Member postings for Rick Parry
Here is a list of all the postings Rick Parry has made in our forums. Click on a thread name to jump to the thread.
Thread: What did you do today (2015)
01/01/2015 14:30:14
Made an adaptor plate for my collet chuck today. Tested when finnished and found the it to be 4 thou out. Do I need to to do it again?
Thread: Motor sounding rough
17/03/2014 23:06:24
Sorry to say but it sounds like the start capacitor ot me. Try spinning it up with the belt removed to some speed before you switch on with piece of string around the pully will do it. It should then start and run if everything else is working.
Richard
Thread: Indentfication of Induction Motor
21/01/2014 19:56:20
Richard
It looks like Brook Cromptom to me Is it a runner?
The end plate can be brazed to repair the fixing for the switch easy enough
Richard
Thread: Workshop size
12/10/2013 16:13:20
My workshop is 15 X 5 Meters with a 5 X 5 upstair storeage area and guess what... it's not big enough!!
I think that what ever you decide to build will eventually not be big eough if you have the space you will use it all and the more you have the more you want
Richard
Thread: Inverter Wiring
12/10/2013 09:59:03
Hay Neil 10 wires?
I have done a quick calculation of the numbers of cables you will need to control your device and come out with 7 asuming you need forward, reverse, jog, and 3 for pot.
even if you incoperate a big red emergency stop you will need a Max of 9
if the other 3 cables are for the motor connection then I cannot stress strongly enough do not do this.
The motor connection must be a seperate dedicated cable.
Regards Richard
JD Metals
