is so car unfriendly, so I tend to use public transport anyhow (diesel bus??) I know at some time I will have to make a decision, but I am holding off as long as I can. |
Thread: Yet another scam |
12/06/2021 06:46:13 |
Last time I got the washing machine warranty call, I decided to play them. Showed great interest and got transferred to supervisor to finalise the contract Then came the key part they wanted my bank details. I say no, I am paying you money, give me your bank details. The guy soon got tired of this and dropped the call. The Microsoft one can also be fun. Once I told them that I have worked in IT for 30 years. The cheeky scammer then said I should know how serious the problem is.... Either that or play completely dumb. Anything to tie them up and delay calling anyone more gullible
Thread: Scalped on my doorstep - it left an unpleasant taste in my mouth. |
06/06/2021 08:34:13 |
Nottingham Knockers, usually have fake ID and have nothing to do with probation https://www.oprepeat.co.uk/nottingham-knockers/ |
Thread: Secrets of the transport museum |
26/05/2021 15:03:48 |
I agree the voice-over is very poor. What did for me last night was in relation to the Napier Railton. I will paraphrase "it was a racer and weight was everything, it doesn't have electrics, it doesn't even have ignition,,," |
Thread: B&D workmate |
25/04/2021 15:49:31 |
Still got mine from the late 80's. The plastic clips locking the legs down failed recently, but replacements available at a sensible price. 8 |
