Member postings for Blue Heeler
Here is a list of all the postings Blue Heeler has made in our forums. Click on a thread name to jump to the thread.
Thread: Huxtable Hot Air Engine Running a Fairground with my Granddaughter Ruby
14/04/2021 05:46:42
Thread: Printer useful parts
13/04/2021 08:24:12
I just love getting printers!
Thread: BA screws and nuts
13/04/2021 08:22:21
In Australia alas my only source is eBay.
Thread: Home made screws
13/04/2021 08:20:45
Great job on those small screws.
13/04/2021 08:15:09
Posted by Michael Gilligan on 13/04/2021 08:12:21:
That looks like a decent power output from a little hot air engine yes
Thanks Michael, really impressed with the Baker Fan and how well they are working on small stirling and steam engines, these were originally designed by a Mr. A.D. Baker to test steam engines and run them in as they left the factory the Baker Company Factory. From Google "A Baker Fan is a simple air-resistance device used run off an engine via a belt and the faster its turned, the harder it is to turn and puts a load on the engine".
They are very good for putting a load on small model steam engines to get them to run at more realistic speeds (not racing) and to get a nicer sound from them from running under a load.
13/04/2021 05:01:40
Huxtable Hot Air Engine Operating a Baker Fan
Thread: Model Turbines
10/04/2021 03:27:43
Very interesting thread to read through, this is a DIY Steam Turbine that i built recently and its first test on steam -
Thread: Little nuts.......big fingers.
10/04/2021 03:09:12
Some good tips
Thread: Old Engine Ads from a bygone era
10/04/2021 03:05:07
Posted by derek hall 1 on 08/04/2021 08:47:15:
Good video....and no annoying background music!
Derek
Thanks Derek.
09/04/2021 11:01:37
Posted by robjon44 on 09/04/2021 09:47:34:
Hi all, a very long time ago my friend Jeff was given a Mamod steam engine by a workmate, as his son was pretty mechanically minded we set about giving the little engine a job of work, cue large wooden box to give it some height when standing on the dining table, followed by constructing a crane from Meccano before securing engine & crane on top of the box giving about 4 feet of lift from floor level, drive train by the beautifully crafted Meccano chain sprockets & chain, the little engine gave the young lad many happy hours & a lifetime later he still harks back to it even though he is approaching retiring age & I of course am older than dirt, happy times.
BobH
Thanks Bob for that anecdote enjoyed reading it.
09/04/2021 00:34:53
Thanks all and thanks for the links Michael.
I have the majority of these old ads framed and up on the walls of the room where my steam engine collection resides. The ephemera really ads a touch of nostalgia.
Cheers all,
Jim
08/04/2021 06:24:25
Here's a collection at 10 second intervals of Old Engine Ads from a bygone era, there should be something for everyone here in this mix. Make yourself a cup of coffee sit back and relax and get transported back into this wonderful era that we all still enjoy to this day with our engine collections and collecting.
Thread: Belting options for running Steam Engine Accessories
01/04/2021 06:11:32
Belting options for running Steam Engine Accessories -
Thread: My easy solution to No More Clogged Spray Paint Rattle Cans
31/03/2021 00:07:24
Posted by Morty on 31/03/2021 00:00:40:
Hi there!
I just pop My nozzles in a jar of thinners after use, fish them out when needed,give them a quick wipe with paper towel.
Pop them back on the can and spray a little paint through before starting the job proper.
Cheers, Pete
G'day I like my idea better wink
I have so many different brands of cans and nearly every nozzle is different, this was I know the right nozzle is with the right can. And did you notice that each time I blew the turps out the nozzle it went further as the paint cleared internally? But whatever works best for you....its better than full cans of paint that are blocked!
30/03/2021 22:41:41
Posted by IanT on 30/03/2021 10:54:37:
Good idea - I'll try that next time around.
Thank you.
IanT
Cheers Ian hope it works as easy for you as it does for me.
30/03/2021 08:01:09
Posted by Hopper on 30/03/2021 06:45:21:
My usual method is poking a bristle from a wire brush down the small spray hole and swearing a lot.
G'day Hopper, been there mate as well. My swearing came from the next time I went to spray something though because of the big droplets coming out because I'd deformed the nozzle outlet with the wire blush
29/03/2021 23:59:04
Posted by not done it yet on 29/03/2021 08:40:39:
Isn’t the nozzle cleared by a quick press with the can inverted?
As explained in the video I spray lots of small parts. There's no way there's going to be enough propellent in the can to keep cleaning the nozzle by inverting it each time I spray something.
29/03/2021 05:47:36
Thread: Work Shop Talk - Cleaning Sanding Belts & Sanding Discs Easily
26/03/2021 05:44:07
Posted by Roderick Jenkins on 25/03/2021 11:16:43:
I've got one of the Axminster ones which I bought for use on my drum sander. I believe it is made from raw (un-vulcanised) rubber.
Rod
Yes it just crumbles up and doesn't get stuck to the belt grit.
25/03/2021 00:40:37
Cleaning Sanding Belts & Sanding Discs, Belt Sanders etc etc Easily refresh all your belts literally in seconds and also even refresh diamond stones like Ezy-Laps -
JD Metals
