Member postings for Robonthemoor
Here is a list of all the postings Robonthemoor has made in our forums. Click on a thread name to jump to the thread.
Thread: Dismantling Vertex HV6 Rotary Table
14/10/2018 14:26:07
Hi Brian wood I’m looking at your photo as I have a vertex HV6 brand new never been out the box til now & the winding handles missing, so will make one. Just can’t make out from your photo the handle & the washer that holds it on, it as slots in it I assume as the shaft is flat on either side with a 4 mm key placed in. Would you take a photo of the washer & handle on there own, with the collar separated away please.
Regards Rob
Thread: Jones & Shipman surface grinder drive unit
09/10/2018 18:49:37
Posted by Pete Rimmer on 09/10/2018 18:22:04:
Posted by Robonthemoor on 09/10/2018 18:08:50:
Pete Rimmer you say you had one like this, could you pull the grinding wheel toward you & it would spring back say a mm or two.
No, not at all Rob. The position of the two round weights in the middle set the front/rear clearance as I recall.
Thank you Pete, Al have you read this?
09/10/2018 18:08:50
Regards RobPete Rimmer you say you had one like this, could you pull the grinding wheel toward you & it would spring back say a mm or two.
04/10/2018 17:51:45
Posted by Robonthemoor on 04/10/2018 17:50:17:
Posted by Mark Rand on 04/10/2018 16:13:16:
Who?
We rang Hardinge no answer Mark.
Tony as only parts manuals not Sevice manuals.
04/10/2018 17:50:17
Who?
04/10/2018 15:21:57
Posted by Mark Rand on 04/10/2018 00:25:08:
Phone up Jones&Shipman (Hardinge now) in Leicester, with the serial number in hand, and see if they've got a manual. If not, Tony at www.lathes.co.uk might have sufficient data.
No answer 😕
03/10/2018 10:17:51
42551eaa-0669-4446-a551-825c7decee0a.jpegea28348e-bafe-4120-887c-1a0ff1a00f96.jpeg023ec2fe-3fb5-4c06-a9a1-7f9550ebb8c6.jpegwe have two Joan & Shipman 540 surface grinders, the older one ( with a counter weight in the back) has an oil seal leake at the spnindle so we need to replace it. We have the gearbox drive case off the machine but no idea how we take the shaft out! Also how to adjust the end float! Please see photos below.
Thread: Rotary table identification
27/09/2018 08:25:15
Thanks Howard.
24/09/2018 09:24:23
Hi Trevor I thought it was an soba so thanks for putting me right, I need the turning handle can one buy them as a part? Do you think MSC or Chronos for best suppling the parts.
Thanks for the table Neil I’ve printed it off.
23/09/2018 22:35:02
can you ID this rotary table I think it is an HV-6 but don’t know the make! & I need parts & I can according to the intruction book I d504a2a3-a69b-496e-b901-e37291c4c7d9.jpegcan make it into a index table.b05cb302-ba79-4a94-92f1-8a8293b44f76.jpeg
Thread: Silver soldering
08/09/2018 17:27:58
Ok thanks for the comment, I will buy some.
08/09/2018 05:49:12
for fixing carbide tips onto tooling, do I need 35% or 55% silver content for best results?
Thread: Gate mill
02/01/2017 17:34:57
This type, I find them very annoying😡Oil nipple
Thread: Brake unit
30/12/2016 15:14:08
Inside the case when the brake unit has been removed. As you can see just a bearing inside a case, called in the manual as a bearing nut, above the belt pulley.Gate mill G301D
30/12/2016 15:09:29
I got it off, a little heat from the heat gun & it just slides off. I will do a full video of the rebuild as nothing on utube for this mill. Gate turret mill G301D
29/12/2016 12:58:30
Thats a good description, moped brake. I'm sure I have seen a head like this gate mill been worked on on utube or one of the forums but can't find it😕
29/12/2016 05:24:16
Posted by Alan Waddington 2 on 28/12/2016 20:08:39:
Is the handle pinned on with a roll pin ? You might need to remove it to allow the casing to come off.
No roll pin
29/12/2016 05:22:54
Been told I need to remove a chamfered pin😮 Can't find it😕 Ordered a manual but as manuals go I won't hold my breath.
29/12/2016 05:19:33
Posted by wheeltapper on 28/12/2016 23:32:44:
can't see properly but the lever coming from the centre boss looks like it's got a flat on it.
it doesn't just unscrew from the boss, does it?
No I think that part is like a rear brake drum of a car, but I'm not certain 🤔
Roy.
29/12/2016 05:17:19
Posted by Bazyle on 28/12/2016 19:01:54:
Not much info there. Does the big hole in the background contain the spindle with a surface against which a brake shoe presses? It could be the shoe needs pressing back or does that handle need to come off?
No that hole take the motor, the spindle is the hole just behind the brake lever,
Dreweatts
Rapid RC
