Member postings for Oompa Lumpa
Here is a list of all the postings Oompa Lumpa has made in our forums. Click on a thread name to jump to the thread.
Thread: I need to buy a Slitting Saw
19/10/2013 21:50:11
No doubt all of the various factions will argue for and against (and that is fine by me) but I need to buy a slitting saw. I don't have one or any other method of slitting a bush so it's time to "invest" in more tooling. I need a MT3 arbour and that's the first question, which one? I have seen both a 'Screw Type' and 'Nut Type' milling arbour for sale on this page -> **LINK**
and as I don't have anything like this and I would like to buy only one this month which one should I be buying?
Thread: Machining Polyurathene
14/10/2013 20:48:08
Posted by Ian Phillips on 14/10/2013 19:14:10:
Graham
What do you mean by Polyurathane?
The Polyurethane I know of is a rubbery sort of material and certainly would not produce white snowflakes. I have only 'machined' it on the lathe with Stanley knife blades.
Can you give a better description of the material?
Ian P
Hi Ian and thank you all for your replies so far.
"Snowflakes" is probably a bit of a dramatic term. Lots of fine crumbly white bits is probably closer to the truth. It is yellowish translucent and as described above, soft and bendy. Yes - Horrid is a good description. You could almost certainly tie a knot in a piece of 8mm diameter.
Not like Corian Jason - which I have machined with great success in the past.
How do you use the Stanley blades to turn material, they are slicing blades?
14/10/2013 18:59:56
I have a specific job I need to do and it involves making some seals from Polyurathene. I have bought a couple of lengths and today I chucked up a 22mm diameter 50mm long piece in the lathe. I tried a few different cutters and produced a very attractive pile of "snowflakes" on the bench.
I have tried HSS, Tipped tools and Tungsten Carbide. Anyone had any experience of this material? The finish produced by the tipped tool was the most acceptable but I was unable to machine to any sort of tolerance. Very much hit and miss.
TIA.
graham.
Thread: Recovering a Milling Vice
14/10/2013 18:54:12
Jason, thank you. Sometimes you get tunnel vision and for the lfe of me I couldn't see this. I will set to and make some clamps as per your drawing.
I appreciate the guidance.
graham.
14/10/2013 18:40:03
"was" I think is the word you are looking for. It is only a rotatary base if I have the other half, which sadly I don't.
But any suggestions as to how to securely attach it to a mounting plate gratefully recieved. The hole is tapped 5/8 Whit.
14/10/2013 17:30:58
A couple of photographs of the actual vice.
13/10/2013 21:13:47
Good idea but I don't think it would work, the bottom of the vce is too thin. I think if i took a picture and posted it that would help.
Thanks though, it is certainly another angle.
13/10/2013 20:32:29
Hi everyone, long time lurker but I recognise a few familiar names from other forums
Well, I didn't quite know what to use as a title but this is the scenario. I have aquired a pretty decent 4" jaw milling vice. Snag is, someone has milled off the cast lugs that you would use to hold it down to a table. The short "wings" that are on either side of the jaws (usuually) are missing. The upside is there is a good 14mm tapped hole in the centre of the underside. It is not a swivel base.
In order to use it, so far, my plan is to use a countersunk machine screw to bolt a square plate to the underside and lock it by drilling either side for a silver steel dowel.
That's as far as my thinking process will go so far so I am looking for ideas. Am I on the right track? I would of course machine a couple or four slots in the plate so I can mount it to the milling table. Should I use countersunk machine screws instead of the silver steel pins in order to furthe secure the base? There is no question of welding as the base is cast.
Thanks everyone.
Ausee.com.au
